MHB -17.2.02 - Solve 2nd order ODE using undetermined coefficients.
karush
MHB
$\tiny{17.2.02}$
\nmh{1000}
$\textrm{Solve the equation by the method of undetermined coefficients.}\\$
\begin{align*}\displaystyle
y''-4y'&=\sin{x}\\
y_p&=A\sin{x}\\
\end{align*}
$\textit{ answer}$
y{\left (x \right )}& = C_{1} + C_{2} e^{4 x} - \frac{1}{17} \sin{\left (x \right )} + \frac{4}{17} \cos{\left (x \right )}
\end{align*}
ok not sure how to start this
looked at example but..
Okay the first thing we do is consider the solution $y_h$ to the corresponding homogeneous equation, namely:
$$y''-4y'=0$$
The characteristic/auxiliary equation is:
$$r^2-4r=r(r-4)=0\implies r\in\{0,4\}$$
Hence, we find:
$$y_h(x)=c_1e^{0x}+c_2e^{4x}=c_1+c_2e^{4x}$$
Next we look at the RHS of the given ODE, and from this we determine the particular solution will take the form:
$$y_p(x)=A\sin(x)+B\cos(x)$$
We need the first and second derivatives, so we compute:
$$y_p'(x)=A\cos(x)-B\sin(x)$$
$$y_p''(x)=-A\sin(x)-B\cos(x)$$
Next, we substitute $y_p$ into the ODE:
$$\left(-A\sin(x)-B\cos(x)\right)-4\left(A\cos(x)-B\sin(x)\right)=\sin(x)$$
Arrange as:
$$(-A+4B)\sin(x)+(-B-4A)\cos(x)=1\cdot\sin(x)+0\cdot\cos(x)$$
Equating coefficients, we obtain the system:
$$-A+4B=1$$
$$B+4A=0$$
Solving this system, we find:
$$(A,B)=\left(-\frac{1}{17},\frac{4}{17}\right)$$
And so we have:
$$y_p(x)=-\frac{1}{17}\sin(x)+\frac{4}{17}\cos(x)$$
And finally, by the principle of superposition, we may state the solution:
$$y(x)=y_h(x)+y_p(x)=c_1+c_2e^{4x}-\frac{1}{17}\sin(x)+\frac{4}{17}\cos(x)$$
Well that took the mystery out of
the textbook examples😎
Notice there is a lot views on these problems
so there is a lot of lateral benefits
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
