2 sphere system, Conservation of Energy and Momentum
In summary: Regarding the second question, I didn't understand. Wouldn't the center of mass of each sphere always be at the center of each sphere...?Regarding the second question, I didn't understand. Wouldn't the center of mass of each sphere always be at the center of each sphere...?
  • #36
Better WOrld said:
Also, how do we conserve Energy? At say ##t=0## the two spheres are at test. However, at ##t+\delta t## an external force is applied. Hence, we can conserve energy only after this external force has done work.
From the OP :
Now the upper sphere is pushed very slightly from it's equilibrium position
You can neglect the external work done by this very small/gentle push . It is just a nudge to get the upper ball moving .
  • #37
Better WOrld said:
Is the Mechanical Energy at the time of the upper sphere losing contact
$$\dfrac{1}{2}V_{M,earth}^2+\dfrac{1}{2}mv_{m,earth}^2+mg(R+r)(1-\cos\theta)?$$
The potential energy term is not correct . The term you have written represents the difference in potential energy .
  • #38
Oh Sorry, it should be $$
\dfrac{1}{2}V_{M,earth}^2+\dfrac{1}{2}mv_{m,earth}^2+mg(R+r)\cos\theta$$ right?
  • #39
Right .
  • #40
Vibhor said:
Right .
And initially then, since the work done by the external force is negligible, $$mg(R+r)$$ is the total energy of the system. Thus, $$mg(R+r)=
  • #41
Yes .
By the way , you are missing 'M' in the first term on the right side.
  • #42
Vibhor said:
Yes .
Sorry again,
$$mg(R+r)=
\dfrac{1}{2}MV_{M,earth}^2+\dfrac{1}{2}mv_{m,earth}^2+mg(R+r)\cos\theta$$
Could you please help me apply the equation for conservation of linear momentum in the horizontal direction?
  • #43
What is troubling you in applying conservation of linear momentum?
  • #44
I'm trying to conserve momentum in the horizontal direction from the ground frame. However, in this frame, the velocity of the upper sphere is ##v_{m,earth}##. However, I cannot understand how to find the horizontal component of ##v_{m,earth}##.
  • #45
Sir we want to find the horizontal momentum for the upper sphere, right? So this would correspond to first finding the horizontal component of ##v_{m,earth}##. Since $$v_{m,earth}=v_{m,M}+v_M$$, finding the horizontal component of ##v_{m,earth}## corresponds to finding the horizontal component of ##v_M## and ##V_{m,M}## and then adding their respective horizontal components to find the horizontal component of ##v_m##. Now since ##v_M## is in the horizontal direction itself, its horizontal component is ##v_M## itself. The horizontal component of ##v_{m,M}## is ##v_{m,M}\cos\theta##. Thus, the horizontal component of ##v_{m,earth}## is $$v_{m,M}\cos\theta+v_M=v_{m,M}\cos\theta-|v_M|$$ since ##v_M## is towards the negative X axis. Thus as the equation for conservation of linear momentum in the horizontal direction, I get $$0+0=-Mv_M+m(v_{m,M}\cos\theta-|v_M|)$$
  • #46
Almost Correct .
No point in using absolute value in ##|v_M|## on right side. Writing ##v_M## is okay . The negative sign in front of ##v_M## takes care of the direction.
So , now you have three equations and three variables . Solve for ##\theta##.
Note : I would again suggest you to work with the notation (free of subscripts) I mentioned in post#33 . The subscripts make things little hard to understand.
  • #47
Vibhor said:
Almost Correct .
Just to confirm, these are the 3 equations, right?
$$\dfrac{mu^2}{R+r}=mg\cos\theta$$
$$(M-m)V=mu\cos\theta$$
$$mg(R+r)(1-\cos\theta)=\dfrac{1}{2}MV^2+\dfrac{1}{2}mv_{m,earth}^2$$
Also, $$v_{m,earth}^2=V^2+u^2-2uV\cos\theta$$
Sir, would it be possible to know the direction of ##V_{m,earth}## just by looking at the diagram and not considering the magnitude of the respective velocities? If so, please could you teach me how to do it?
  • #48
Sir, could you please check the value you are getting for ##\cos\theta## with $$R=5,r=1,m=25,M=7,g=9.8$$ I'm not getting ##\cos\theta=\dfrac{4}{5}## which is the given answer.
  • #49
Recheck this equation .
Parallelogram law of vector addition .
  • #50
Sorry, it should be $$(M+m)V=mu\cos\theta$$
If it is possible, could you please show the direction of ##v_{m,Earth}##?
  • #51
The green vector represents ##v_{m,Earth}## .
  • #52
Thanks very much. I was about to upload the same picture!
  • #53
In this equation, how would we substitute ##v_{m,earth}^2## in terms of ##u## and ##V##?
Is it ##v_{m,earth}=\sqrt{u+V}=\sqrt{(u\cos\theta-V)\hat{i}+u\sin\theta\hat{j}}##
  • #54
Refer to your post#47.
  • #55
Thanks Sir. I had just finished editing my previous post.
  • #56
From post#47
##v_{m,earth}^2=V^2+u^2-2uV\cos\theta##
  • #57
o_O This doesn't make sense.
##v_{m,earth}=\sqrt{V^2+u^2-2uV\cos\theta}##
  • #58
Sorry again. I forgot to add the ##^2## symbol and remove the unit vectors. I think I do get ##\cos\theta=\dfrac{4}{5}## now.
I'm really, really grateful to you for all your help! Many, many thanks once again!
  • #59
You are welcome :smile: .
  • #60
Hello Vibhor. Sorry to disturb you again, but I have a few fresh doubts.
$$\dfrac{mv_{m,M}^2}{R+r}=N+mg\cos\theta$$
In this equation, is ##N## the normal force measured from the ground frame, or is it the normal force measured from the frame of the ##lower sphere## ie by keeping the lower sphere's position fixed (the way we kept the lower sphere's velocity fixed - through relative velocity)? Wouldn't the Normal force measured from these 2 frames (ground and the lower sphere) differ in direction?
I'm confused because I always learned that in circular motion, for $$F_1+F_2+...=\dfrac{mv^2}{R}$$ we consider forces ##F_i## which when drawn pass through the center of the circle about which the particle undergoes circular motion. However, when the lower sphere is moving too, I don't think it is necessary for the normal force between the upper and lower spheres (as measured from the ground frame) to pass through the center of any circle about which the particle may be undergoing circular motion.
Secondly, if we consider the motion of the upper sphere with respect to the ##ground frame##, is it undergoing circular motion? Are there any specific conditions for it to undergo circular motion? I know that the upper sphere with respect to the ##lower sphere## is undergoing circular motion, but am not sure about the motion of the upper sphere with respect to the ground. In other words, over a period of time, is the green vector (in post #51) also undergoing circular motion about any point? If so, could you please show me that point?
I do hope you'll have the patience to bear with me. Many thanks in advance!
9K
