2 Energy-related equations: Lost and getting started please
  • Thread starter Snomann92
  • Tags
    Lost
In summary, the term "lost" in energy-related equations refers to unaccounted energy while "getting started" refers to the initial energy input. Energy-related equations take into account different forms of energy and can be used to predict energy efficiency. These equations are derived from the laws of thermodynamics and there are various types used in different fields of science and engineering.
Snomann92
A worker pushed a 27 kg block 7.4 m along a level floor at constant speed with a force directed 28° below the horizontal.
(a) If the coefficient of kinetic friction is 0.20, how much work was done by the worker's force?
Magnitude of the x component of the applied force = - Magnitude of the kinetic frictional force, but part of the applied force is in the normal force?
FA,x+muk*|FN|=FA,y+m*g+FN?
Two children are playing a game in which they try to hit a small box on the floor with a marble fired from a spring-loaded gun that is mounted on a table. The target box is horizontal distance D = 2.00 m from the edge of the table, see the figure. Bobby compresses the spring 1.10 cm, but the center of the marble falls 22.0 cm short of the center of the box. How far should Rhoda compress the spring to score a direct hit?
No mass, no height, no value for k... I don't even know where to start. :S
Hello there,
I would like to address both of your questions.
For the first question about the worker pushing a block, yes, you are correct that the magnitude of the x component of the applied force is equal to the magnitude of the kinetic frictional force. However, in this case, the applied force is not only in the x-direction, but also has a component in the y-direction (FA,y). So the equation would be:
FA,x + FA,y + μk|FN| = mg
Where μk is the coefficient of kinetic friction, FN is the normal force, and mg is the weight of the block.
To solve for the work done by the worker's force, we can use the formula:
W = Fcosθ * d
Where F is the applied force, θ is the angle between the force and the displacement (in this case, 28°), and d is the displacement (7.4 m). So the work done by the worker's force would be:
W = (FA,x + FA,y)cos28° * 7.4 m
Now, for the second question about the game with the spring-loaded gun, without knowing the mass, height, or value for k, it is impossible to determine the exact amount that Rhoda should compress the spring. However, we can use the concept of conservation of energy to solve for the compression distance.
The total energy of the system (spring and marble) is equal to the potential energy stored in the compressed spring and the kinetic energy of the marble when it is fired. So we can write:
PEinitial = KEfinal
Since PE = 1/2kx^2 and KE = 1/2mv^2, we can set these two equations equal to each other and solve for x (the compression distance):
1/2kx^2 = 1/2mv^2
Where v is the velocity of the marble, which can be found using the given information (distance D and height difference of 22.0 cm).
I hope this helps to clarify things for you. Please let me know if you have any further questions. Keep exploring and learning!
FAQ: 2 Energy-related equations: Lost and getting started please
What is the difference between "lost" and "getting started" in energy-related equations?
The term "lost" in energy-related equations refers to the amount of energy that is not accounted for or cannot be harnessed in a given system. This can be due to factors such as friction, heat loss, or inefficiencies in the system. On the other hand, "getting started" refers to the initial energy input or activation energy needed to start a reaction or process.
How do energy-related equations account for different forms of energy?
Energy-related equations take into account both kinetic and potential energy, as well as different forms of energy such as thermal, electrical, chemical, and nuclear. The equations use specific units and formulas to accurately measure and calculate the different types of energy involved in a system.
Can energy-related equations be used to predict energy efficiency?
Yes, energy-related equations can be used to predict the efficiency of a system or process by calculating the amount of energy input and the amount of energy output. This can help identify areas for improvement and optimization in order to increase energy efficiency.
How do energy-related equations relate to the laws of thermodynamics?
The laws of thermodynamics are fundamental principles that govern energy and its behavior in physical systems. Energy-related equations are derived from these laws and are used to quantify and describe the transfer and transformation of energy in a system.
Are there different types of energy-related equations?
Yes, there are various types of energy-related equations, such as the laws of thermodynamics, the kinetic energy equation, the potential energy equation, and equations related to specific forms of energy, such as electrical or thermal energy. These equations are used in different fields of science and engineering to analyze and understand energy systems.
