-17.2.0 Solve y''+7y'+10y=80 by undetermined coefficients.
In summary, the given equation is solved by finding the auxiliary equation and determining the roots. The homogeneous solution is given by $y_h=c_1e^{-5x}+c_2e^{-2x}$. The particular solution takes the form $y_p=A$, and upon substitution, we find that $A=8$, giving us the general solution $y(x)=c_1e^{-5x}+c_2e^{-2x}+8$.
karush
MHB
3,269
$\tiny{17.2.0}$
$\textrm{ Solve the given equation by the method of undetermined coefficients.}$
\begin{align*}\displaystyle
y''+7y'+10y&=80\\
\end{align*}
$\textrm{auxilary equation}$
r^2+7r+10&=0\\
(r+2)(r+5)&=0\\
r&=-2,-5
\end{align*}
then is it the general equation?
this is the last one of the undetermined coefficients problems
You have correctly identified the auxiliary roots...so:
a) What is the homogeneous solution $y_h$?
b) What form will the particular solution $y_p$ take?
\begin{align*}\displaystyle y''+7y'+10y&=80\\\end{align*}
r^2+7r+10&=0\\
(r+2)(r+5)&=0\\
r&=-2,-5
\end{align*}
$y_h=c^{-5x}+c^{-2x}+8$
$y_p=Ax^2+Bx + 8$
I think?
r^2+7r+10&=0\\
(r+2)(r+5)&=0\\
r&=-2,-5
\end{align*}
I think?
What we would have is:
\(\displaystyle y_h(x)=c_1e^{-5x}+c_2e^{-2x}\)
Okay, now what form will the particular solution take?
r^2+7r+10&=0\\
(r+2)(r+5)&=0\\
r&=-2,-5
\end{align*}
$y_h=c_1 e^{-5x}+c_2 e^{-2x}$
$y_p=A $
$y_p^´=0$
$y_p^{´´}=0$
Let's not get ahead of ourselves. :D To determine the form for the particular solution, we look at the RHS of the original ODE:
\(\displaystyle y''+7y'+10y=80\)
We see it (80) is a constant, and we also note that no term in the homogeneous solution is a constant, and so the particular solution takes the form:
\(\displaystyle y_p(x)=A\)
The particular solution will be a constant.
And thus:
\(\displaystyle y_p'(x)=0\)
\(\displaystyle y_p''(x)=0\)
Substituting into the ODE, what do we obtain?
$10y=80$
$y=10$
karush said:
$10y=80$
$y=10$
Upon substitution, we have:
\(\displaystyle 0+7(0)+10A=80\implies A=8\)
And so we have:
\(\displaystyle y_p(x)=8\)
And so our general solution is:
\(\displaystyle y(x)=y_h(x)+y_p(x)=c_1e^{-5x}+c_2e^{-2x}+8\)
And there's our 8...:D
I'm beside myself😎
If you think [tex]\frac{80}{10}= 10[/tex] you certainly are.
FAQ: -17.2.0 Solve y''+7y'+10y=80 by undetermined coefficients.
What is the purpose of using undetermined coefficients to solve this equation?
The method of undetermined coefficients is used to find a particular solution to a non-homogeneous linear differential equation. This allows us to find a specific function that satisfies the equation and can be added to the general solution of the corresponding homogeneous equation.
What is the general approach for solving a non-homogeneous linear differential equation using undetermined coefficients?
The general approach involves assuming a particular form for the solution, plugging it into the equation, and then solving for the undetermined coefficients. These coefficients are determined based on the form of the non-homogeneous term in the equation.
How do you determine the form of the particular solution for this equation?
In this equation, the non-homogeneous term is a constant, which suggests that the particular solution will be a constant function. Therefore, we can assume that the particular solution has the form y_p = A, where A is an unknown constant.
What is the process for finding the undetermined coefficients in the particular solution?
After plugging the assumed form of the particular solution into the equation, we can solve for the undetermined coefficients by equating coefficients of like terms on both sides of the equation. In this case, we will equate the constant term on the left side with the constant term on the right side (80 = A, so A = 80).
How do you find the complete solution to this differential equation using the method of undetermined coefficients?
The complete solution is found by adding the particular solution to the general solution of the corresponding homogeneous equation. In this case, the general solution is y = c_1e^{-2x} + c_2e^{-5x}, so the complete solution is y = c_1e^{-2x} + c_2e^{-5x} + 80.
