MHB 12.4.9 - Area of a triangle given points in 3D space
The discussion focuses on calculating the area of a triangle defined by three points in 3D space using vector cross products. The vectors PQ and PR are derived from the given points, and their cross product is computed to find the area. There are some concerns about notation and sign errors in the calculations, which are acknowledged and corrected. A suggestion to use Heron's formula for a potentially simpler calculation is mentioned, but the original method is emphasized due to homework requirements. The area is ultimately confirmed to be half the magnitude of the cross product, leading to the final result of \(\frac{\sqrt{4773}}{2}\).
karush
MHB
$\textsf{Find the area of the triangle determined by the points }$
\begin{align*}\displaystyle
&P(1,1,1), \, Q(-2,-7,-1), \, R(-7,-1,4)\\
\end{align*}
\vec{PQ}&=(-2-1)i&+(-7-1)J&+(-1-1)k&=-3i-8j-2k\\
\vec{PR}&=(-7-1)i&+(-1-1)j&+(4-1) k&=-8i-2j-3k
\end{align*}
\vec{PQ} \times \vec{PR}&=
\begin{vmatrix}
i&j&k\\-3&-8&-2\\-8&-2&3
\end{vmatrix}\\
\begin{vmatrix}
-8&-2\\-2&3
\end{vmatrix}i-
\begin{vmatrix}
-3&-2\\-8&3
\end{vmatrix}j-
\begin{vmatrix}
-3&-8\\-8&-2
\end{vmatrix}k\\
&=(-24-4)i-(-9-16)j+(6-64)k\\
&=-28i+25j-58k\\
&=\sqrt{28^2 + 25^2 + 58^2}\\
&=\sqrt{4773}
\end{align*}
$\textit{divide by half to obtain area of triangle}$
$\displaystyle \frac{\sqrt{4773}}{2}$
I just followed an example but was unsure about the signs in between matrix
and suggestions ?
Re: 12.4.9 area of a triangle given points in 3D space
\end{align*}
\end{align*}
\begin{vmatrix}
\end{vmatrix}\\
\begin{vmatrix}
-8&-2\\-2&3
\end{vmatrix}i-
\begin{vmatrix}
-3&-2\\-8&3
\end{vmatrix}j-
\begin{vmatrix}
-3&-8\\-8&-2
\end{vmatrix}k\\
&=-28i+25j-58k\\
&=\sqrt{4773}
\end{align*}
and suggestions ?
$\displaystyle \begin{align*} \vec{PR} = \left( -8, -2, 3 \right) \end{align*}$, not $\displaystyle \begin{align*} \left( -8, -2, -3 \right) \end{align*}$ as you wrote, but since you have used the correct vector in your calculation of the cross product, I expect this is just a typo.
Also, the area is $\displaystyle \begin{align*} \frac{1}{2} \left| \vec{PQ} \times \vec{PR} \right| \end{align*}$, which you actually calculated, but you wrote $\displaystyle \begin{align*} \frac{1}{2} \left( \vec{PQ} \times \vec{PR} \right) \end{align*}$. PLEASE be careful with your notation!
thanks for the catch
yes easy sign error typos on these
Still got 5 more vector probs to do :cool:
where did I write this?
\end{align*}$
It might be simpler to do this using "Heron's formula": If the lengths of the three sides of a triangle are a, b, and c, then the area of the triangle is \sqrt{s(s- a)(s- b)(s- c)} where "s" is the "half perimeter"- s= (a+ b+ c)/2.
probably so but it was a homework assignment on this method.
There are probably loads of proofs of this online, but I do not want to cheat. Here is my attempt: Convexity says that $$f(\lambda a + (1-\lambda)b) \leq \lambda f(a) + (1-\lambda) f(b)$$ $$f(b + \lambda(a-b)) \leq f(b) + \lambda (f(a) - f(b))$$ We know from the intermediate value theorem that there exists a ##c \in (b,a)## such that $$\frac{f(a) - f(b)}{a-b} = f'(c).$$ Hence $$f(b + \lambda(a-b)) \leq f(b) + \lambda (a - b) f'(c))$$ $$\frac{f(b + \lambda(a-b)) - f(b)}{\lambda(a-b)}...
