10.5.55 Does the following series converge or diverge?
  • MHB
  • Thread starter karush
  • Tags
    Series
In summary: Ratio Test. Thus, the series converges. In summary, the series $S_n = \sum_{n=1}^\infty \frac{10^n n!n!}{(2n)!}$ converges by the Ratio Test.
karush
MHB
3,269
$\tiny{10.5.55}$
$\textsf{ Does the following series converge or diverge?}$
\begin{align*}\displaystyle
S_{n}&=\sum_{n=1}^{\infty}\frac{10^n n!n!}{(2n)!} \\
\end{align*}
$\textit{ratio test?}$
:cool:
Yes, the ratio test will work well here. (Yes)
$\tiny{10.5.55}$
$\textsf{ 10.5.55 Does the following series converge or diverge?}$
\end{align*}
$\textsf{The Ratio Test Let }$
$\displaystyle\sum ar^n$ $
\textsf{ be a series with positive terms and suppose that}$
&\lim_{{n}\to{\infty}} \frac{a_n+1}{a_n}=p \\
\end{align*}
$\textsf{Then}\\$
$\textsf{(a) the series converges if $p<1$}\\$
$\textsf{(b) the series diverges if $p>1$ or p is infinite}\\$
$\textsf{(c) the test is inconclusive if $p=1$}\\$
$\textsf{So}\\$
&=\lim_{{n}\to{\infty}}\frac{10^n n!n!+1}{(2n)^n}=p=\frac{5}{2}\\
\end{align*}
$\textit{The series diverges by the Ratio Test since the limit resulting from the test is $\displaystyle\frac{5}{2}$}$
Yes, I got:
\(\displaystyle p=\lim_{n\to\infty}\left(\frac{10(n+1)^2}{(2n+2)(2n+1)}\right)=\frac{5}{2}>1\)
Divergent. $\checkmark$
$$(2n)! = 1 \times 2 \times \cdots (2n-1)(2n) \leq 2 \times 2 \cdots (2n) (2n) = 4^n(n!)^2$$
Hence
$$\sum_{n=1}^\infty \frac{10^n (n!)^2}{(2n)!} \geq \sum_{n=1}^\infty \left( \frac{5}{2}\right)^n$$
FAQ: 10.5.55 Does the following series converge or diverge?
What is the meaning of convergence and divergence in a series?
In a series, convergence means that the sum of all the terms in the series approaches a finite limit as the number of terms increases. Divergence means that the sum of the terms does not approach a finite limit and instead goes to infinity.
How can I determine if a series converges or diverges?
There are several convergence tests that can be used to determine if a series converges or diverges. These include the comparison test, the ratio test, the root test, and the integral test.
What is the significance of the number "10.5.55" in the series?
The number "10.5.55" is likely just a label or index for the series and does not have any specific significance in determining whether the series converges or diverges. It is important to look at the actual terms and use a convergence test to determine the behavior of the series.
Can a series converge for some values and diverge for others?
Yes, a series can converge for some values and diverge for others. This is because the convergence or divergence of a series is dependent on the behavior of the individual terms in the series, and different values can produce different behaviors.
What is the difference between absolute and conditional convergence?
Absolute convergence means that the series converges when considering the absolute value of each term, while conditional convergence means that the series converges but not when considering the absolute value of each term. In other words, a series that is absolutely convergent will also be conditionally convergent, but the reverse is not necessarily true.
