2D Kinematics questions -been stuck fo hours on it
In summary, the problem involves a golf ball being struck and leaving the ground at an initial velocity of 96 m/s on a 60 degree angle. The task is to determine the velocity of the ball 2 seconds after it was struck, using kinematic equations and Pythagoras' theorem. After splitting the initial velocity into horizontal and vertical components, the appropriate kinematic equations can be used to solve for the final velocities in the x and y directions. However, the provided answer of 32.6 m/s at 45 degrees above the horizon seems to be incorrect, and it is recommended to confirm with the teacher before proceeding further.
ja!mee
Okay so here is the problem: A golf ball is struck and leaves the ground at 96 m/s on a 60 angle. Determine the velocity of the ball 2 seconds after it was struck. I have the answer provided, which is 32.6 m/s at 45° above the horizon.
Obviously I need to use the kinematic equations to solve this, and I have a hunch that I will need the Pythagoras as well.
So what I have done is split the initial velocity of 96 m/s into a horizontal component and a vertical component. the horizontal being 48 m/s and the vertical 83.14. and now I am at a loss on how to proceed next... Not sure if I am over thinking the solution, but please help
You can now look in the y direction and use the appropraite kimematic equation to solve for vy at t=2. Then look in the x direction to solve for vx at t=2.
Sorry, I might be a little simple, but I only have the four main equations infront of me and I just can't figure out what one to use. and how do I use a kinematic equation to get a degree answer??
In projectile motion:
the horizontal component is assumed to have no acceleration and thus the velocity is constant.
the vertical component is assumed to have only the acceleration due to gravity acting on it and thus you can use the equation vy2 = vy1 + 2at since acceleration due to gravity is acting downwards, the equation becomes vy2 = vy1 - 2gt, where vy2 is your final vertical velocity, vy1 is your initial vertical velocity, g is acceleration due to gravity(9.8) and t is time
EDIT: after obtaining the vertical and horizontal components of velocity you must use vector addition to solve for the velocity
the angle is the arctangent of the vertical component of velocity divided by the horizontal component of the velocity. The angle you obtain can then be expressed as [x degrees above the horizontal]
That's in the y direction, vy = vy_initial + ayt where ay = -g, and in the x direction, vx = vx_initial + axt where ax = 0.
Okay So I took you guys advise and i did as follows:
vy = vo - 2at where a is equal to negative gravity
vy = 83.14 m/s - 2(-9.81m/s2)(2s)
Vy = 122.34
Vx = Vo - 2at where the vertical acceleration is 0
Vx = 48 m/s -[STRIKE] 2(0)(t)[/STRIKE]
Vx = 48 m/s
tan ° = 48/122.34
[STRIKE]tan-1+ tan-1[/STRIKE]°= tan-1(48/122.34)
° = 21.42
but these are not the answers that I need to be ending up at. My answers have been provided for me they should be 32.6 m/s at 45° above the horizon. I have indeed tried these steps above before I posted, and gotten the same answers, I just don't know where I am going wrong
I corrected the typos in the kinematic equations but I guess you missed it. So here they are again:
In the y direction,
vy = vy_initial + ayt, where ay = -g,
vx = vx_initial + axt, where ax = 0.
Watch plus and minus signs...
where did those answers come from...they are way off..?
The answers are provided from my teacher, I was wondering as well if the answers provided where correct. I had a sneaky suspicion that they where not, as I do not normally struggle this bad on a question like this.
Maybe I will just confirm with my teacher, before I get anymore into the question.
than answer I keep getting to is (now that I've corrected my signs) , that the velocity is 43.94 m/s at 47.53° above the horizon?? Does this sound more correct
I don't know how you are getting that answer...checking the maths,
In the y direction,
vy = 83.14 -9.8(2) = 63.54 m/s
vx = vx_initial + axt, where ax = 0,
vx = 48 + 0 = 48 m/s
V = sqrt(63.542 + 482)
V = 80 m/s
Tan-1θ = 63.54/48 = 1.32
θ = 53°
Related to 2D Kinematics questions -been stuck fo hours on it
What is 2D kinematics?
2D kinematics is the study of motion in two dimensions, where an object's position, velocity, and acceleration are described using two-dimensional vectors.
How is 2D kinematics different from 1D kinematics?
1D kinematics only considers motion in one dimension (usually along a straight line), while 2D kinematics takes into account motion in two dimensions (usually along a horizontal and vertical axis).
What are the equations used in 2D kinematics?
The most frequently used equations in 2D kinematics are displacement (Δx = xf - xi), velocity (v = Δx/Δt), and acceleration (a = Δv/Δt).
How do I solve 2D kinematics problems?
In order to solve 2D kinematics problems, you will need to break down the motion into its horizontal and vertical components, and then use the relevant equations to solve for the unknown quantities.
What are some common mistakes to avoid when solving 2D kinematics problems?
Some common mistakes to avoid include forgetting to consider both horizontal and vertical components, mixing up signs for direction (positive vs negative), and not using the correct equations for the given problem.
