1-Dimensional Distance with Drag
  • Thread starter Matt Callicott
  • Tags
    Drag
In summary: I think I understand what you’re saying now. In summary, the equations show that the object will eventually stop after traveling a finite distance. However, there is no terminal velocity, so the distance traveled may be infinite.
Matt Callicott
Find the distance, x, that an object of mass m travels through a medium, given an initial veloicty v0.
I searched the web and came across a site that showed how to deal with velocity dependent forces. http://farside.ph.utexas.edu/teaching/336k/Newtonhtml/node17.html#svelyd
Equations:
FD = 1/2 ρCAv2 , simplified to FD = Bv2
mv (dv/dx) = -Bv2
Going off of what the site said, I arrived at the following answer using these steps: mv dv = -Bv2 dx
(1/B) v/v2 dv = 1/m dx
-1/B ∫ 1/v dv = 1/m ∫ dx
-1/B ln(v / v0) = x / m
So this gives me that x = -m/B ln(v / v0)
However, this does not make since in the context of the question because x is dependent on v, which is not the initial velocity (v0). I do not know if my interpretation is wrong or if I am doing something wrong here. Any help is appreciated. Thanks
When you integrate, consider bounds.
After posting I did try to integrate with bounds. I tried v bounds of v0 and vf. Since I want to find the total distance, however, I substituted 0 as vf. This gave me a problem with the ln function since ln(0) is undefined.
Ok, so how do you interpret that result?
I’m not sure how to interpret that. Plugging in values here doesn’t yield a finite distance, yet I know that the object will eventually stop. What am I missing?
Is that your intuition, or do you have some reasoning for that?
My intuition tells me that it will stop; however, are you implying terminal velocity?
No, there cannot be a nonzero terminal velocity since there is no force tending to maintain motion.
I am challenging your statement that it must stop after a finite distance.
On the one hand, your intuition tells you that, on the other, the equations say otherwise...
So the interpretation of the equation is that it takes an infinite distance to stop? I’m not following what you’re saying because my intuition is, what I have previously thought of as, strong that it will stop.
In your model where the drag is proportional to ##v^2##, yes. That does not mean that this is a good physical model.
In general, for small velocities, the drag is proportional to ##v##, not ##v^2##.
Orodruin said:
In your model where the drag is proportional to v2v2v^2, yes. That does not mean that this is a good physical model.
In general, for small velocities, the drag is proportional to vvv, not v2v2v^2.
This is interesting. All of the equations that I have found are FD=0.5pACv2. Is there an alternative?
The ##C## in your equation is a constant only for large Reynold's numbers ##R = vD/\nu##. For small Reynold's numbers, ##C## goes roughly as ##1/R \propto 1/v##.
Beware of intuition! Physics is a mathematical science, not a subset of philosophy! :smile:
Right, but equally beware assuming the same equation applies throughout the domain of interest. Sometimes intuition is telling you something important.
Sorry for the late response. Is there some mathematical function that describes the whole scope of the domain? A piece wise perhaps? What is the threshold in which you shift from proportionality of v2 to v?
I’m having a difficult time comprehending that the force changes due to velocity. I’m not doubting you all’s expertise, I just don’t understand how you can do an analysis like this one with two equations and an ambiguous threshold.
Thank you all for your responses
There is no known equation of purely analytic form which operates at all speeds. If you were to create such an equation, analytic or otherwise, it would be found to be approximately quadratic at high speeds and linear at low speeds. There is a distinct transition over a fairly narrow range between linear (low) and turbulent (high) flow. Where exactly that transition occurs depends on parameters such as density and viscosity.
In the context of this thread, I note that you are given hardly any relevant values. This suggests to me that the question setter expects infinity as the answer. But as Orodruin points out, it must at some stage transition to linear, and that will result in a finite value, but you do not seem to have enough information to determine it.
Related to 1-Dimensional Distance with Drag
1. What is 1-Dimensional Distance with Drag?
1-Dimensional Distance with Drag is a scientific concept that involves measuring the distance traveled by an object in one dimension (usually along a straight line) while taking into account the effects of drag on the object's movement. Drag is a force that acts in the opposite direction of an object's motion, causing it to slow down.
2. How is drag calculated in 1-Dimensional Distance with Drag?
Drag is calculated using the drag equation, which takes into account the density of the fluid the object is moving through, the object's velocity, its cross-sectional area, and its drag coefficient. The drag coefficient is a measure of how streamlined the object is, with lower values indicating a more aerodynamic shape.
3. What is the difference between 1-Dimensional Distance with Drag and 1-Dimensional Distance without Drag?
The main difference between the two is that 1-Dimensional Distance with Drag takes into account the effects of drag on an object's movement, while 1-Dimensional Distance without Drag assumes there is no drag acting on the object. In real-world situations, objects are almost always affected by some amount of drag, so 1-Dimensional Distance with Drag provides a more accurate measurement of an object's movement.
4. How does air resistance affect 1-Dimensional Distance with Drag?
Air resistance, also known as air drag, is a type of drag that results from an object moving through the air. It can significantly impact an object's movement and must be taken into account in 1-Dimensional Distance with Drag calculations. The amount of air resistance an object experiences depends on its shape, speed, and the density of the air.
5. What are some real-world applications of 1-Dimensional Distance with Drag?
1-Dimensional Distance with Drag has many practical applications in fields such as engineering, physics, and sports. For example, it can be used to design more aerodynamic cars, optimize the flight paths of airplanes, or improve the performance of athletes in sports like cycling or skiing. It can also help in predicting the trajectory of projectiles, such as bullets or rockets, and in understanding the movement of particles in fluid flow.
