-16(2a) -> How to isolate variable?
  • Thread starter Nano-Passion
  • Tags
    Variable
In summary, the attempt at a solution is to set a equal to 0 in order to avoid a violation of some basic arithmetic law. However, this solution does not work as intended and ends up giving a different answer to the question.
Nano-Passion
1,291
-16(2a) --> How to isolate variable?
-16(2a)
How do I isolate the variable? This is probably an EXTREMLY simple question. Its times like this that makes me wish I paid attention in high school algebra.
Don't really know what to do without violating some basic arithmetic law.
I tried setting it equal to 0 but??
-32a = 0
My professor got the answer of [tex]a=\frac{5\sqrt{5}}{2} [/tex]
Is there an equation associated with this?
In any case, you can simplify a little more. Use the associative law. For any real numbers x,y,z:
x(yz) = (xy)z
What's x? y? z?
x(yz) = (xy)z
What's x? y? z?
I did that, maybe it wasn't very noticiable in my post. Regardless,
-16(2a) = -32a
Edit: No equation, just part of a word problem in my calc class. This is the very last step, just don't know how to solve for a. I have the problem copied from my professor so it isn't an error.
With the information given, there's no way to properly answer your question. What's the original problem?
Given the position function, [tex] s(t)= -16t^2 + 500[/tex]
If a construction worker drops a wrench from a height of 500
feet, when will the wrench hit the ground? At what velocity
will the wrench impact the ground?
[tex]lim_{t\to a} \frac{s(a) - s(t)}{a-t} = \frac{-16at^2 + 500 - (16t^2 + 500 )} {a-t}[/tex]
[tex]= \frac{-16a^2+16t^2}{a-t}[/tex]
[tex]= \frac{-16(a^2 - t)}{a-t} = \frac{-16 (a+t)(a-t)}{a-t}[/tex]
[tex]= lim_{t\to a} = -16(a+t) [/tex]
[tex]= - 16(2a)[/tex]
Professor said a = t, and set (a+t) is the same thing as 2a.
(1) Did you answer this question? If not, when the wrench hits the ground, what does s(t) have to equal? You need to then solve for t.
I learned the formula as this:
[tex]s'(a) = lim_{t\to a} \frac{s(t) - s(a)}{t-a}[/tex]
Nano-Passion said:
Professor said a = t, and set a = 2.
You sure? The a = 2 part isn't right. What you should plug in is the value of t you get from (1) above.
Like eumyang stated, there's two parts to this question. First, you need to find the time at which the wrench hits the ground. How do you do this?
Ignoring the latex typos, your methodology for solving for the velocity is fine. However, you need to approach the time at which the wrench hits the ground. If you properly solve for this time, you won't get 2.
I'm sorry, that was a typo, what I really meant was [tex]\lim_{t\to a} (t+a) = 2a[/tex]
So when I said a = 2, I meant since t approaches a its the same as 2a. I've been studying and practicing for a while, sometimes you get clumsy.
I'm sorry that was a typo, read the above post.
There are quite a few mistakes here.
The first question is the same as asking at what t is s(t) = 0? When you answer that question, you should get the same answer as you posted, which is (5[itex]\sqrt{5}[/itex])/2.
It looks like you skipped that question and went on to try to answer the second question.
s(a) [itex]\neq[/itex] -16at2 + 500.
Since you actually take the limit in the last expression above, each step preceding it should indicate that you haven't yet taken the limit. IOW, Each expression except the very last should be preceded with [itex]\lim_{t \to a}...[/itex].
Actually, since what you're really doing is finding s'(t), each limit shoud have been [itex]\lim_{a \to t}...[/itex].
BTW, as already noted by other folks in this thread there are a couple of errors in the work above.
What you have found here is s'(t), or the velocity at time t for the dropped wrench. You should have found that v(t) = -32t. If you had answered the first question, you could have used that value to find the velocity when the wrench hit the ground.
Oh my... I was so fixated on figuring out how my professor solved for a, it crossed my mind to flip a page back for the other portion.:
[tex]-16t^2+500=0[/tex]
[tex]-16t^2= -500[/tex]
[tex]\sqrt{t^2}= \frac{\sqrt{125}}{\sqrt{4}}[/tex]
I probably need a break lol..
FAQ: -16(2a) -> How to isolate variable?
What does it mean to isolate a variable?
Isolating a variable means to rewrite an equation so that the desired variable is on one side of the equals sign by itself, with all other terms on the other side.
How do I isolate a variable in an equation?
To isolate a variable, you need to use inverse operations to cancel out any other terms or factors that are attached to the variable. This can include addition, subtraction, multiplication, and division.
Can you provide an example of isolating a variable in an equation?
Sure, let's look at the equation -16(2a) = 32. To isolate the variable "a", we first need to divide both sides by -16, giving us 2a = -2. Then, we can divide both sides by 2 to get the final answer of a = -1.
What is the purpose of isolating a variable?
Isolating a variable allows us to solve for that specific variable and find its value in an equation. This is useful when trying to solve for unknown quantities or when simplifying complex expressions.
Are there any tips or tricks for isolating variables in equations?
One helpful tip is to always perform the inverse operation on both sides of the equation to maintain balance. It can also be useful to work backwards, starting with the variable you want to isolate and working backwards through the inverse operations to the original equation.
