2D Projectile Motion - Minimum Speed
In summary, the problem involves finding the minimum speed at which a salmon must leave the water, at a given angle, in order to continue upstream and reach its breeding grounds. The given information includes the acceleration of gravity, the distance from the waterfall, and the height of the waterfall. The solution involves finding equations of motion for both the x and y directions, and using them to solve for the initial velocity (Vox and Voy) of the salmon. The value of 6.179 used in the attempt at a solution is incorrect and the calculation for time (t) is also incorrect.
stickyriceyum
Salmon often jum waterfalls to reach their breeding grounds.
The acceleration of gravity is 9.81 m/s^2
Starting 1.73 m from a waterfall .0386 m in height, at what minimum speed must a salmon jumping at an angle of 44.3 degrees leave the water to continue upstream? Answer in units of m/s.
Vox = Vocos(theta)
Vox = 6.179cos(44.3) = 4.42
Voy = Vosin(theta)
Voy = 6.179sin(44.3) = 4.316
- I drew a graph:
x-axis labeled as 1.73m and the y-axis labeled as .386m
- Tried to find time:
t = (sqrt) 2(h)/g
t = (sqrt) 2(.386)/9.81
t = .28 seconds <-- I think this may be wrong.
- Tried to find Vo:
Vo = x/t
Vo = 1.73/.28
Vo = 6.179
Now plugged Vo result to find components:
Vox = Vocos(theta)
Vox = (6.179)cos(44.3)
Vox = 4.42
Voy = Vosin(theta)
Voy = (6.179)sin(44.3)
Voy = 4.316
... I'm not sure what to do next. Am I supposed to use the Pythagorean Theorem? And find the tangent? I have no clue. All help would be appreciated. =)
I am sorry to ask this, but are you sure you did actually read the problem?
You have to FIND the initial velocity, it is not give.
The angle is given, so you don't need to find it (by using tangent...).
Where did you get the value of 6.179 from?
"t = (sqrt) 2(h)/g
t = .28 seconds <-- I think this may be wrong."
You are right (that it is wrong). The vertical motion has initial speed (voy):
y=voy*t-1/2*g*t^2
What yo have to do is to write equations of motion for both x and y direction and solve them to find vox and voy.
Hint: you can start by finding what is voy in order to reach the given height.
As a scientist, your approach to solving this problem is correct so far. You have correctly found the horizontal and vertical components of the initial velocity of the salmon.
To find the minimum speed required for the salmon to jump the waterfall, you need to consider the conservation of energy. At the top of the waterfall, the salmon will have both potential and kinetic energy. At the bottom of the waterfall, the salmon will only have kinetic energy. Therefore, the minimum speed required for the salmon to jump the waterfall will be equal to the initial velocity at the bottom of the waterfall, which is the horizontal component you have already calculated (4.42 m/s).
You can also use the Pythagorean theorem to calculate the magnitude of the initial velocity, which will be equal to the minimum speed required for the salmon to jump the waterfall. So, using the horizontal and vertical components you have calculated, the minimum speed required for the salmon to jump the waterfall is:
V = sqrt(Vox^2 + Voy^2)
V = sqrt((4.42 m/s)^2 + (4.316 m/s)^2)
V = 6.22 m/s
Therefore, the minimum speed required for the salmon to jump the waterfall is 6.22 m/s.
FAQ: 2D Projectile Motion - Minimum Speed
1. What is 2D Projectile Motion?
2D Projectile Motion is the motion of an object that is launched or thrown in two dimensions, typically represented by the x and y axes. This type of motion involves both horizontal and vertical components, and is affected by factors such as gravity and air resistance.
2. What is the minimum speed required for a projectile to reach a certain height or distance?
The minimum speed required for a projectile to reach a certain height or distance depends on the angle at which it is launched and the acceleration due to gravity. This can be calculated using the equation v = √(gh/2sin^2θ), where v is the minimum speed, g is the acceleration due to gravity, h is the desired height or distance, and θ is the launch angle.
3. How does air resistance affect 2D Projectile Motion?
Air resistance, also known as drag, can significantly impact the motion of a projectile by slowing it down. The amount of air resistance depends on the shape and size of the object, as well as the density of the air. This can be accounted for in calculations by using a drag coefficient.
4. How is the range of a projectile affected by its launch angle?
The range, or horizontal distance traveled, of a projectile is affected by its launch angle. The maximum range is achieved when the projectile is launched at a 45 degree angle. As the angle increases or decreases from 45 degrees, the range decreases.
5. Can the speed of a projectile be increased in mid-air?
In most cases, the speed of a projectile cannot be increased in mid-air without external forces acting on it. Once the projectile is launched, its speed will decrease due to air resistance and gravity. However, if the projectile is launched from a higher elevation or accelerated by a force, its speed may increase in mid-air.
