MHB 1.8.6 AP calculus Exam continuity
karush
MHB
well just by observation $x-2$ cancels out leaving $2x+1$ plugging in $2$ gives $2(2)+1 = 5$
or is there some more anointed way to do this.
Not really a fan of this explanation.
I want to know why
$\dfrac{(2x+1)(x-2)}{x-2}$
is NOT EXACTLY THE SAME as
$(2x+1)$
I assume its about k
Always thought filling a hole was more rigorous
definition of continuity at $x=c$ ...
1. $f(c)$ exists
2. $\displaystyle \lim_{x \to c} f(x)$ exists
3. $\displaystyle \lim_{x \to c} f(x) = f(c)$
I shall personally anoint this:
The definition of "continuous" is "f is continuous at x= a if and only if both f(a) and \lim_{x\to a} f(x) exist and
\lim_{x\to a} f(x)= f(a)". Further
\lim_{x\to a} f(x)= L is defined by "given any \epsilon> 0, there exist \delta> 0 such that if 0< |x- a|< \delta then |f(x)- L|< \epsilon.
Note the "0< |x- a|" which perhaps should be given more emphasis in math classes. The value of \lim_{x\to a} f(x) depends entirely upon the values of f(x) for x close to x= a, but the value of f(a), or even whether it exists, is completely irrelevant to the limit!
For this problem, as long as x is not 2, x- 2 is not 0 and the "x- 2" terms in numerator and denominator cancel.
That is, for x\ne 2, f(x)= \frac{(2x+1)(x- 2)}{x- 2}= 2x+1.
I want to know why
$(2x+1)$
They are "NOT EXACTLY THE SAME" because the second has value 5 when x= 2 and the first is not defined there. The graph of y= 2x+ 1 is a straight line while the graph of y=\frac{(2x+1)(x- 2)}{x- 2} is that same straight line except for a hole at (2, 5).
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-slog2)+e^(-slog3)+e^(-slog4)+... , Re(s)>1 Riemann extended the Zeta function to the region where s≠1 using analytical extension. New Zeta function is in the form of contour integration, which appears simple but is actually more inconvenient to analyze than the original Zeta function. The original Zeta function already contains all the information about the distribution of prime numbers. So we only handle with original Zeta...
