2 questions on Wave Phase Differences [Diagram Included]
  • Thread starter qazxsw11111
  • Tags
    Phase Wave
In summary: The phase difference between the waves emitted by the two sources is π/2. The waveform detected at P for S2 only is also shown on Fig. 5. The waveform detected at P for S1 only is shown in the bottom dashed line. The phase difference is 0.2 (x10s). The waveform detected at P for S1 and S2 together is shown in the top dashed line. The phase difference is 0.5 (x10s).
qazxsw11111
95
2 URGENT questions on Wave Phase Differences [Diagram Included]!
Two microwave sources S( and S, are situated as shown in Fig. 5.1. The waves emitted by the two sources are in phase and are polarised in the same plane.
http://img190.imageshack.us/img190/3924/wave1f.jpg
A microwave detector is placed on a line XY which is parallel to, and 3.2 m from, the line joining S, and S2. M is the midpoint of the line joining S( and S2. The line from M perpendicular to the line S,S2 meets XY at O. The detector produces an output which is proportional to the displacement of the wave.
With only S, switched on, the change with time of the detector output measured at P, a distance of 5.0 cm from O, is as shown in Fig.
Determine phase difference between the waves at P.
My solution:
According to my knowledge, phase difference= Δt/T x 2π
Hence, looking at the distance between the two peaks or two troughs, the time lag is about 0.2 (x10s) Dividing by period of 8.3 (x10s) you get around π/2. Is this correct? Is there a better method to do this?
Second part (Still same question):
S1 and S2 are switched on together, with the emitted waves in phase. The detector is moved from P along the line OY, in the direction away from O. State and explain the approximate distance that the detector must be moved before the intensity is a maximum, given that there is no maximum between O and P.
My solution:
Since constructive interference occurs, path difference=nλ. Since it is first maximum, n=1. But I do not know how to carry on. Anyone please help?
Another Question:
http://img687.imageshack.us/img687/446/wave2.jpg
Fig shows a displacement-distance graph for two sound waves A and B. of the same frequency and amplitude. WaveA traveling to the right and wave B is traveling to the left.
(ii) The period of each wave is T. Determine the maximum displacement of the resultant of the two waves
1. at the instant shown.
2. at the instant shown +1/8T,
3. at the instant shown +3/8T.
Well guys, I am really unsure on how to do this question, with all the 1/8T and 3/8T which are confusing me. Anyone help?
Thanks.
Bumpy?
Anyone?
Anyone can help? I need understanding about wave phases. And my exam is only a day away.
Anyone?
Anyone please chip in?
First problem: Although you made a mistake in the period (it is 0.833 x 10-10 s) the method is all right, but a bit less accurate than to get the phase difference by calculation.
The phase of a wave is
[tex]2\pi(\frac{t}{T}-\frac{x}{\lambda})+\psi[/tex]
The two sources emit in the same phase so the phase constant can be taken zero. The phase difference between the waves emerging from S1 and S2 is caused by the difference in length of path they travel from their source to the point P. Calculate the path difference, determine the wavelength and you get the phase difference.
In the second part, you know the phase difference, find the arrangement where the path difference is equal to the wavelength.
ehild
Related to 2 questions on Wave Phase Differences [Diagram Included]
1. What is a wave phase difference?
A wave phase difference refers to the difference in the position of two waves with the same frequency, measured in terms of their phase angle. It is a measure of how much the two waves are out of sync with each other.
2. How is wave phase difference measured?
Wave phase difference is typically measured in degrees or radians, with a full cycle or wavelength being equal to 360 degrees or 2π radians. It can be measured using a variety of tools such as an oscilloscope or a wave meter.
