MHB 2.1.13 ok this isn't uv'+u'v
  • Thread starter Thread starter karush
karush
MHB
$\tiny{2.1.{13}}$
$\textsf{Find the solution of the given initial value problem}$
$$y'-y=2te^{2t}, \quad y(0)=1$$
$\textit{Find u(x)}$
$$\displaystyle\exp\int -1 dt =e^{ t^{-1}}$$
$\textit{multiply thru with $e^{ t^{-1}}$} $
$$ e^{ t^{-1}}y'- e^{ t^{-1}}y=2te^{t}$$
$\textit{W|A}$
$$\color{red}{c_1e^t+2e^{2t}t-2e^{2t}}$$
The integrating factor is:
$$\mu(t)=\exp\left(-\int\,dt\right)=e^{-t}$$
Try that...:)
$\tiny{2.1.{13}}$
$$\displaystyle\exp\int -1 dt =e^{ -t}$$
$\textit{multiply thru with $e^{- t}$} $
$$ e^{-t}y'- e^{-t}y=2te^{t}$$
but still this isn't uv'+u'v
$\textit{W|A}$
karush said:
$\tiny{2.1.{13}}$
$\textit{W|A}$
Hi,
Notice that, $\frac{d}{dt}\left(e^{-t}y\right)=e^{-t}y'-ye^{-t}$. I hope you can continue with this hint. :)
Sudharaka said:
Hi,
$\tiny{2.1.{13}}$
$$(e^{-t}y)'=2te^{t}$$
$\textit{integrate}$
$$e^{-t}y=\int 2te^{t} \, dt =2e^t (t-1)+c_1$$
$\textit{Divide thru by $e^{-t}y$ and distribute}$
$$c _1e^t+2e^{2t}t-2e^{2t}$$
$$y(0)=c _1e^{(0)}+2e^{2(0)}t-2e^{2(0)}=1+2-2=1$$
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
