2D Laplacian in polar coordinates
So you only need to impose the constraints on ##\Theta(0)=\Theta(2\pi)## and ##\Theta'(0)=\Theta'(2\pi)## to get a discrete set of solutions for ##\lambda##.In summary, the 2D Laplacian in polar coordinates can be written as a differential equation using separation of variables. To find non-trivial solutions, the boundary conditions must be satisfied, including ##\Theta(0)=\Theta(2\pi)## and ##\Theta'(0)=\Theta'(2\pi)##, leading to a discrete set of solutions for ##\lambda##.
Mayan Fung
131
The 2D Laplacian in polar coordinates has the form of
$$ \frac{1}{r}(ru_r)_r +\frac{1}{r^2}u_{\theta \theta} =0 $$
By separation of variables, we can write the ## \theta## part as
$$ \Theta'' (\theta) = \lambda \Theta (\theta)$$
Now, the book said because we need to satisfy the condition ## \Theta (0)=\Theta (2\pi)##, ##\lambda = n^2## with n =1,2,3...
I tried this in detailed steps.
##\Theta (\theta) = Acos\sqrt{\lambda}\theta + Bcos\sqrt{\lambda}\theta##
With the BC,
## B = Acos(\sqrt{\lambda}2\pi) + Bsin(\sqrt{\lambda}2\pi) ##
This is just an equality but not an identity. Why can't I conclude that
## B = \frac{cos(\sqrt{\lambda}2\pi)}{1-sin(\sqrt{\lambda}2\pi)} A ##
instead of imposing constraint on ##\lambda##
Thanks!
Because you also need to satisfy ##\Theta'(0) = \Theta'(2\pi)##. For general lambda that gives you a system of equations that lead to trivial solutions only. Only for a discrete set of lambda do you get non-trivial solutions.
Note: You are missing the ##\lambda=0## solution.
Likes Mayan Fung
Thank you! Is it also true that ##\Theta^{(n)}(0)=\Theta^{(n)}(2\pi)##?
That follows from the differential equation if you have the other two.
Likes Mayan Fung
Related to 2D Laplacian in polar coordinates
1. What is the 2D Laplacian in polar coordinates?
The 2D Laplacian in polar coordinates is a mathematical operator that is used to describe the behavior of a function in two-dimensional space, specifically in polar coordinates. It is also known as the Laplace operator or the Laplace-Beltrami operator.
2. How is the 2D Laplacian in polar coordinates different from the 2D Laplacian in Cartesian coordinates?
The 2D Laplacian in polar coordinates takes into account the curvature of the coordinate system, whereas the 2D Laplacian in Cartesian coordinates assumes a flat coordinate system. This means that the equations used to calculate the Laplacian differ between the two coordinate systems.
3. What is the significance of the 2D Laplacian in polar coordinates in physics and engineering?
The 2D Laplacian in polar coordinates is used to describe physical phenomena that exhibit rotational symmetry, such as electromagnetic fields, fluid flow, and heat transfer. It is also commonly used in solving problems involving circular or cylindrical geometries.
4. How is the 2D Laplacian in polar coordinates calculated?
The 2D Laplacian in polar coordinates can be calculated using the formula: ∇²f = 1/r*(∂/∂r)(r*(∂f/∂r)) + 1/r²*(∂²f/∂θ²). This takes into account the radial and angular components of the coordinate system.
5. What are some applications of the 2D Laplacian in polar coordinates?
The 2D Laplacian in polar coordinates is used in a variety of fields, including physics, engineering, and mathematics. It is commonly used in solving partial differential equations, as well as in image processing and computer graphics for edge detection and smoothing. It also has applications in quantum mechanics and fluid dynamics.
  • Differential Equations
