MHB 11.1 Determine if the polynominal.... is the span of (....,....)
  • Thread starter Thread starter karush
    Span
karush
MHB
Determine if the polynomial
$3x^2+2x-1$
is the $\textbf{span}\{x^2+x-1,x^2-x+2,1\}$ok from examples it looks like we see if there are scalars such that
$c_1(x^2+x-1)+c_2(x^2-x+2,1)=3x^2+2x-1$so far not sure how this is turned into a simultaneous eq
I did notice that it is common to get over 100 views on these DE problems
so thot it would be good to show sufficient steps
It should be
$$c_1(x^2+x-1)+c_2(x^2-x+2)+c_3\ \equiv\ 3x^2+2x-1$$
Expand out the LHS and compare coefficients. This will give you a system of equations in $c_1,c_2,c_3$. If the system is consistent (i.e. has at least one solution) then the given polynomial is in the given span, otherwise not.
https://www.physicsforums.com/attachments/9043
ok here is an example but I don't see how they got the numbers"
That solution is for the problem of determining if this polynomial
$$2x^2+x+1$$
is in $\mathrm{Span}\{x^2+x,x^2-1,x+1\}$.
In your OP, you have this:
so comparing coefficients of $x^2$, $x$ and the constant terms should give you
$$\begin{array}{rcrcrcr}c_1 & +&c_2 && &=& 3 \\ c_1 &-&c_2 && &=& 2 \\ c_1 &+&2c_2 &+&c_3 &=& -1\end{array}.$$
$c_1(x^2+x-1)+c_2(x^2-x+2)+c_3\ \equiv\ 3x^2+2x-1$ok I got ...\begin{array}{rcrcrcr}c_1 & +&c_2 && &=& 3 \\ c_1 &-&c_2 && &=& 2 \\ -c_1 &+&2c_2 &+&c_3 &=& -1\end{array}
could we multiply thru the $R_3$ with -1
well anyway got this ...
$\left[ \begin{array}{ccc|c} 1 & 0 & 0 & \frac{5}{2} \\ 0 & 1 & 0 & \frac{1}{2} \\ 0 & 0 & 1 & - \frac{9}{2} \end{array} \right]$
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
