geoffgow
- 3
Hello - this is a continuation of a previous thread https://www.physicsforums.com/threads/using-european-230v-50hz-appliances-in-the-us.620097/
Question 1:
The final recommendation was to run 3 wires plus ground to the new 220v outlet but the appliance doesn't have anywhere for 3 wires + ground. The appliance is wired for a single hot (phase) wire, a neutral and a ground.
In creating the 220v with the 2x 110v legs we would be applying 110v to Line (phase) and 110v to Neutral and then ground to ground. There would not be anywhere on the appliance to connect the actual neutral coming from the panel - right?
Question 2:
Assuming I did not misunderstand the recommendation to create the 220v in the above manner I then wonder the wisdom of applying 110v to the neutral of the appliance. Is there any risk the neutral and ground are bonded within the appliance? Or any other reason to be concerned about heating up the neutral?
Thanks in advance,
Geoff
Question 1:
Question 2:
Thanks in advance,
Geoff
