~12mm EP and a barlow or just one good ~6mm EP
  • Thread starter QuantumPion
In summary, a 12mm EP (eyepiece) and a barlow are both optical accessories used in telescopes to increase magnification. The main difference is that a barlow is an additional lens while a 6mm EP is simply a different focal length eyepiece. Both options have their advantages, with a 12mm EP with a barlow providing higher magnification for smaller and distant objects, and a 6mm EP providing a wider field of view for larger objects. It is possible to use a barlow with a 6mm EP, but it may decrease image quality and brightness. The best option depends on the specific object being viewed and personal preferences. Experimentation is recommended to determine the best choice for a
QuantumPion
42
I'm trying to keep my EP budget around ~$120 for now. I can't decide between getting a ~12mm EP and a barlow or just one good ~6mm EP. I'm thinking about getting a Baader Planetarium Hyperion, but can't decide between 5, 8, 10 or 13mm and/or barlow to go with it.
Astronomy news on Phys.org
You may wish to peruse ebay, as well. You can usually find a variety of both planetary and wide field eyepieces that are relatively inexpensive.
FAQ: ~12mm EP and a barlow or just one good ~6mm EP
What is the difference between a 12mm EP and a barlow or a 6mm EP?
A 12mm EP (eyepiece) and a barlow are both optical accessories used in telescopes to increase magnification. The main difference is that a barlow is an additional lens that is placed between the eyepiece and the telescope, while a 6mm EP is simply a different focal length eyepiece. A 12mm EP with a barlow will provide a higher magnification than a 6mm EP alone.
Which option is better for viewing celestial objects, a 12mm EP with a barlow or a 6mm EP?
Both options have their advantages. A 12mm EP with a barlow will provide a higher magnification, making it better for viewing smaller and more distant objects such as planets or star clusters. On the other hand, a 6mm EP will provide a wider field of view, making it better for viewing larger objects such as galaxies or nebulae.
Can I use a barlow with a 6mm EP?
Yes, you can use a barlow with any eyepiece, including a 6mm EP. This combination will provide an even higher magnification than using a 6mm EP alone.
Are there any downsides to using a barlow with an eyepiece?
One potential downside is that using a barlow can decrease the overall image quality, as it introduces an additional element into the optical path. Additionally, using a barlow can also decrease the amount of light reaching your eye, resulting in a dimmer image.
How do I choose between a 12mm EP with a barlow or a 6mm EP?
The best option will depend on the specific object you are viewing and your personal preferences. If you are primarily interested in viewing smaller and more distant objects, the higher magnification of a 12mm EP with a barlow may be better. If you prefer a wider field of view and want to view larger objects, a 6mm EP may be the better choice. It's always a good idea to experiment with both options to see which one works best for your specific telescope and viewing conditions.
