242t.08.02.09 int of rational expression.
In summary, we used the substitution method to evaluate the integral $I_{8.1.31}=\int_5^{10}\frac{3x^5}{x^3-5} \, dx$ and found the value to be approximately 885.576. While there are different approaches to solving this integral, it is beneficial to choose a method that minimizes the amount of computation needed.
karush
MHB
3,269
$\tiny{242t.08.02.09}$
$\textsf{ Evaluate to nearest thousandth}\\$
\begin{align*}
\displaystyle
I_{8.1.31}
&=\int_5^{10}
\frac{3x^5}{x^3-5} \, dx =885.576\\
\end{align*}
$\textit{ok tried getting to this answer by: }$
$u=x^3-5 \therefore du=3x^2 \, dx$
$\textit{but it didnt seem to go to good}$
\begin{align*}
\displaystyle
I_{8.1.31}
&=\int_5^{10}
\end{align*}
$\displaystyle \begin{align*} \int_5^{10}{ \frac{3\,x^5}{x^3 - 5}\,\mathrm{d}x } &= \int_5^{10}{ \frac{x^3}{x^3 - 5}\,3\,x^2\,\mathrm{d}x } \end{align*}$
Let $\displaystyle \begin{align*} u = x^3 - 5 \implies \mathrm{d}u = 3\,x^2\,\mathrm{d}x \end{align*}$ and note that $\displaystyle \begin{align*} u(5) = 120 \end{align*}$ and $\displaystyle \begin{align*} u(10) = 995 \end{align*}$ and the integral becomes
$\displaystyle \begin{align*} \int_5^{10}{ \frac{x^3}{x^3 - 5}\,3\,x^2\,\mathrm{d}x } &= \int_{120}^{995}{ \frac{u + 5}{u}\,\mathrm{d}u } \\ &= \int_{120}^{995}{ \left( 1 + \frac{5}{u}\right) \,\mathrm{d}u } \end{align*}$
Continue.
\begin{align*}\displaystyle
I_{8.1.31}&=\int_5^{10}
\frac{3x^5}{x^3-5} \, dx \\
\end{align*}
I_{8.1.31}&= \int_{120}^{995}{ \frac{u + 5}{u}\,du } \\
&=\left[u+5\ln\left({\left| u \right|}\right)\right]^{995}_{120}\\
&=\left[1029.514-143.938\right] \\
&=885.576
\end{align*}
$\textit{basically}$
While there's technically nothing wrong with what you did, I would evaluate as follows:
\(\displaystyle I=\int_{120}^{995} 1+\frac{5}{u}\,du=(995-120)+5\ln\left(\frac{995}{120}\right)=5\left(175+\ln\left(\frac{199}{24}\right)\right)\approx885.576\)
This way, you only have one log to evaluate, and the rounding is done one time.
thanks love the tips...
FAQ: 242t.08.02.09 int of rational expression.
What is the meaning of "242t.08.02.09 int of rational expression"?
The expression "242t.08.02.09 int of rational expression" refers to a specific mathematical problem or equation that involves rational expressions, which are fractions with variables in the numerator and/or denominator.
How do you solve a rational expression?
To solve a rational expression, you need to simplify the fraction by factoring out common terms and then canceling them out. Then, you can set the remaining factors equal to zero and solve for the variable. Be sure to check for any excluded values, which are values that make the denominator equal to zero.
Can you provide an example of solving a rational expression?
Sure, for example, to solve the expression (x+3)/(x+5), we can factor out the common term (x+3) and cancel it out, leaving us with 1/(x+5). Then, we can set the remaining factor (x+5) equal to zero and solve for x, giving us x=-5. However, we must also remember to check for an excluded value of x=-5, which would make the denominator equal to zero and therefore make the expression undefined.
What are some common mistakes when solving rational expressions?
Some common mistakes when solving rational expressions include forgetting to factor out common terms, canceling out too many terms, and not checking for excluded values. It's important to carefully simplify and check your work to avoid these mistakes.
How are rational expressions used in real life?
Rational expressions are used in many real-life applications, such as calculating proportions, solving problems involving rates and ratios, and determining the slope of a line. They are also used in economics, engineering, and science for modeling and analyzing various systems and processes.
