2D Kinematics problem (hill projectile)
In summary, the cannon ball is launched with an initial velocity of 50 m/s 300 above the horizontal. The height of the cliff is h and the impact velocity is v=84.36 m/s.
madeeeeee
87
3. A cannon ball is launched from a cliff with an initial velocity of 50 m/s 300 above the horizontal. If it’s range is 300 m.
a)What is the height of the cliff?
b) What is the impact velocity of the ball right before it strikes the ground?
d=v1t+1/2at^2
d=V*t
Vav=V1+v2/2
How do you find the height and impact velocity?
Horizontal: Vx=Cos30*50= 43m/s
dx= 300m
Vertical: Vy=Sin 30*50=25
a= -9.8 m/s^2
I am really stuck!
You need to derive an equation for the range so that you can plug 300m into it. Try writing out the equations of motion for both the x and y directions. Then solve for the x when y=0 (i.e. when the ball hits the ground).
"initial velocity of 50 m/s 300 above the horizontal."
What do you mean by 300 above the horizontal?
sorry i meant 30 degrees
let the height of cliff be h
let the angle be 30 degrees
range = 50cos30 * time = 300
time = 4root3 seconds
initial vertical velocity is vsin30 = 25 m/s
h = 25 - 1/2gt^2
assuming g = 10m/s^2
= - 215 meters
height is 215 meters
impact velocity is easiest calculated using energy conservation
both the equation of motion and energy conservation will lead to the same equation and asnwer
initial energy = 1/2 m 50^2 + mg 215
final energy = 1/2mv^2
v = 84.36 m/s
I don't know if this is right
The time calculated seems right.
h = 25 - 1/2gt^2
I believe your equation is a little bit wrong.
Y = Vot + 1/2gt^2
Does your teacher accept g as 10 m/s^2?? I hate that...
no sorry i was doing this in my head but should i have acceleration as -9.8 m/s with the negative because my velocity is +
How would you do this problem?
I was just pointing out that your Y displacement formula has Vo multiplied by time.
Y = Vot+1/2gt^2
and yea, gravity would be negative.
i just feel very unsure doing this problem and when i do other problems i need to refer to my previous examples, could you give me some tips that you use to solve these easily?
Thanks
Whenever you have a 2-d kinematics problem I always separate into 2 columns all the known data. In the x-direction and in the y-direction. And if you ever need to know something in specifically the x or y-axis and it seems as though you have insufficient data, then try linking the two by finding time.
That's just me though. And of course keep in my mind which equations solve for which variables: displacement, initial and final velocity, and time.
thank you
FAQ: 2D Kinematics problem (hill projectile)
What is a 2D Kinematics problem in relation to a hill projectile?
A 2D Kinematics problem involving a hill projectile refers to a physics problem that involves the motion of an object (the projectile) on a two-dimensional plane (x-y plane) in the presence of gravity. The hill in this case can be considered as an incline or slope that the projectile is launched from or lands on.
How is the motion of a hill projectile calculated?
The motion of a hill projectile can be calculated using the principles of kinematics, which involves analyzing the object's position, velocity, and acceleration over time. This involves breaking down the motion into its horizontal and vertical components and using equations such as the kinematic equations and vector components to solve for the unknown variables.
What are the key factors that affect the motion of a hill projectile?
The key factors that affect the motion of a hill projectile are the initial velocity of the projectile, the angle at which it is launched, the force of gravity, and the presence of air resistance. These factors can vary depending on the specific problem and can greatly impact the trajectory and distance traveled by the projectile.
What is the significance of solving a 2D Kinematics problem involving a hill projectile?
Solving a 2D Kinematics problem involving a hill projectile can help in understanding and predicting the motion of objects in real-life scenarios, such as a ball rolling down a hill or a car driving up a slope. It also helps in developing critical thinking and problem-solving skills, which are important in the field of science and engineering.
Can the principles of 2D Kinematics be applied to other types of motion?
Yes, the principles of 2D Kinematics can be applied to other types of motion, such as projectile motion, circular motion, and even simple harmonic motion. These principles are based on fundamental laws of physics and can be used to analyze and solve a wide range of motion problems in various scenarios.
