MHB -17.2.53 Find the unique solution from initial conditions.
karush
MHB
the function y_p is a particular solution to the specified nonhomogeneous equation. Find the unique solution satisfying the equation and the given initial conditions.
$y'' + 7y' = 7x$
$y_p=\frac{1}{2}x^2-\frac{1}{7}x$
$y(0)=y'(0)=0$
$r^2+7r=0$
$r=0$
$r=-7$
$y'' + 7y' = 7x$
$y(0)=y'(0)=0$
$r^2+7r=0$
$r=0$
$r=-7$
This problem is almost identical to the previous. What is your homogeneous solution $y_h$?
What I used to like to do as a student, when presented with a batch of similar problems, is to generalize to get a formula I could use. Suppose we are given the IVP:
$$y''+ay'=bx$$ where $y(0)=y_0$ and $y'(0)=y_0'$.
Now, using a technique you'll likely learn in a short while, it can be shown that the particular solution is:
$$y_p(x)=\frac{b}{2a}x^2-\frac{b}{a^2}x$$
From the characteristic equation, we find the homogeneous solution is:
$$y_h(x)=c_1+c_2e^{-ax}$$
And so, by the principle of superposition, we find the general solution to the ODE is:
$$y(x)=y_h(x)+y_p(x)=c_1+c_2e^{-ax}+\frac{b}{2a}x^2-\frac{b}{a^2}x$$
Differentiating, we obtain:
$$y'(x)=-ac_2e^{-ax}+\frac{b}{a}x-\frac{b}{a^2}$$
Now, using our initial values, we find:
$$y(0)=c_1+c_2=y_0$$
$$y'(0)=-ac_2-\frac{b}{a^2}=y_0'$$
This system implies:
$$\left(c_1,c_2\right)=\left(\frac{a^3y_0+a^2y_0'+b}{a^3},-\frac{a^2y_0'+b}{a^3}\right)$$
And so the solution to the IVP is given by:
$$y(x)=\frac{a^3y_0+a^2y_0'+b}{a^3}-\frac{a^2y_0'+b}{a^3}e^{-ax}+\frac{b}{2a}x^2-\frac{b}{a^2}x$$
wow thank you
I did the very last problem
and got the "fantastic" robot reply
but I followed your example to get it
anyway I need to do more so for this one
$y'' + 7y' = 7x$
$y(0)=y'(0)=0$
$r^2+7r=0$
$r=0$
$r=-7$
$y(x)=c_2\sin(\sqrt{7}x)+c_2\cos(\sqrt{7}x)+x$
karush said:
wow thank you
$y'' + 7y' = 7x$
$y(0)=y'(0)=0$
$r^2+7r=0$
$r=0$
$r=-7$
Only when the roots of the characteristic equation are imaginary do you typically express the homogeneous solution as a sinusoid. For example, if the given ODE had been:
$$y''+7y=f(x)$$
Then, the characteristic equation would be:
$$r^2+7=0\implies r=\pm\sqrt{7}i$$
And the homogeneous solution would then be:
$$y_h(x)=c_1\cos(\sqrt{7}x)+c_2\sin(\sqrt{7}x)$$
But in this problem, and the one before, the roots are real, and so we would use the exponential form for our homogeneous solution. :D
The other case, when the roots are real and repeated, will be a discussion for another thread. ;)
With characteristic roots 0 and -7, the general solution to the homogeneous differential equation is [math]Ce^{0x}+ De^{-7x}= C+ De^{-7x}[/math]. To solve y''+ 7y'= 7x, look for a specific solution of the form [math]y= (Ax+ B)x= Ax^2+ Bx[/math]. Then y'= 2Ax+ B and y''= 2A so the equation becomes 2A+ 14Ax+ 7B= 7x. We must have 14A= 7 and 2A+ 7B= 0.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
