2D-Diamond and 2D-Center Rectangular Lattice Comparison
In summary, a 2D-diamond lattice is a two-dimensional arrangement of atoms or particles in a diamond-like pattern. It has a rhombic symmetry and is studied for potential applications in various fields. This lattice can be created through methods such as molecular beam epitaxy and chemical vapor deposition. It offers advantages such as tunable properties and potential for miniaturization in research and technology. The 2D-center rectangular lattice, with a rectangular symmetry, has similar applications and can also be created through various methods.
Karim Habashy
33
Hi All,
Using (Mirror + Translation in 2D).
I see that Diamond and Center Rectangular Lattice in 2D has the same Symmetry i.e:
1)Horizontal Mirror Plane
2)Vertical Mirror Plane
3)2-Fold Rotation Axis.
and Diamond has Smaller Area.
Then why we say Center Rectangular has higher Symmetry and we take it as the Standard Cell.
Image Attached.
Reference, Edx.org, Course:
Symmetry, Structure and Tensor Properties of Materials, Lecture 7.
Thanks.
Thank you for bringing up this interesting observation. I would like to provide some insight into why we consider the center rectangular lattice to have higher symmetry compared to the diamond lattice.
Firstly, it is important to understand that symmetry is a fundamental concept in materials science, and it plays a crucial role in understanding the properties and behavior of materials. In 2D, symmetry is described by the presence of mirror planes, rotation axes, and translation vectors.
In the case of the diamond and center rectangular lattices, both have the same number of symmetry elements, as you have correctly identified. However, the placement and orientation of these elements differ between the two lattices. In the diamond lattice, the mirror planes and rotation axes are not aligned with the lattice vectors, whereas in the center rectangular lattice, they are aligned. This alignment of symmetry elements in the center rectangular lattice results in a higher degree of symmetry compared to the diamond lattice.
Additionally, as you have mentioned, the diamond lattice has a smaller area compared to the center rectangular lattice. This means that the diamond lattice does not fully fill the 2D space, and there are gaps between the lattice points. On the other hand, the center rectangular lattice fully fills the space, resulting in a more regular and symmetric arrangement of lattice points.
In summary, while both lattices have the same number of symmetry elements, the alignment and regularity of these elements in the center rectangular lattice give it a higher degree of symmetry. This is why it is considered the standard cell in 2D crystallography.
I hope this helps clarify the concept of symmetry in these two lattices. If you have any further questions, please do not hesitate to ask.
Related to 2D-Diamond and 2D-Center Rectangular Lattice Comparison
1. What is a 2D-Diamond lattice?
A 2D-diamond lattice is a two-dimensional arrangement of atoms or particles in a diamond-like pattern. It consists of two interlaced triangular sublattices, forming a rhombic structure.
2. How does the 2D-Diamond lattice compare to the 2D-Center Rectangular lattice?
The main difference between the two lattices is their symmetry. While the 2D-Diamond lattice has a rhombic symmetry, the 2D-Center Rectangular lattice has a rectangular symmetry. This results in different properties, such as different lattice constants and band structures.
3. What are the applications of 2D-Diamond and 2D-Center Rectangular lattices?
Both lattices have been extensively studied for their potential applications in various fields, such as photonic and phononic crystals, electronic devices, and catalysis. Their unique structures and properties make them promising candidates for these applications.
4. How are these lattices created or synthesized?
2D-Diamond and 2D-Center Rectangular lattices can be created through various methods, including molecular beam epitaxy, chemical vapor deposition, and self-assembly techniques. These methods involve the controlled deposition of atoms or molecules on a surface to form the desired lattice structure.
5. What are the advantages of using 2D-Diamond and 2D-Center Rectangular lattices in research and technology?
Some potential advantages of these lattices include their tunable properties, large surface-to-volume ratio, and potential for miniaturization. They also provide a platform for studying fundamental physical phenomena and have potential for applications in nanotechnology and advanced materials.
  • Atomic and Condensed Matter
