*15.4.17 Volume between a cone and a sphere
In summary, the volume of the given solid region is bounded BELOW by the cone and bounded ABOVE by the sphere, and the maximum circle of radius 8 units is located at the origin.
karush
MHB
3,269
$\tiny{15.4.17}$
Find the volume of the given solid region
bounded below by the cone $z=\sqrt{x^2+y^2}$
and bounded above by the sphere $x^2+y^2+z^2=128$
using triple integrals
$\displaystyle\int_{a}^{b}\int_{c}^{d} \int_{e}^{f} \,dx\,dy \,dz$
not real sure where to to start with this?
Re: 15.4.17 volume between a cone and a sphere
karush said:
$\tiny{15.4.17}$
Bounded ABOVE by $\displaystyle \begin{align*} x^2 + y^2 + z^2 = 128 \implies z = \sqrt{128 - \left( x^2 + y^2 \right) } \end{align*}$ and bounded BELOW by $\displaystyle \begin{align*} z = \sqrt{x^2 + y^2} \end{align*}$ means $\displaystyle \begin{align*} \sqrt{ x^2 + y^2 } \leq z \leq \sqrt{ 128 - \left( x^2 + y^2 \right) } \end{align*}$.
Now we need to determine how far out we go in each direction in the x-y plane. Notice that each cross-section parallel to the x-y plane is a full circle, and the maximum circle will be where the cone and sphere intersect, so where:
$\displaystyle \begin{align*} 128 - \left( x^2 + y^2 \right) &= x^2 + y^2 \\ 128 &= 2 \left( x^2 + y^2 \right) \\ 64 &= x^2 + y^2 \end{align*}$
So the maximum circle is of radius 8 units centred at the origin.
It would be easiest to do this triple integral in cylindrical polar co-ordinates, so with $\displaystyle \begin{align*} 0 \leq r \leq 8 \end{align*}$ and $\displaystyle \begin{align*} 0 \leq \theta \leq 2\,\pi \end{align*}$, so your z boundaries are $\displaystyle \begin{align*} r \leq z \leq \sqrt{128 - r^2} \end{align*}$ and your triple integral is
$\displaystyle \begin{align*} V &= \int_0^{2\,\pi}{\int_0^8{\int_r^{\sqrt{128 - r^2}} r\,\mathrm{d}z \,\mathrm{d}r }\,\mathrm{d}\theta} \end{align*}$
thanks that was really a great help
much mahalo...
FAQ: *15.4.17 Volume between a cone and a sphere
What is the formula for finding the volume between a cone and a sphere?
The formula for finding the volume between a cone and a sphere is (1/3)πr2h + (4/3)πr3, where r is the radius of the sphere and h is the height of the cone.
How do you determine the radius and height of the cone and sphere?
The radius and height of the cone and sphere can be determined by using the given measurements or by measuring them directly using a ruler or measuring tape.
Can the volume between a cone and a sphere be negative?
No, the volume between a cone and a sphere cannot be negative. Volume is a measure of space and cannot have a negative value.
What are the units for the volume between a cone and a sphere?
The units for the volume between a cone and a sphere will depend on the units used for the radius and height of the cone and sphere. The most common units are cubic centimeters (cm3) or cubic meters (m3).
Can the volume between a cone and a sphere be greater than the volume of the sphere itself?
Yes, it is possible for the volume between a cone and a sphere to be greater than the volume of the sphere itself. This will depend on the size and dimensions of the cone and sphere.
