2nd Born term calculation (potential scattering)
In summary, the 2nd Born term calculation is a mathematical method used in potential scattering to accurately calculate the scattering amplitude of a particle after multiple collisions with a potential field. It takes into account the effects of both the initial and final states of the particle, as well as the interactions between the particle and the potential field. The calculation involves iteratively calculating the scattering amplitude, incorporating the effects of previous collisions, until the desired level of accuracy is achieved. The significance of the 2nd Born term is that it allows for a more accurate understanding of the dynamics of the scattering process and can be applied in various areas of physics, such as nuclear physics, atomic and molecular physics, and high energy particle physics. However, it has limitations in situations
CyBeaR
2nd Born term calculation problem (potential scattering)
I'm trying to get a 2nd Born term for scattering amplitude in momentum representation (potential scattering).
I take potential of the form:
[tex]V \left( r \right) = \gamma r^{-1} \exp \left( \frac{-r}{R} \right) \; , R >0[/tex]
and it's form in momentum representation is:
[tex]\left\langle \mathbf{p'} \vert V \vert \mathbf{p} \right\rangle = \frac{\gamma}{2 \pi^2} \frac{1}{R^{-2}+ \left(\mathbf{p'}-\mathbf{p}\right)^2}[/tex]
2nd Born term is of the form:
[tex]\left\langle \mathbf{p'} \vert VGV \vert \mathbf{p} \right\rangle = \int d^3 q \frac{\left\langle \mathbf{p'} \vert V \vert \mathbf{q} \right\rangle \left\langle \mathbf{q} \vert V \vert \mathbf{p} \right\rangle }{k^2 - q^2 + i \epsilon } [/tex]
where [tex]k[/tex] is the length of the momenta [tex] \mathbf{p'} [/tex] and [tex] \mathbf{p}[/tex] and [tex]0< k \leq 1[/tex]
After applying Feynman method:
[tex] \frac{1}{ab} = \frac{1}{2} \int_{-1}^1 d\alpha \left( a \frac{1+\alpha}{2}+b \frac{1-\alpha }{2} \right)^{-2} [/tex]
with:
[tex]a=R^{-2}+ \left(\mathbf{p'}-\mathbf{q}\right)^2 , \; b=R^{-2}+ \left(\mathbf{q}-\mathbf{p}\right)^2[/tex]
to:
[tex]\int d^3 \mathbf{q}\frac{1}{a b \left( k^2 - q^2 + i \epsilon \right)}[/tex]
i'm getting two integrals to evaluate. One (easly done by using partial fractions):
[tex]-2 i \pi^2 k \int_0^1 d\alpha (f^2 - k^2 \tau^2 \alpha^2)^{-1}=-\frac{i \pi^2}{\tau f} ln\left|\frac{f+k\tau}{f-k\tau}\right|[/tex]
and 2nd:
[tex]- 2 \pi^2 R^{-2} \int_0^1 d\alpha (4 R^{-2}+\tau^2 - \tau^2 \alpha^2)^{-1/2} (f^2 - k^2 \tau^2 \alpha^2)^{-1}[/tex]
which is the problematic one.
Variable info:
-> [tex]\tau = 2 k sin\left( \frac{\theta}{2} \right)[/tex]
-> [tex] \theta [/tex] is scattering angle and [tex]0\leq \theta \leq \pi[/tex]
-> [tex]f^2 = R^{-4} + 4R^{-2}k^2 + k^2 \tau^2[/tex]
I've tried substitution like:
[tex]\sqrt{4R^{-2}+\tau^2 -\tau^2 \alpha^2}=\alpha \lambda -\sqrt{4R^{-2}+\tau^2}[/tex]
or
[tex]\lambda = \frac{4R^{-2}+\tau^2-\tau^2 \alpha^2}{\sqrt{4R^{-2}+\tau^2}-\tau \alpha} [/tex]
- where [tex]\lambda[/tex] is new integration variable in both cases - but that leads to cumbersome results.
Maybe someone can explain to me how to calculate second integral or share some tricks which can be applied to such integrals.
Any advice will be greatly appreciated.
Cheers!
Hello there,
Thank you for sharing your problem with us. I understand the importance of finding solutions to complex calculations like this one. After reading through your forum post, I have a few suggestions that may help you in your calculation.
Firstly, have you considered using numerical methods to solve the integral? This may be a faster and more accurate approach compared to analytical methods, especially for complex integrals like the one you are dealing with. There are many numerical integration techniques available, such as the trapezoidal rule or Simpson's rule, that may be useful in this case.
Another suggestion would be to try and simplify the integral before trying to evaluate it. This can be done by using trigonometric identities or by making appropriate substitutions. For example, you could try substituting \tau and f^2 in terms of \alpha to make the integral more manageable.
Lastly, have you checked for any existing methods or techniques that may be applicable to your integral? It is always helpful to see if other scientists have faced a similar problem and have found a solution or approach that may be useful to you.
I hope these suggestions help you in finding a solution to your problem. Keep up the good work and don't hesitate to seek help or collaborate with other scientists to find solutions to complex problems. Good luck!
FAQ: 2nd Born term calculation (potential scattering)
What is 2nd Born term calculation in potential scattering?
The 2nd Born term calculation is a mathematical method used in potential scattering to calculate the scattering amplitude of a particle after multiple collisions with a potential field. It takes into account the effects of both the initial and final states of the particle, as well as the interactions between the particle and the potential field.
How is the 2nd Born term calculated?
The 2nd Born term is calculated by first determining the scattering amplitude of the particle after a single collision with the potential field. This is then used as an input into the second iteration of the calculation, where the scattering amplitude is calculated again, taking into account the effects of the first collision. This process is repeated until the desired level of accuracy is achieved.
What is the significance of the 2nd Born term in potential scattering?
The 2nd Born term is significant because it allows for a more accurate calculation of the scattering amplitude, taking into account multiple collisions and interactions with the potential field. This leads to a better understanding of the dynamics of the scattering process and can help in making predictions about the behavior of particles in the presence of a potential field.
What are the limitations of the 2nd Born term calculation?
The 2nd Born term calculation assumes that the interactions between the particle and the potential field are weak, and therefore it may not be accurate in situations where the interactions are strong. Additionally, it is a perturbative method, meaning it may not yield accurate results for highly energetic particles.
In what areas of science is the 2nd Born term calculation used?
The 2nd Born term calculation is used in various areas of physics, such as nuclear physics, atomic and molecular physics, and high energy particle physics. It is also used in other fields related to potential scattering, such as quantum mechanics and quantum field theory. It has applications in understanding the behavior of particles in accelerators, nuclear reactions, and other scattering experiments.
