- #36
PeterDonis
Mentor
- 46,795
- 23,299
Isaac0427 said:I understand what a Hilbert space is, but I always thought that a valid basis would be a spin up state and a spin down state
Those states form a basis for one particular Hilbert space, the Hilbert space of spin states for a single spin-1/2 particle.
Isaac0427 said:or if we are talking about energy, the ground state, the first excited state, the second excited state, etc
Those states would form a basis for another particular Hilbert space, the Hilbert space of a single particle in a potential well. Strictly speaking, this particle would have to have zero spin, since you are only including energy in the specification of the basis states.
The Hilbert space you have been implicitly referring to in this discussion is neither of the above. In fact it's not entirely clear which one it is, since we have talked about several different possible scenarios, but we'll start with the simplest possible one that is relevant: the Hilbert space of a quantum system consisting of two identical spin-1/2 particles, which are both in the same energy level of some potential well. At this point we are ignoring any other characteristics of the particle or the potential well: no electric charge, no nucleus of the atom, etc. We are also ignoring any possibility of either particle jumping to some other energy level (for example, by absorbing a quantum of radiation).
This Hilbert space is an antisymmetric tensor product of two copies of the Hilbert space of spin states for a single spin-1/2 particle. Unfortunately, we don't have any way of writing down what that means without labeling the particles, but as I've said before, it's important to realize that these labels are artifacts of our math and do not correspond to anything in the actual system. If we label the particles as "particle 1" and "particle 2", then a simple tensor product (which is not quite what we're looking for, but will give us a start at getting there) of the Hilbert spaces for each particle would be a Hilbert space with a basis consisting of four mutually orthogonal vectors which we could write as ##\vert \uparrow \rangle_1 \vert \uparrow \rangle_2##, ##\vert \uparrow \rangle_1 \vert \downarrow \rangle_2##, ##\vert \downarrow \rangle_1 \vert \uparrow \rangle_2##, ##\vert \downarrow \rangle_1 \vert \downarrow \rangle_2##, where the arrows denote the "up" and "down" basis states for the single-particle Hilbert space and the subscripts denote which particle (1 or 2). In other words, the simple tensor product Hilbert spaces consists of all possible states you can form by multiplying together two single-particle states.
If you want some more information about tensor products of Hilbert spaces, see here:
https://en.wikipedia.org/wiki/Tensor_product_of_Hilbert_spaces
But the Hilbert space we actually want is the antisymmetric tensor product; "antisymmetric" because we are dealing with fermions. This Hilbert space can be constructed in a number of ways, but the simplest is to take all possible states you can form from the following formula:
\vert \psi \rangle_A = \frac{1}{\sqrt{2}} \left( \vert \psi_a \rangle_1 \vert \psi_b \rangle_2 - \vert \psi_b \rangle_1 \vert \psi_a \rangle_2 \right)
where ##\vert \psi_a \rangle## and ##\vert \psi_a \rangle## are states belonging to the single-particle Hilbert space of spin states. So what we need is a valid set of basis states for this Hilbert space. One way to find them is to expand ##\vert \psi_a \rangle## and ##\vert \psi_a \rangle## in terms of the single-particle basis states and substitute into the above formula:
\vert \psi \rangle_A = \frac{1}{\sqrt{2}} \left[ \left( a_{\uparrow} \vert \uparrow \rangle_1 + a_{\downarrow} \vert \downarrow \rangle_1 \right) \left( b_{\uparrow} \vert \uparrow \rangle_2 + b_{\downarrow} \vert \downarrow \rangle_2 \right) - \left( b_{\uparrow} \vert \uparrow \rangle_1 + b_{\downarrow} \vert \downarrow \rangle_1 \right) \left( a_{\uparrow} \vert \uparrow \rangle_2 +a _{\downarrow} \vert \downarrow \rangle_2 \right) \right]
Then we can just expand out the products and collect terms:
\vert \psi \rangle_A = \frac{1}{\sqrt{2}} \left[ \left( a_{\uparrow} b_{\uparrow} - b_{\uparrow} a_{\uparrow} \right) \vert \uparrow \rangle_1 \vert \uparrow \rangle_2 + \left( a_{\uparrow} b_{\downarrow} - b_{\uparrow} a_{\downarrow} \right) \vert \uparrow \rangle_1 \vert \downarrow \rangle_2 + \left( a_{\downarrow} b_{\uparrow} - b_{\downarrow} a_{\uparrow}\right) \vert \downarrow \rangle_1 \vert \uparrow \rangle_2 + \left( a_{\downarrow} b_{\downarrow} - b_{\downarrow} a_{\downarrow} \right) \vert \downarrow \rangle_1 \vert \downarrow \rangle_2 \right]
You can see that two of these four terms vanish, and the other two have the same factor in front, just with a sign change, so we end up with (note that the factor involving the ##a## and ##b## coefficients must be ##1## if the state is normalized):
\vert \psi \rangle_A = \frac{1}{\sqrt{2}} \left( \vert \uparrow \rangle_1 \vert \downarrow \rangle_2 - \vert \downarrow \rangle_1 \vert \uparrow \rangle_2 \right)
In other words, the antisymmetric tensor product Hilbert space has just one basis state! And therefore it has just one state, period (since the only way to change the above basis state would be to multiply it by some complex number, and that doesn't change the state physically).
What does this mean, physically? It means that, if you want to put two spin-1/2 particles into the same energy level of a potential well, there is only one way to do it. What is that way? The obvious way: give them opposite spins. Note that that is what the above state is: a state in which the two spin-1/2 particles have opposite spins. It does not specify the spins of either particle individually: it just says they have opposite spins. In other words, this state is an entangled state: neither particle has a definite state individually, only the system consisting of the two particles does.
Note also that, since the two particles must have opposite spins, there is no state in this Hilbert space that corresponds to your example, where the two spins only differed by a small amount. What the above is telling us is that this is not physically possible for two spin-1/2 fermions in the same energy level of a potential well.
I'll stop here and let you digest the above. But you should understand it thoroughly before we try to go on to more complicated examples.
