2D Kinematics; Flying Saucer observed with two velocities
In summary, a flying saucer with constant acceleration is observed with positions and velocities shown in a graph. To find the saucer's acceleration, knowledge of elapsed time between the two velocity measurements is needed. Assuming constant acceleration, the equations for displacement and velocity can be used to find the acceleration in both the horizontal and vertical directions.
oddjobmj
306
A flying saucer maneuvering with constant acceleration is observed with the positions and velocities shown below:
http://imgur.com/gq1g0
What is the saucer's acceleration?
*note: I created the image in paint and I did forget to label the vectors. The one starting at the origin is '1' and the second vector is '2'.
EDIT:
a(vector)=lim (as delta t approaches 0) delta v(vector)/delta t(vector)
That equals:
dv(vector)/dt
(dvx/dt)i + (vy/dt)j = a(vector)
[STRIKE]The portion of the chapter that most closely relates to this, as far as I can see, is the bit on Galilean transformation of velocity. 'If we know an object's velocity measured in one reference frame, we can transform it into the velocity that would be measured by an experimenter in a different reference frame.'
That method simply converts between two reference points which is how I interpret the two different vectors. Same object w/ different reference points yields two different vectors for velocity.
The issue here is that I don't know how to find acceleration of which I understand to be a change in velocity over a change in time. Having not been provided any information on time elapsed I cannot figure out how to find acceleration. I have the answer in the back of the book and see that it's not some trick where it is not accelerating or the acceleration is 0.[/STRIKE]
None of that applies >_< The section this points to suggests you can combine two vectors into one and then somehow come up with instantaneous velocity but it doesn't provide any examples of how to do it; just images. I'm checking google to figure it out but am having a hard time coming up with a reasonable search.
Thank you!
~Odd
It looks like you need to know the time that elapses between the first velocity measurement and the second. Then you could use
a = Δv/Δt in each dimension to find the components of acceleration.
We don't know time, but we do also have distance info. If you assume constant acceleration, then in each dimension you have an a = Δv/Δt equation with unknowns t and a, plus a d=Vi*t +½at² equation with unknowns t and a. Hey, that gives you 2 equations with two unknowns so you can find the acceleration!
Remember to do all that for both x and y directions.
I edited my original post.
I appreciate your help but I don't see how that would help me. The equation d=Vi*t +½at² is familiar but never used in this chapter/section. Shouldn't d=0? If so, it doesn't work out to anything useful. If it equals the only other attainable distance, 1000sqrt(5) (from the overall chance in position between point 1 and 2) it still doesn't help me out.
I must be missing something here because this problem is, I'm sure, very simple.
On the graph, you can see that vector 1 is at x=0, while vector 2 is at x=2000. So the horizontal distance from time 1 to time 2 is 2000 m.
I worked out the horizontal acceleration and it comes to about 10 m/s².
That velocity formula is the very basic accelerated motion formula from a first high school physics course. It applies to any situation where there is constant acceleration. I think that is a reasonable assumption here because there likely are an infinite number of solutions with varying acceleration.
If you wish to do the x and y parts together, you could use the same formulas with your i and j unit vectors.
To find the acceleration of the flying saucer, we can use the equation a = (vf - vi)/t, where vf is the final velocity, vi is the initial velocity, and t is the time elapsed. In this case, we have two different velocities, v1 and v2, and we know that the saucer is accelerating at a constant rate. This means that the change in velocity between v1 and v2 is due to the acceleration of the saucer.
To calculate the acceleration, we can use the equation a = (v2 - v1)/t. However, we do not have the time elapsed. In order to find the acceleration, we need to find the time elapsed between v1 and v2.
To do this, we can use the fact that the saucer is accelerating at a constant rate. This means that the average velocity between v1 and v2 is equal to the average of v1 and v2. So, we can set up the equation (v1 + v2)/2 = (v2 - v1)/t and solve for t. This will give us the time elapsed between v1 and v2.
Once we have the time elapsed, we can plug it into our original equation a = (v2 - v1)/t to find the acceleration of the flying saucer.
FAQ: 2D Kinematics; Flying Saucer observed with two velocities
What is 2D kinematics?
2D kinematics is a branch of physics that studies the motion of objects in two-dimensional space. It involves analyzing the position, velocity, and acceleration of objects as they move in two perpendicular directions.
How is 2D kinematics related to flying saucers?
In the context of flying saucers, 2D kinematics can be used to analyze the motion of a flying saucer as it moves in two dimensions through space. This can help us understand the trajectory, speed, and other characteristics of the flying saucer's movement.
3. What is meant by "two velocities" in relation to a flying saucer?
"Two velocities" refers to the fact that a flying saucer can have two different velocities in the x and y directions. This is because the saucer is moving in two dimensions, and its velocity in each direction can be different at any given moment.
4. How is a flying saucer's motion observed?
A flying saucer's motion can be observed by tracking its position over time. This can be done through various methods such as radar, telescopes, or other tracking devices. By observing the change in position, we can determine the saucer's velocity and acceleration.
5. Why is the study of 2D kinematics important in understanding flying saucers?
Studying 2D kinematics is important in understanding flying saucers because it allows us to analyze and predict their movements, which can help us identify potential patterns or anomalies. This information can also be used in developing technologies to track and potentially even control flying saucers in the future.
