How Do You Solve a 2nd Order Linear Non-Homogeneous DE with Imaginary Roots?
In summary, when solving a 2nd order linear non-homogeneous DE where it is equal to a constant, superposition of 2 solutions occurs when the roots of the auxiliary equation are imaginary. The particular solution can be found by solving for a constant k using q(0), q'(0), q''(0). It is not always necessary to use Euler's identity in this case. In regards to another DE equal to xsinx, the solution can have derivatives with terms xsinx, xcosx, sinx, cosx by the product rule. To prove that these functions are linearly independent, one must show that their linear combinations always result in a non-zero function.
mathnerd15
109
when you solve a 2nd order linear non-homogeneous DE, where it is equal to a constant as in Kirchoff's 2nd Law and the roots of the auxiliary equation are imaginary then you have superposition of 2 solutions. so the particular solution is equal to a constant k and you can solve for this by taking q(0), q'(0), q''(0) and it will have a constant form? I'd like to spend some time studying the theory of this. is it always necessary to use Euler's identity?
[tex]q(t)=\frac{-1}{25(25e^{20t})}cos(10\sqrt{46}t)+\frac{21}{50\sqrt{46}e^{20t}}sin(10 \sqrt{46}t)+\frac{1}{25}[/tex]on another question in the DE which is equal to xsinx can only have derivatives with terms xsinx, xcosx, sinx, cosx by the product rule. so in this case you guess the solution as Axsinx+Bxcosx+Csinx+Dcosx... how do you prove then that these functions are linearly independent?
By definition, a homogeneous ODE is equal to zero.
Likes 1 person
Related to How Do You Solve a 2nd Order Linear Non-Homogeneous DE with Imaginary Roots?
1. What is a 2nd order linear homogeneous differential equation?
A 2nd order linear homogeneous differential equation is a mathematical expression that includes a dependent variable, its first and second derivatives, and constant coefficients. It is considered linear if the dependent variable and its derivatives are raised to the first power and homogeneous if all terms in the equation have the same degree of the dependent variable.
2. How do you solve a 2nd order linear homogeneous differential equation?
To solve a 2nd order linear homogeneous differential equation, you must first identify the values of the constant coefficients and the dependent variable. Then, you can use various methods such as the method of undetermined coefficients or the method of variation of parameters to find the general solution.
3. What is the general solution of a 2nd order linear homogeneous differential equation?
The general solution of a 2nd order linear homogeneous differential equation is a formula that includes arbitrary constants and satisfies the original differential equation. It can be written in the form of a linear combination of two linearly independent solutions.
4. What is the role of initial conditions in solving a 2nd order linear homogeneous differential equation?
Initial conditions are values given for the dependent variable and its derivatives at a specific point. They are used to determine the values of the arbitrary constants in the general solution and find a particular solution that satisfies both the differential equation and the given initial conditions.
5. What are some real-life applications of 2nd order linear homogeneous differential equations?
2nd order linear homogeneous differential equations have many applications in various fields such as physics, engineering, and biology. They can be used to model oscillations, vibrations, and other physical phenomena. They are also important in understanding the behavior of electrical circuits and population dynamics.
  • Differential Equations
