1-dimensional non-conservative force that depends on position?
In summary, friction does not work as a means of creating a non-conservative force that depends on position.
Adoniram
94
Does there exist a 1-dimensional non-conservative force that depends on POSITION (not velocity)?
N/A
I've given this a lot of thought, and I can't come up with anything! Friction doesn't work, etc...
Any help would be greatly appreciated! :)
N/A
Welcome to the PF.
Why doesn't friction work?
Would the hysteresis in a rubber band qualify it as a non-conservative?
Friction doesn't fit the definition because it is not dependent on position. Hysteresis... not sure. That seems more dependent on tension, but if it can be quantified in terms of position, that might work. What do you think?
I think friction can work if you put one condition on it. Can you think of that condition?
Are you referring to static vs kinetic? As far as I can tell, friction depends on some velocity being present (kinetic), or not present at all (static). As far as I can imagine, it doesn't depend on position, but I would love to hear which condition you refer to :)
We can't give out answers here at the PF (it's against the rules for schoolwork questions). So you will need to think on it more. I'm referring only to kinetic friction. Think about what you are trying to achieve in this problem, and see if you can think of what to do with friction to accomplish it...
Ok, so say you have a block sliding along a surface. The only way I can think of making the force of friction dependent on position is if the coefficient of friction changes along the surface. For example, if you have sand paper on the surface with changing grit values from left to right, then yes, the force of friction would absolutely depend on position.
I'm not sure if that's what my prof is going for, but I'll give it a whirl... I can't think of any others!
That's exactly what I was thinking of -- good for you for coming up with it! I think it satisfies the problem statement... The non-conservative force is position dependent, but not velocity dependent.
Thanks for your replies :)
The forum looks great, I don't know why I didn't find this earlier. I still have 1.5 more years of my degree program left, so this forum will undoubtedly be handy!
FAQ: 1-dimensional non-conservative force that depends on position?
What is a 1-dimensional non-conservative force?
A 1-dimensional non-conservative force is a type of force that acts on an object along a single dimension, such as in the horizontal or vertical direction. This force is not conservative, meaning that it does not conserve mechanical energy, and its magnitude and direction can change as the position of the object changes.
How does a 1-dimensional non-conservative force depend on position?
A 1-dimensional non-conservative force depends on position because its magnitude and direction change as the position of the object changes. This means that the force may be different at different points along the object's path, and it is not constant like a conservative force.
What is an example of a 1-dimensional non-conservative force?
Friction is a common example of a 1-dimensional non-conservative force. As an object moves along a surface, the force of friction acting on it changes depending on its position. For example, as a block slides down a ramp, the force of friction decreases as it moves further down the ramp.
How is work calculated for a 1-dimensional non-conservative force?
The work done by a 1-dimensional non-conservative force is calculated by integrating the force over the object's path. This takes into account the changing magnitude and direction of the force at different positions along the path.
What is the relationship between 1-dimensional non-conservative forces and energy?
1-dimensional non-conservative forces do not conserve mechanical energy, as their magnitude and direction can change along the object's path. This means that work must be done to overcome these forces, resulting in a change in the object's kinetic or potential energy.
