2 masses connected by spring, one is pulled, how much does the spring stretch?
The discussion revolves around a physics problem involving two masses connected by a spring, where one mass is pulled. The initial approach involves using the net force equations for both masses, but the poster expresses uncertainty about the solution. A suggestion is made to simplify the problem by assuming one mass is significantly larger than the other, which can help clarify the calculations. The conversation highlights the importance of analyzing limiting cases to understand the behavior of the system. Ultimately, the focus remains on finding the correct method to determine how much the spring stretches.
Obliv
The masses are connected by a massless spring on a frictionless surface. One of the masses is pulled by a force F, how much does the spring stretch if at all?
F = ma, F = -kx
Hi, I am having trouble with this problem. I'm thinking the solution is this but I'm not sure. Fnet=m1a+m2aFnet=m1a+m2a , m1a=kxm1a=kx, m2a=Fkxm2a=F−kx so x=m1ak=−(m2aF)kx=m1ak=−(m2a−F)k
nvm
So what answer did you finally get? Does it reduce to what you would expect in the limiting cases ##m_1<<m_2## and ##m_1>>m_2##?
Likes MatinSAR and PeroK
... I suggest first assuming that ##m_1## is so large that it doesn't move. That gives you an easier problem to get you started.
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 42 ·
