1s orbital overlaps with the nucleus, why don't they interact?
In summary, internal conversion is a process where an electron is transferred from an upper to a lower energy level in the atom.
rumborak
706
154
Granted, the size difference between a hydrogen atom's electron cloud and its nucleus is a factor of one million (~1Å vs ~10^-6Å), but that's still a significant amount of overlap that, I would think, would trigger the occasional interaction.
They do interact, in most considerations indeed the nucleus is treated merely as a point and hence dimensionless charge. But if more accurate energy levels are desired, various corrections, usually treated as perturbations, must be incorporated into the Schroedinger equation. The one that pertains the finite size of the nucleus is the volume effect.
Indeed they do. Electron capture is a type of radioactive decay where the nucleus absorbs an inner shell electron. This doesn't happen in hydrogen because it isn't energetically favorable; the resulting neutron has more mass than the hydrogen atom.
Likes davenn
Radioactive isotopes that decay by pure electron capture can be inhibited from radioactive decay if they are fully ionized ("stripped" is sometimes used to describe such ions). It is hypothesized that such elements, if formed by the r-process in exploding supernovae, are ejected fully ionized and so do not undergo radioactive decay as long as they do not encounter electrons in outer space.
That. Is. So. Cool.
To expand on this, the effect also changes the number of energy levels for the hydrogen atom, not just their value. There is the well-known k-l degeneracy, where the n=2 l=0 level has the same energy as the n=2 l=1 level. But because the l = 0 level spends more time "inside" the nucleus, it has a larger energy shift than the l=1 state, breaking the degeneracy.
cool, learn something new every day :)
If you, like I, have a stack of "Scientific American" gathering dust on your shelves, you might find it interesting to read or re-read this article: https://www.scientificamerican.com/article/the-proton-radius-puzzle/
As I recall, part of it talks about how the electron wave function overlaps the proton wave function differently than the muon does in muonic hydrogen. It is offered up as a possible explanation of why the proton radius appears to be different when muons are substituted for electrons in one method for measuring the the proton radius.
You probably mean react , not interact.
The hydrogen atom is produced by electron-proton interaction.
I would think the previous discussion in this thread indicates that I was indeed talking about interaction between the electron's wave function and the proton's, not just a chemistry consideration. I was wondering why, if the the highest probability of an 1s electron is smack in the middle of the nucleus, why there aren't obvious interactions between the two. As was indicated in the replies here, there are indeed interactions resulting from that.
Likes davenn
It seems like you forget that the radial probability of a hydrogen-like atom is given by ##r^2|\psi_{nl}(r)|^2##, the presence of ##r^2## makes the probability inevitably zero in the origin and the maximum is shifted to a further distance.
Likes nasu and davenn
I don't understand what you mean by an interaction. The way I look at it the interaction between the electron and the nucleus is what forms the 1s orbital, so as long as that orbital exists there's an interaction at all times.
On the other hand, if by interaction you mean "occupy the same place at the same time" then you are asking a question that can't be answered because the electron can't be located that precisely.
But on the other hand if you're asking if there are other interactions besides the electromagnetic interaction that forms the 1s orbital, then the answer is yes and other posters have provided that answer.
Related to 1s orbital overlaps with the nucleus, why don't they interact?
1. What is the 1s orbital and how does it overlap with the nucleus?
The 1s orbital is the first energy level of an atom, and it is the closest to the nucleus. It is a spherical region of space where there is a high probability of finding an electron. The 1s orbital overlaps with the nucleus because it extends into the space occupied by the nucleus.
2. Why don't the 1s orbital and the nucleus interact?
The 1s orbital and the nucleus do interact, but the interaction is not significant enough to affect the overall behavior of the atom. This is because the 1s orbital is confined to a small region of space, while the nucleus is much smaller in comparison. Additionally, the electrons in the 1s orbital have low energy levels, so the interaction with the positively charged nucleus is weak.
3. What factors determine the strength of the interaction between the 1s orbital and the nucleus?
The strength of the interaction between the 1s orbital and the nucleus is primarily determined by the distance between them. The closer the electron is to the nucleus, the stronger the interaction will be. Additionally, the charge of the nucleus and the energy level of the electron also play a role in determining the strength of the interaction.
4. How does the interaction between the 1s orbital and the nucleus affect the stability of an atom?
The interaction between the 1s orbital and the nucleus is one of the factors that contribute to the overall stability of an atom. It helps to hold the electrons in their respective orbitals and prevents them from escaping. However, other factors such as the number of protons and neutrons in the nucleus also play a significant role in determining the stability of an atom.
5. Can the interaction between the 1s orbital and the nucleus be altered?
The interaction between the 1s orbital and the nucleus can be altered by changing the energy level of the electron or by changing the distance between the electron and the nucleus. This can be achieved through external factors such as the application of an external electric field or through chemical reactions that result in the rearrangement of electrons within the atom.
  • Other Physics Topics
  • Quantum Physics
  • Quantum Physics
