Fluidman117
- 34
I would like to solve a 2nd Order Differential Equation using the Improved Euler Method. The 2nd ODE is a Mass-Spring-Damper equation. I tried coming up with an solution for the Improved Euler Method, but not entirely sure. Can you help me and have a look if this is correct?
This solution assumes that inital conditions for x and u are known.
Forced Mass-Spring-Damper equation:
[itex]m\ddot{x} + b\dot{x}+kx = F[/itex]
Converting the equation to a pair of first order differential equations:
[itex]u=\dot{x}[/itex]
[itex]\dot{u}=\ddot{x}[/itex]
And thus we have:
[itex]\dot{u}=\frac{1}{m}\left[F-bu-kx\right][/itex]
The forward Euler solution would result in:
[itex]x_{n+1}=x_{n}+dt*u_{n}[/itex]
[itex]u_{n+1}=u_{n}+dt*\dot{u_{n}}=u_{n}+dt*\frac{1}{m}\left[F_{n}-bu_{n}-kx_{n}\right][/itex]
And the Improved Euler solution would be:
[itex]u_{n+1}=u_{n}+dt*\dot{u_{n}}=u_{n}+\frac{dt}{2} \left[ \frac{1}{m} \left[F_{n}-bu_{n}-kx_{n}\right]+\frac{1}{m}\left[F_{n+1}-bu_{n+1}-kx_{n+1}\right] \right][/itex]
In the last equation, does the last [itex]F[/itex] needs to be [itex]F_{n+1}[/itex] like I have it?
Thanks a bunch, if you have time to have a look at it!
