-17.2.05 by undetermined coefficients.
In summary: A-6B&=0\\ \displaystyle6B&=2/3\\ \displaystyle B&=1/9\end{align*}In summary, the auxiliary equation for the given ODE is $r^2+6r=0$. This results in the homogeneous solution $y_h=c_1e+c_2e^{-6x}$. The particular solution is found using the method of undetermined coefficients, leading to the expression $y_p=x\left(Ax+B\right)e^{-6x}$. By equating coefficients, we find that $A=-1/3$ and $B=1/9$. Therefore
karush
MHB
3,269
$\textrm{Solve the given equation by the method of undetermined coefficients.}$
\begin{align*}\displaystyle
y'' +6y'&=-4xe^{-6x}\\
y_p&=Ax^2e^{-6x}+Bxe^{-6x}
\end{align*}ok just wanted get this posted before I leave campus
so assume finding zeros is next
Yes, in order to get the general solution to the given ODE, you will need the homogeneous solution, and this involves finding the roots (zeroes) of the characteristic equation. :D
$\tiny{17.2.05}$
\end{align*}
$\textrm{So the auxiliary equation is}$
r^2+6r&=0\\ r(r+6)&=0\\ r&=0\\ r&=-6
\end{align*}
$\textrm{then}$
y_h&=c_1e^{0x}+c_2e^{-6x}=c_1e+c_2e^{-6x}\\
\end{align*}
is $y_p$ correct?
karush said:
$\tiny{17.2.05}$
\end{align*}
\end{align*}
$\textrm{then}$
\end{align*}
is $y_p$ correct?
You correctly found the characteristic roots, and so that means the homogeneous solution is:
\(\displaystyle y_h(x)=c_1e^{0x}+c_2e^{-6x}=c_1+c_2e^{-6x}\)
The mistake you made was in using $e^0=e$ when we actually have $e^0=1$ :D
Now, if we were not given the form for the particular solution, we would use:
\(\displaystyle y_p(x)=x^s\left(Ax+B\right)e^{-6x}\)
Since one of the terms of the homogeneous solution is $c_2e^{-6x}$, we need to let $s=1$ so that no term in the particular solution is in the homogeneous solution, and so we have:
\(\displaystyle y_p(x)=x\left(Ax+B\right)e^{-6x}\)
And this is equivalent to what you stated. Now you need to determine $A$ and $B$ using the method of undetermined coefficients.
y_p&=Ax^2e^{-6x}+Bxe^{-6x}\\
G(x)&=-4xe^{-6x}
\end{align*}
So
y_p(x)&=Ax^2+Bx+C\\
y_p^{'}& =2Ax+B\\
y_p^{''}& =2A
\end{align*}
substituting into the differential equation
$$(2A)+(2Ax+B)-2(Ax^2+Bx+C)=-4xe^{-6x}$$
got this from an example but ??
We have:
Using the general product rule for differentiation, we may state:
\(\displaystyle y_p'(x)=\left(Ax+B\right)e^{-6x}+Axe^{-6x}-6x\left(Ax+B\right)e^{-6x}=e^{-6x}\left(Ax+B+Ax-6x(Ax+B)\right)=\left(-6Ax^2+2(A-3B)x+B\right)e^{-6x}\)
And hence:
\(\displaystyle y_p''(x)=\left(-12Ax+2(A-3B)\right)e^{-6x}-6\left(-6Ax^2+2(A-3B)x+B\right)e^{-6x}=2\left(18Ax^2-6(2A-3B)x+A-6B\right)e^{-6x}\)
Now, you want to substitute for $y_p''$ and $y_p'$ into the ODE, and then continue with the process of using the method of undetermined coefficients. :D
karush said:
this ?
$y'' +6y'=-4xe^{-6x}$
$(-6Ax^2+2(A-3B)x+B)e^{-6x}+6[2(18Ax^2-6(2A-3B)x+A-6B)e^{-6x}]=-4xe^{-6x}$
Yes. :D
$$(-6Ax^2+2(A-3B)x+B)e^{-6x}+6[2(18Ax^2-6(2A-3B)x+A-6B)e^{-6x}]=-4xe^{-6x}\\
\textrm{expanded}$$
$$210Ae^{-6x}x^2-142Ae^{-6x}x+12Ae^{-6x}+210Be^{-6x}x-71Be^{-6x}
=-4e^{-6x}x$$
$$210Ax^2-142Ax+12A+210Bx-71B=-4x$$
I mistakenly told you "Yes" when I should have pointed out that you substituted incorrectly (sorry about that :eek:)...you should have:
\(\displaystyle 2\left(18Ax^2-6(2A-3B)x+A-6B\right)e^{-6x}+6\left(\left(-6Ax^2+2(A-3B)x+B\right)e^{-6x}\right)=-4xe^{-6x}\)
Divided through by $4^{-6x}$ since it cannot be zero:
\(\displaystyle 2\left(18Ax^2-6(2A-3B)x+A-6B\right)+6\left(\left(-6Ax^2+2(A-3B)x+B\right)\right)=-4x\)
Arrange both sides in standard form:
\(\displaystyle -12Ax+2A-6B=-4x+0\)
Okay, now what do you get when you equate coefficients?
karush said:
$\displaystyle-12Ax+2A-6B=-4x+0$\\
$\displaystyle x=0$\\
$\displaystyle 2A-6B=0$\\
$\displaystyle x=1$\\
$\displaystyle -12A+2A-6B=0$\\
$\displaystyle -10A-6B=4$
this doesn't look to good!
What you want to do is equate corresponding coefficients, like so:
\(\displaystyle -12A=-4\)
\(\displaystyle 2A-6B=0\)
Now you can uniquely determine $A$ and $B$...:D
When Karush set x= 0, he got the "constant terms", 2A- 6B= 0. When he set x= 1 he got the sum of the constant term and the coefficient of x, -10A- 6B= 4, effectively the same thing. I don't know why he says "this doesn't look too good".
Subtracting the second equation from the first, 12A= -4 so A= -1/3. Then 2A- 6B= -2/3- 6B= 0 so 6B= -2/3 and B= -1/9[FONT=MathJax_Main]−[/FONT][FONT=MathJax_Main]10[/FONT][FONT=MathJax_Math]A[/FONT][FONT=MathJax_Main]−[/FONT][FONT=MathJax_Main]6[/FONT][FONT=MathJax_Math]B[/FONT][FONT=MathJax_Main]=[/FONT][FONT=MathJax_Main]4[FONT=MathJax_Main]−[/FONT][FONT=MathJax_Main]10[/FONT][FONT=MathJax_Math]A[/FONT][FONT=MathJax_Main]−[/FONT][FONT=MathJax_Main]6[/FONT][FONT=MathJax_Math]B[/FONT][FONT=MathJax_Main]=[/FONT][FONT=MathJax_Main]4[/FONT][/FONT]
updated
$A=\frac{1}{3}$
$B=\frac{1}{9}$
so
$$\displaystyle
y_p=\frac{1}{3}x^2e^{-6x}+\frac{1}{9}x e^{-6x}$$
karush said:
I got
$A=-\frac{1}{3}$
$B=-\frac{1}{9}$
i was expecting integers
I got:
\(\displaystyle (A,B)=\left(\frac{1}{3},\frac{1}{9}\right)\)
And so, this would give me:
\(\displaystyle y_p(x)=x\left(\frac{1}{3}x+\frac{1}{9}\right)e^{-6x}=\frac{x}{9}(3x+1)e^{-6x}\)
Now, suppose I wish to check my answer, I would then compute:
\(\displaystyle y_p'=\frac{1}{9}(1-18x^2)e^{-6x}\)
\(\displaystyle y_p''=\frac{2}{3}(18x^2-6x-1)e^{-6x}\)
Now plug into the LHS of the original ODE and simplify to make sure we get the RHS of the original ODE:
\(\displaystyle \frac{2}{3}(18x^2-6x-1)e^{-6x}+6\left(\frac{1}{9}(1-18x^2)e^{-6x}\right)=\frac{2}{3}e^{-6x}\left(18x^2-6x-1+1-18x^2\right)=\frac{2}{3}e^{-6x}\left(-6x\right)=-4xe^{-6x}\quad\checkmark\)
So, we find this particular solution works. Check your algebra to find where you went wrong with the signs. :D
much mahalo
these are ? max problems
note
I had to repeatedly log in?
Here's an alternative approach to working the problem...we are given:
\(\displaystyle y''+6y'=-4xe^{-6x}\)
Let:
\(\displaystyle u=y'\implies u'=y''\)
And we have:
\(\displaystyle u'+6u=-4xe^{-6x}\)
Now, if we multiply through by an integrating factor of:
\(\displaystyle \mu(x)=e^{6x}\)
We obtain:
\(\displaystyle e^{6x}u'+6e^{6x}u=-4x\)
The LHS may now be rewritten as the differentiation of a product:
\(\displaystyle \frac{d}{dx}\left(e^{6x}u\right)=-4x\)
Integrate w.r.t $x$:
\(\displaystyle e^{6x}u=-2x^2+c_1\)
And so we have:
\(\displaystyle u=-2x^2e^{-6x}+c_1e^{-6x}\)
Back-substitute for $u$:
\(\displaystyle y'=-2x^2e^{-6x}+c_1e^{-6x}\)
\(\displaystyle y(x)=\int -2x^2e^{-6x}+c_1e^{-6x}\,dx=-2\int x^2e^{-6x}\,dx-\frac{1}{6}c_1e^{-6x}\)
Now, if we note that the factor in the second term of \(\displaystyle -\frac{1}{6}c_1\) is just an arbitrary constant, we may write:
\(\displaystyle y(x)=-2\int x^2e^{-6x}\,dx+c_2e^{-6x}\)
Now, on the remaining integral, let's use IBP, where:
\(\displaystyle u=x^2\implies du=2x\,dx\)
\(\displaystyle dv=e^{-6x}\,dx\implies v=-\frac{1}{6}e^{-6x}\)
And so we have:
\(\displaystyle y(x)=-2\left(-\frac{1}{6}x^2e^{-6x}+\frac{1}{3}\int xe^{-6x}\,dx\right)+c_2e^{-6x}=\frac{1}{3}x^2e^{-6x}-\frac{2}{3}\int xe^{-6x}\,dx+c_2e^{-6x}\)
For the remaining integral, let's use IBP again, where:
\(\displaystyle u=x\implies du=dx\)
And so we have:
\(\displaystyle y(x)=\frac{1}{3}x^2e^{-6x}-\frac{2}{3}\left(-\frac{1}{6}xe^{-6x}+\frac{1}{6}\int e^{-6x}\,dx\right)+c_2e^{-6x}=\frac{1}{3}x^2e^{-6x}+\frac{1}{9}xe^{-6x}+\frac{1}{18^2}e^{-6x}+c_1+c_2e^{-6x}\)
\(\displaystyle y(x)=c_1+\left(c_2+\frac{1}{18^2}\right)e^{-6x}+\frac{x}{9}\left(3x+1\right)e^{-6x}\)
Noting that \(\displaystyle \left(c_2+\frac{1}{18^2}\right)\) is still just an arbitrary constant, we may write:
\(\displaystyle y(x)=c_1+c_2e^{-6x}+\frac{x}{9}\left(3x+1\right)e^{-6x}\)
And this is equivalent to the solution obtain through the method of undetermined coefficients (but with a lot more work). :D
did you mean $e^{-6x}$
Yes, 'twas a typo. :D
FAQ: -17.2.05 by undetermined coefficients.
What is -17.2.05 by undetermined coefficients?
-17.2.05 by undetermined coefficients refers to a mathematical method used to find the particular solution of a nonhomogeneous linear differential equation.
How does the undetermined coefficients method work?
The undetermined coefficients method involves guessing a particular solution based on the form of the nonhomogeneous term in the differential equation, and then using this guess to find the coefficients that satisfy the equation.
When is the undetermined coefficients method used?
The undetermined coefficients method is typically used to find particular solutions for linear differential equations with constant coefficients and nonhomogeneous terms that are polynomials, exponential functions, or trigonometric functions.
What are the limitations of the undetermined coefficients method?
The undetermined coefficients method can only be used for linear differential equations, and it may not work for more complex nonhomogeneous terms such as logarithmic functions or products of different types of functions.
Are there any alternative methods to find particular solutions?
Yes, there are other methods for finding particular solutions of differential equations, such as the method of variation of parameters and the Laplace transform method.
