MHB -2.1.9 Find general solution of 2y'+y=3t
The discussion focuses on solving the differential equation 2y' + y = 3t, leading to the general solution y(t) = ce^{-t/2} + 3t - 6. The integrating factor is determined to be e^{t/2}, which simplifies the equation to a solvable form. As t approaches infinity, the solution behaves asymptotically, approaching 3t - 6. Participants also discuss the implications of the solution and share a link to a Desmos slope field for visualization. The conversation highlights the importance of careful calculation and understanding of integrating factors in solving differential equations.
karush
MHB
$\tiny{2.1.9}$
2000
Find the general solution of the given differential equation, and use it to determine how
solutions behave as $t\to\infty$.
$2y'+y=3t$
divide by 2
$y'+\frac{1}{2}y=\frac{3}{2}t$
find integrating factor,
$\displaystyle\exp\left(\int \frac{1}{2} dt\right)=e^{t/2}+c$
multiply thru
$e^{t/2}y'+e^{t/2}\frac{y}{2}
=\frac{3e^{t/2}}{2}t $ok something went :confused::confused::confused::confused::confused:
book answer
$\color{red}\displaystyle y=ce^{-t/2}+3t-6 \\
\textit{y is asymptotic to } 3t-6 \textit{ as } t\to\infty $
When you determine your integrating factor, you need only determine up to but not including the constant of integration:
$$\mu(t)=\exp\left(\int\frac{1}{2}\,dt\right)=e^{\frac{t}{2}}$$
And so the ODE becomes:
$$e^{\frac{t}{2}}y'+\frac{1}{2}e^{\frac{t}{2}}y=\frac{3}{2}te^{\frac{t}{2}}$$
Or:
$$\frac{d}{dt}\left(e^{\frac{t}{2}}y\right)=\frac{3}{2}te^{\frac{t}{2}}$$
Integrating, we obtain:
$$e^{\frac{t}{2}}y=3e^{\frac{t}{2}}(t-2)+c_1$$
Now does the answer given by the book make sense? :)
Hence:
$$y(t)=3(t-2)+c_1e^{-\frac{t}{2}}$$
for some reason I thought $\displaystyle e^{t/2}$ stayed the same whether taking the integral or derivative
$\displaystyle\frac{d}{dt} e^{t/2} = \frac{e^{t/2}}{2}$
multiply thru
$\displaystyle e^{t/2}y'+\frac{1}{2}e^{t/2}y
=\left(e^{t/2}y\right)^\prime
=\frac{3}{2}te^{t/2}$
integrate through
=\int\frac{3}{2}te^{t/2}\ dt=3 e^{t/2}(t-2)+c$
simplify
$\displaystyle y=ce^{t/2}+3t-6$
$\textit{ok I didn't know how this the book says y is asymptotic to $3t-6$ as $t\to\infty$}$
Draw a direction field for the given differential equation.
how do you do this with Desmos
karush said:
$\displaystyle e^{t/2}y =3 e^{t/2}(t-2)+c$
simplify
Think about these two lines for a moment...
-Dan
-Dan
$\displaystyle y=3(t-2)+\frac{c}{e^{t/2}}=ce^{-t/2}+3t-6$
You just aren't doing well with the typos today, huh? (Sun)
Whatever. You got it.
-Dan
I just wanted to see if you would catch it...
