-2.2.4 find general solution xy'+2y=e^x
In summary, the general solution to the differential equation $xy'+2y=e^x$ is $y=\frac{e^x}{x}-\frac{e^x}{x^2}+\frac{c}{x^2}$. This was found by dividing through by $x$, finding the appropriate $u(x)$, multiplying through by $x^2$, integrating, and then dividing through by $x^2$.
karush
MHB
3,269
$\textsf{find the general solution}$
$$xy'+2y=e^x$$
$\textsf{divide thru by x}$
$$y' +\frac{2}{x}y=\frac{e^x}{x}$$
$\textsf{Find u(x)}$
$$\displaystyle u(x)=\exp\int\frac{2}{x} \, dx=e^{\ln x^2}=x^2$$
$\textsf{so far anyway..}$
$$xy'+2y=e^x$$
$\textsf{multiply thru with $x^2$}$
$x^2 y' +2xy=xe^x$
$(x^2 y)'=xe^x$
$\textsf{integrate}$
$\displaystyle x^2 y=\int xe^x \, dx =e^x(x-1)+c$
$\textsf{divide thru by $x^2$}$
$\displaystyle y=\frac{e^x}{x}-\frac{e^x}{x^2}+\frac{c}{x^2}$
hopefully
FAQ: -2.2.4 find general solution xy'+2y=e^x
What is the general solution to the differential equation xy'+2y=e^x?
The general solution to this differential equation is y(x) = Cx^2 + e^x/2, where C is an arbitrary constant.
How do you find the general solution to this differential equation?
To find the general solution, we first solve for y' by dividing both sides of the equation by x, giving us y' + 2y/x = e^x/x. Next, we use the integrating factor method to solve for y. Once we have the general solution, we can add any arbitrary constant to it to account for all possible solutions.
What is the integrating factor method?
The integrating factor method is a technique used to solve first-order linear differential equations. It involves multiplying both sides of the equation by an integrating factor, which is calculated using the coefficient of the dependent variable. This reduces the equation to a form that can be easily integrated.
Can you provide an example of using the integrating factor method to solve this differential equation?
Sure. Using the equation xy'+2y=e^x, the integrating factor is calculated as e^(2lnx) = x^2. Multiplying both sides of the equation by x^2, we get x^2y'+2x^2y=e^xx^2. The left side of the equation can be written as (x^2y)' = e^xx^2. Integrating both sides and adding an arbitrary constant, we get the general solution y(x) = Cx^2 + e^x/2.
What is the significance of the arbitrary constant in the general solution?
The arbitrary constant accounts for all possible solutions to the differential equation. Without it, we would only have a particular solution. By adding the arbitrary constant, we are able to find the entire family of solutions to the differential equation.
