MHB 15.2.66 Solve by reversing the reversing the order of integration
  • Thread starter Thread starter karush
    Integration
karush
MHB
solve by reversing the reversing the order of integration
this was given:
\begin{align*}\displaystyle
I&=\int_0^8 \int_{\sqrt[3]{x}}^2
\left[\frac{x}{y^7+1}\right]dy \, dx\\
\end{align*}
ok I put this in an dbl int calculor but it turned the order around to
I&=\int_{\sqrt[3]{x}}^2 \int_0^8
\end{align*}
Re: 15.2.66 solve by reversing the reversing the order of integration
So what's your question? :)
this was given:
\end{align*}
I would begin by plotting the region over which we are to integrate:
The integral as given is using vertical strips...and we need to use horizontal strips instead.
In order to reverse the order of integration, we need to observe that we have:
$$0\le x\le y^3$$...the upper limit was obtained from $y=\sqrt[3]{x}$...
$$0\le y\le 2$$
And so we have:
$$I=\int_0^2\int_0^{y^3}\frac{x}{y^7+1}\,dx\,dy$$
Now you will be able to integrate...can you continue?
we got
$\frac{\ln\left({129}\right)}{14}$
karush said:
we got
Yes:
$$I=\int_0^2\int_0^{y^3}\frac{x}{y^7+1}\,dx\,dy=\int_0^2\frac{1}{y^7+1}\int_0^{y^3}x\,dx\,dy=\frac{1}{2}\int_0^2\frac{1}{y^7+1}\int_0^{y^3}\left[x^2\right]_0^{y^3}\,dy$$
$$I=\frac{1}{2}\int_0^2\frac{y^6}{y^7+1}\,dy=\frac{1}{14}\int_0^2\frac{7y^6}{y^7+1}\,dy=\frac{1}{14}\int_1^{129}\frac{1}{u}\,du=\frac{1}{14}\left[\ln(u)\right]_1^{129}=\frac{1}{14}\ln(129)$$
For original Zeta function, ζ(s)=1+1/2^s+1/3^s+1/4^s+... =1+e^(-slog2)+e^(-slog3)+e^(-slog4)+... , Re(s)>1 Riemann extended the Zeta function to the region where s≠1 using analytical extension. New Zeta function is in the form of contour integration, which appears simple but is actually more inconvenient to analyze than the original Zeta function. The original Zeta function already contains all the information about the distribution of prime numbers. So we only handle with original Zeta...
