2 dimension kinematics Cutnell Chapter 3 Prob 26
In summary, the quarterback claims to be able to throw a football 184 m horizontally at a launch angle of 29.7°. To evaluate this claim, we must determine the speed at which the quarterback must throw the ball. Assuming that air resistance can be ignored and the ball is launched and caught at the same vertical level, we can use a projectile motion equation to calculate the required velocity. The answer would then be compared to a baseball pitcher who throws a fastball at 45 m/s (100 mph).
Jacque77
A quarterback claims that he can throw the football a horizontal distance of 184 m. Furthermore, he claims that he can do this by launching the ball at the relatively low angle of 29.7 ° above the horizontal. To evaluate this claim, determine the speed with which this quarterback must throw the ball. Assume that the ball is launched and caught at the same vertical level and that air resistance can be ignored. For comparison a baseball pitcher who can accurately throw a fastball at 45 m/s (100 mph) would be considered exceptional
.5*184m=92m -adjacent side
90-29.7(theta)=60.3 other angle
Hyp=x/cos theta or 91.42=92/.8686
Opposite ; tan theta=X/92(adjacent side)=54.27 is (.5704*92)
need time so d=(.5)at^2
184=(.5)(-9.80)(t)^2 =-6.13seconds
see above - I'm not sure I have the time set up properly. I need a hint as to how to get
started with determining the velocity - just a hint!
Use an equation for Projectile Motion instead.
Split the velocity vector on x and y component. Then it's easy to calculate the time of flight since x speed is constant. Once you have time, you have tu calculate what initial y speed should be that the vertical throw with that speed would be that long.
Since the problem is stated this way, the horizontal displacement is the range. Thus, use a projectile motion equation for the range.
It will then be a very simple problem of substituting in the given values!
FAQ: 2 dimension kinematics Cutnell Chapter 3 Prob 26
1. What is 2 dimension kinematics?
2 dimension kinematics is the study of motion in two dimensions, typically represented by the x and y axes. It involves analyzing the position, velocity, and acceleration of an object as it moves through space.
2. What is Cutnell Chapter 3 Prob 26?
Cutnell Chapter 3 Prob 26 is a specific problem from the textbook "Physics, 11th Edition" by John D. Cutnell and Kenneth W. Johnson. It involves solving a 2 dimension kinematics problem using equations and principles taught in Chapter 3.
3. What are the main concepts covered in Cutnell Chapter 3 Prob 26?
The main concepts covered in Cutnell Chapter 3 Prob 26 include displacement, velocity, acceleration, and projectile motion. These concepts are used to solve a 2 dimension kinematics problem involving an object being launched at an angle.
4. How do I approach solving Cutnell Chapter 3 Prob 26?
The first step in solving Cutnell Chapter 3 Prob 26 is to clearly identify and understand the given information, including the initial position, velocity, and angle of launch. Then, use the appropriate equations and principles from Chapter 3 to solve for the unknown variables, such as time, displacement, or velocity at a certain point in time.
5. Why is it important to understand 2 dimension kinematics?
Understanding 2 dimension kinematics is important because it allows us to accurately describe and predict the motion of objects in our everyday lives. It is also a fundamental concept in physics and is necessary for understanding more complex topics such as forces and energy. Additionally, it has practical applications in fields such as engineering and motion analysis in sports.
