100MW reactor must produce a 110MW
  • Thread starter EinsteinII
  • Tags
    Reactor
In summary, a Hollywood movie showed a reactor officer being asked to push a nuclear submarine's reactor to give 110% of its capacity, which is typically not possible in nuclear power plants due to safety concerns. However, it is possible to temporarily exceed the normal limit by withdrawing control rods or reducing soluble boron in the coolant. This can lead to faster degradation of the reactor and other components, but not a meltdown as it would be detected and prevented by the reactor officer. The exact meltdown threshold varies for each reactor. Some reactors in the US have been uprated by 5-20% of their original full power rating, but this requires modifications to the plant and is not a common
EinsteinII
35
Watched a scene from a Hollywood movie where the Captain of a Nuclear submarine asks his Reactor officer to give him a 110% of his reactor. That means a 100MW reactor must produce a 110MW.
How is that increased? Is that simply by pulling off control rods or is there any other way? Whats the threshold by the way?
http://en.wikipedia.org/wiki/Rocket#Net_thrust
A typical rocket engine can handle a significant fraction of its own mass in propellant each second, with the propellant leaving the nozzle at several kilometres per second. This means that the thrust-to-weight ratio of a rocket engine, and often the entire vehicle can be very high, in extreme cases over 100.
Was that an answer to my question?
1. Hollywood script writers say anything.
2. Real rockets can get more than 100% thrust.
Devils,
My brother is an officer on board a nuclear submarine and he says that actually is a possible thing! Can you explain me how is that not possible in a nuclear reactor's case?
This is about nuclear power, not rocket thrust.
EinsteinII said:
Devils,
Nuclear reactors can have their output varied by putting control rods in or pulling them out. Since control rods absorb neutrons, pulling them out let's those neutrons that would have been absorbed hit the fuel instead and cause another fission reaction. I assume that the reactor and powerplant of the submarine can handle going above "normal" limits if need be, but it probably leads to much faster degradation of the reactor and other components than normal. Obviously pushing the reactor too high will lead to extreme danger and likely damage the reactor and possibly cause a meltdown if you go too high or for too long.
Reactors may have margin to failure limits such that they can realize 110% during a short period. It is a simple matter to increase power by withdrawing control rods (if control rods are actively used in the core for reactivity control) or soluble boron in the coolant is reduced. This is not common practice.
Besides the reactor, the heat exchangers and steam turbines must be able to handle the extra power/energy.
Thank you very much sir,
I was confused when Devils answered me, but again thought he might have a point there. My brother's answer was the same though ruled out a meltdown because reactor officer will warn the captain about it but faster degradation of fuel is obvious.
Thank you again Sir.
Can anyone tell me what's the meltdown threshold of a reactor. Or at least a link to refer this subject.
It's the only way you're going to get over unity in this argument. Otherwise you are talking about perpetual motion.
If some arbitrary process is running "greater than 100%", say 102%, then its 102% of what?
There is no over unity or perpetual motion here. Such things do not exist. End of story.
Of standard operating maximum due to the design of the reactor. Anything beyond 100% is considered above normal and is likely to vastly increase the chances of something breaking. For example, my trucks engine is limited to around 6,000 RPM. I can, if I want to, remove the limiter and rev my engine even higher, however the further I get above 6,000 RPM the greater the chance of something flying apart inside it. I might reach 7,000 or even 8,000 RPM but my engine is likely to break.
As Drakkith iindicated, the 100% refers to a 'normal' rated thermal power (or full power).
Many reactors in the US have been uprated between 5 and 20% of their original full power ratings. It usually required modifications to the balance of plant, and some modifications to the primary system (e.g., increased flow) and core design. The core can be designed to reduce power peaking both in the axial and radial directions.
One thing to realize with nuclear plants, is that we run our reactors such that during worst case conditions, the reactor is still safe.
This means, you can run the reactor at higher power levels and tighter thermal limits, but risk unacceptable accident conditions.
So an example of this, and I'm going to use a large BWR I've worked at as an example. The critical power ratio (CPR) is required to be above 1.09 at all times during that plant's operation. This is a safety limit on the reactor. The operating limit critical power ratio in our plant is around 1.47. What we did, is we looked at every accident that affects critical power ratio, and we found the worst case one to be around .38. We then added that to the minimum critical power ratio (MCPR 1.09) and came up with a limit for normal operation. So what that means, is if I keep my reactor's critical power ratio above 1.47 at all times during NORMAL operation, then during accidents it will never go below our safety limit. On the flip side, I theoretically could operate the plant BELOW 1.47, with no problems or issues to the core, BUT if an accident happens, I risk violating my safety limit and potentially causing unacceptable damage to the fuel during an accident.
In a nuclear submarine, these risks are weighed, and there are calculations and analysis that allow for this for some period of time as well. The maximum power in a nuclear power reactor is almost always limited by thermal limits (maximum capacity of heat exchangers or heat removal from the fuel), and is almost never limited by the core itself. If you were to keep pulling rods, diluting boron, and increasing cooling flow or subcooling, you will keep pushing power up. The maximum limit is definitely over 100%. Power reactors have pre-programmed trip limits on overpower. A large commercial BWR will have a system (APRM - Average Power Range Monitors) that automatically scrams if the reactor is ever over about 118% power, and can not be overridden. Additionally if there is not enough cooling for the current power level for more than a few seconds, the reactor will automatically scram as well. Sub reactors have similar systems (which may be overridden during battle situations).
tl;dr you can easily push reactor power up by diluting boron or pulling rods (or some other reactivity insertion mechanism), but will either be pushing your thermal limits, or pushing the limits on your emergency trip/scram settings.
Can you also increase the output of the reactor by lowering the water temperature? Ie, by drawing energy off faster with those heat exchangers? Heat exchangers are designed for adverse conditions (warmer cooling water) and if the cooling water is unusually cold, you can pull more heat from a heat exhchanger than it is designed for. Similarly, I would think you can over-rev a turbine (not certain) by putting more electrical load on the generator -- for example by increasing the RPM or prop pitch of the propulsion system.
For a PWR, if you increase the steam extraction from the steam generators (either through increasing turbine load, opening a steam relief valve or PORV, or opening turbine bypass valves, for example), this will remove more steam from the generator, and effectively increases the heat removal from the primary cooling loop. This increase in effective cooling causes lower temperature water to enter the reactor. Due to negative temperature coefficients of reactivity for most operating states of a PWR, decreasing inlet temperature will increase reactor power.
There are limits to this though. Increasing the power in this way affects thermal limits. To protect the fuel, all plants have some type of thermal limit, and many plants have a "Delta-T" interlock which will trip the reactor if the hotleg and coldleg temperatures are too far apart, OR they may have a power-flow imbalance trip where if power is greater than flow allows a trip will occur.
For a BWR, if you increase effective heat removal by making the turbine draw more steam, you have the OPPOSITE effect. An increase in steam removal causes the pressure in the reactor to decrease, which in turn increases the amount of voiding in the core (remember BWRs operate at saturated steam conditions and temperature is a function of pressure). BWRs have negative void coefficients for virtually all operating modes, and as a result, an increase in voiding results in a decrease in power. This will also challenge thermal limits as well (mainly critical power ratio CPR), however BWRs typically are capable of operating with no forced cooling flow (natural flow is enough), but their power will be limited by lack of cooling flow. Additionally during high power/low flow conditions (typically less than 60% flow and greater than 40% power), you run the risk of core thermalhydraulic oscilliations, causing power in the core to oscillate with a very specific frequency (in the 1-2 second range). All BWRs have OPRM (Oscillating power range monitors) which detect these oscillations and will automatically scram the reactor if they are present, and most, if not all plants, have procedures to manually scram the reactor upon entering the region where core oscillations are known to exist.
The control systems between PWR and BWR turbines are different as well. PWR turbine control systems typically operate in the load-set mode. In this mode, you tell the turbine how much steam it is allowed to draw, and that sets the electrical power being generated. If too much steam is suddenly available the bypass valves will lift automatically to limit the pressure increase. To make power changes, you dial in a load-set targer power, and a rate of change. When you enter this in, the turbine will ramp at the specified rate to the new power level.
A BWR CAN operate in the load set mode, and typically is for turbine startup/shutdown and special operations, but normally BWRs operate in the "Pressure Control" mode. In this mode, the operators tell the turbine what reactor pressure they want to maintain, and the turbine will only draw the amount of steam required to maintain that pressure. This means, if you increase reactor power through some method (control rods or cooling flow), the turbine will automatically follow the reactor power increase and increase its power output as well. There is no need to change the load set when you change reactor power, as the turbine will automatically adjust to the new power level.
tl;dr - In a PWR, the reactor follows the turbine load. For a BWR, the turbine follows the reactor.
Other ways to change power in BWRs include subcooling and forced cooling flow. Subcooling is how cold the water entering the core is. You can make the water colder by taking feedwater heaters out of service. You have to take penalties to your core thermal limits to do so, and US plants will only do this at the end of cycle to extend the fuel cycle a couple weeks. The other way to change power in a BWR (and is used from roughly 40% power up to 100% power), is to increase forced cooling flow in the reactor. The reactor recirculation pumps drive jet pumps in the core (except BWR/2 plants, where the recirc pumps directly cool the core). As you increase the jet pump drive flow, it 'pushes' more water through the core and pushes steam out of the core faster. This effectively decreases your void coefficient and increases inlet subcooling. The core will respond by increasing thermal output, until it starts boiling the new volume of water fast enough to return it to equilibrium boiling conditions.
Thank you very much Gentlemen!
the reactor is not like a gasoline engine, ie limited by a its fuel flow to a relatively fixed output. Its fuel is 100% there,built in, and control systems determine at what rate it burns hence energy conversion progresses.
Designers build in natural thermal feedbacks to make a gross limit on power
but for fine control rods are used.
A typical commercial PWR would have control systems that stop rod withdrawal around 102% or 103% rated poweras measured by neutron detectors , and would drop them all in(trip reactor is the tern we use) at about 108%-110% on presumption something is awry.
There's also systems that infer power from temperature rise across core and trip reactor should it reach the 107%-110% range by thermal measurement.
So most reactors could do 110% if allowed to, but we don't hot-rod them.old jim
These are good questions.
Let me just point out that a naval nuclear power plant (primarily for propulsion) operates a bit differently than a commercial power plant (for electrical generation and contrained to a 60 Hz grid in the US or 50 Hz in Europe and other countries).
To get more efficiency out of a nuclear power plant one either raises the hot temperature to the high pressure turbine, or reduces the cold temperature in the condenser, after discharge from the LP turbine. When the cooling water is warmer, the turbines are slightly less efficient.
Generally reactors are contrained by cladding surface temperatures on the fuel. The higher the temperature the higher the corrosion (cladding oxidation). There is also a concern about nucleate boiling in PWRs, since that is where crud likes to deposit, and that can (and has in rare cases) lead to fuel failure (water chemistry, e.g., pH and Ni content is usually the other factor). The hot coolant temperature is usually limited because corrosion of steam generator materials (which is usually the main source of crud species). Lower cooling water temperature at the condenser is a preferred way to get more efficiency, but it's usually a fraction of a percent.
Commercial plants must produce electricity at 60 Hz or 50 Hz, to large turbines run at 1800 rpm (60 Hz) or 1500/3000 rpm (50 Hz), and there is little variation.
Reducing core inlet temperature, but reducing feedwater temperature can increase reactivity in the core, and this can be used toward end of cycle to get a little more energy out of the core - but that doesn't so much increase the thermal efficiecy of the plant.
Some plants have replaced their turbines with more efficient turbines, with advanced blade geometry and improved sealing between stages. This can boost efficient 1 to 2%, as has been the case at some German plants. The best PWRs are about 36 to 37% efficient, from a combination of slightly higher hot temperature in conjunction with more efficient turbines.
As far as I know, naval plants aren't as constrained as commercial plants.
Related to 100MW reactor must produce a 110MW
1. How is it possible for a 100MW reactor to produce 110MW?
The answer to this question lies in the concept of efficiency. A 100MW reactor may have an efficiency of 90%, meaning that it can convert 90% of its fuel into usable energy. Therefore, the reactor can produce 90MW of energy. If the efficiency is increased to 110%, the reactor can produce 110MW of energy.
2. What is the difference between a 100MW and a 110MW reactor?
The main difference between these two reactors is their power output. A 100MW reactor can produce 100 million watts of energy, while a 110MW reactor can produce 110 million watts of energy. This difference is due to the design and efficiency of the reactors.
3. Can a 100MW reactor be upgraded to produce 110MW?
Yes, it is possible to upgrade a 100MW reactor to produce 110MW. This can be achieved by improving the efficiency of the reactor through technological advancements or modifications to its design. However, it may require significant investments and expertise.
4. What are the benefits of a 110MW reactor over a 100MW reactor?
The main benefit of a 110MW reactor is its increased power output. This means that it can generate more energy and meet higher demands. Additionally, a more efficient reactor can also lead to cost savings and a reduced environmental impact.
5. Are there any potential challenges in building a 110MW reactor?
Building a 110MW reactor may present some challenges, especially in terms of its design and safety regulations. The reactor must be able to handle the increased power output and operate safely. Additionally, it may also require significant resources and expertise to construct and maintain a 110MW reactor.
  • Nuclear Engineering
  • Art, Music, History, and Linguistics
  • General Discussion
