2Al + 3CuCl2 -> 3Cu + 2AlCl3 Mass of Cu = ?
  • Thread starter Strawberry123
  • Tags
    Mass
In summary, sources of error that could affect the percentage yield of the reaction could be avoided by careful mixing of the reactants, using an accurate timer, and performing the experiment in a fume hood. Additionally, accurate mass measurements of the reactants and products, and complete mixing of the reactants, are other key ways to improve the accuracy of the experiment.
Strawberry123
URGENT:Sources of Error that Impact the Percentage Yield
This is my chem lab on the reaction 2Al + 3CuCl2 --> 3Cu + 2AlCl3.
So my question is:
1. What sources of error in the experiment would affect the percentage yield of reaction?
2. In what ways this experiment could be improved?
Purpose: to find the percentage yield of copper in the reaction.
Procedure:
1. Add enough distilled water to dissolve the 0.51 g of CuCl2 (s) in the beaker.
2. Record the colour of the resulting solution.
3. Measure out 0.25 g of the aluminum and add this to your solution.
4. Leave the beaker on your lab desk and allow the reaction to go to completion.
5. When the reaction is completed, record your observations.
6. Use the forceps to collect all copper formed. Carefully transfer the copper to a beaker and rinse the copper with water.
7. Pour off as much of the rinse water as possible. Spread the copper on the bottom of the beaker.
8. Cover the beaker containing the wet copper with a watch glass and gently heat the beaker on a hot plate to dry the copper. Reduce heat if the copper begins to turn black.
9. When the copper is dry completely, determine the mass of copper.
Thanks Millions! Please help! I'd really appreciate it! =]
1. Sources of error that could affect the percentage yield of reaction include:-Insufficient mixing of reactants, leading to incomplete reaction-Inaccurate mass measurement of the reactants or products-Contamination of reagents or products-Loss of product due to improper handling (e.g. spilling, vaporization)-Inaccurate timing of the reaction-Incomplete transfer of the products from one container to another2. Ways to improve the experiment include:-Conducting the experiment in a fume hood to avoid contamination and vaporization-Using precise mass measurements of reactants and products-Ensuring complete mixing of the reactants-Using an accurate timer to measure the duration of the reaction-Using appropriate safety equipment while transferring the products from one container to another
Related to 2Al + 3CuCl2 -> 3Cu + 2AlCl3 Mass of Cu = ?
1. What is the balanced chemical equation for this reaction?
The balanced chemical equation for this reaction is 2Al + 3CuCl2 -> 3Cu + 2AlCl3.
2. What is the molar mass of Cu?
The molar mass of Cu, or copper, is approximately 63.55 grams per mole.
3. How can I calculate the mass of Cu produced in this reaction?
To calculate the mass of Cu produced in this reaction, you can use the molar ratio between Cu and Al. In this reaction, for every 2 moles of Al, 3 moles of Cu are produced. So, if you know the mass of Al used, you can use this ratio to calculate the mass of Cu produced.
4. Is this reaction exothermic or endothermic?
This reaction is exothermic, meaning it releases heat energy as it occurs.
5. How does the mass of the reactants compare to the mass of the products in this reaction?
The mass of the reactants, 2Al and 3CuCl2, is equal to the mass of the products, 3Cu and 2AlCl3. This is because mass is conserved in a chemical reaction, meaning the total mass of the reactants must be equal to the total mass of the products.
21K
108K
