10) AP Calculus linear functions
In summary, we have a function $f(x)$ that is continuous for all $x$, with $f(0)=2$, $f'(0)=-3$, and $f''(0)=0$. We also have a function $g$ whose derivative is given by $g'(x)=e^{-2x}(3f(x))+2f'(x)$ for all $x$. For part a), we need to find an equation of the line tangent to the graph of $f$ at the point where $x=0$, which is $y-2=-3(x-0)$. For part b), we are given that $g(0)=4$ and need to find an equation of the line tangent
karush
MHB
3,269
$\textbf{10)} \\
f(x)\text{ is continuous at all } \textit{x}
\displaystyle
f(0)=2, \, f'(0)=-3,\, f''(0)=0 $
$\text{let} \textbf{ g }
\text{be a function whose derivative is given by}\\
\displaystyle g'(x)=e^{-2 x} (3f(x))+2f'(x)
\text{ for all x}\\$
$\text{a) write an equation of the line tangent to the graph of f at the point where } $ $x=0$
$\displaystyle y-2 = -3(x-0) \\$
$\text{b) given that } \displaystyle g(0)=4, \\
\text{ write an equation of the line tangent of}
$g$
\text{at the point where }
\textit{x=0} \\$
$\displaystyle m_g=g'(0)=(1)[(3\cdot2)+2(0)]=6 \\
y-4=6(x-0)$
Was not sure about $g$ ??
For part b), check the slope of the tangent line. :)
FAQ: 10) AP Calculus linear functions
What is a linear function in AP Calculus?
A linear function in AP Calculus is a function that can be represented by a straight line on a graph. It has the form f(x) = mx + b, where m is the slope of the line and b is the y-intercept. The slope represents the rate of change of the function and the y-intercept is the value of the function when x = 0.
How do you find the slope of a linear function in AP Calculus?
The slope of a linear function in AP Calculus can be found by calculating the change in y divided by the change in x. This is also known as rise over run. In the function f(x) = mx + b, the slope is represented by the value of m.
What is the difference between a linear function and a non-linear function in AP Calculus?
The main difference between a linear function and a non-linear function in AP Calculus is the shape of their graphs. A linear function will always have a straight line, while a non-linear function will have a curved or non-straight line. Additionally, a linear function will have a constant rate of change, while a non-linear function will have a changing rate of change.
How do you graph a linear function in AP Calculus?
To graph a linear function in AP Calculus, you can plot at least two points on the line and connect them with a straight line. These points can be found by choosing different values for x and solving for the corresponding values of y using the function. You can also use the slope and y-intercept to graph the line.
What are some real-life applications of linear functions in AP Calculus?
Linear functions are used in various real-life applications, such as calculating the cost of a cell phone plan based on minutes used, determining the growth rate of a population, and predicting the trajectory of a moving object. They are also commonly used in economics and finance to analyze trends and make predictions.
