2nd order, linear, homogeneous proof
In summary: So if the Wronskian is not 0, then the only solution to af(x)+ bg(x)= 0 is a= b= 0. In summary, the Wronskian is used to show that the solutions to a second order linear differential equation are independent, and therefore any linear combination of those solutions will encompass all possible solutions.
MathewsMD
433
Hi,
I was wondering if someone could provide either a bit of intuition or a mathematical proof (or both) as to why if the Wronskian (W(f,g)) does not equal 0 for all t in an interval, then the linear combinations of the two functions f and g encompass ALL solutions. Is there any particular reason that this can be known to include all possible solutions for the second order, linear, homogeneous differential equation?
Any insight would be greatly appreciated!
Any help at all is appreciated!
The equation has two constants of integration, and two possible solutions: y = c1*y1 + c2*y2, where y1(t0) = 1, y1'(t0) = 0, y2(t0) = 0, y2'(t0) = 1 for independent-variable value t = t0. It's easy to show that y1 and y2 have a nonzero Wronskian.
As to how the Wronskian behaves in general, consider that this differential equation has general form p2*y'' + p1*y'+ p0*y = 0, a form which both f and g satisfy.
Take the derivative of the Wronskian, W(f,g), and plug in the differential equation's values for f'' and g''. You will find a differential equation for W: W' = (something) * W. You can then solve it for W, though you will have an integral involving p2, p1, and p0. You will now be able to have an idea of what is necessary to make the Wronskian zero if it had been nonzero somewhere.
MathewsMD said:
Hi,
You are leaving out quite a lot here! For one thing "the linear combinations of the two functions f and g encompass ALL solutions" to what problem?! I presume you are referring to a second order linear differential equation. It can be shown that the set of all solutions to an "nth order" linear differential equation form an "n dimensional" vector space so if you can find n independent solutions, they form a basis for the vector space of all solutions. We use the Wronskian to show that the solutions are independent. For if f and g are solutions to a given second order differential equation then they are "independent" if and only if af(x)+ bg(x)= 0, for all x the a= b= 0. Of af(x)+ bg(x)= 0, for all x, then af'(x)+ bg'(x)= 0. That will have a unique solution, which would obviously be a= b= 0, if and only if the determinant of coefficients
[tex]\left|\begin{array}{cc}f(x) & g(x) \\ f'(x) & g'(x)\end{array}\right| \ne 0[/tex]
That is, of course, the Wronskian.
I can provide a response to your question. The Wronskian is a mathematical determinant that is used to determine the linear independence of two functions. In the context of a second order, linear, homogeneous differential equation, the Wronskian is used to determine whether two solutions (in this case, f and g) are linearly independent or not.
If the Wronskian is non-zero for all values of t in a given interval, it means that the two solutions are linearly independent. This is because the Wronskian captures the linear relationship between the two functions. If the Wronskian is non-zero, it means that the two functions are not multiples of each other and thus, they are not dependent on each other.
In the context of a second order, linear, homogeneous differential equation, this means that the two solutions (f and g) are not dependent on each other and they encompass all possible solutions. This can be understood intuitively as well - if the two solutions are linearly independent, they can be combined in different ways to create all possible solutions to the given equation.
In terms of a mathematical proof, it can be shown that the general solution to a second order, linear, homogeneous differential equation can be expressed as a linear combination of two linearly independent solutions. Therefore, if the Wronskian is non-zero, it means that the two solutions are linearly independent and thus, the linear combination of these solutions will encompass all possible solutions.
In summary, the Wronskian being non-zero for all values of t in a given interval is a necessary condition for the linear combinations of two solutions to encompass all possible solutions to a second order, linear, homogeneous differential equation. This can be understood intuitively and mathematically. I hope this helps answer your question!
FAQ: 2nd order, linear, homogeneous proof
1. What is a 2nd order linear homogeneous proof?
A 2nd order linear homogeneous proof is a mathematical method used to show that a second order linear differential equation with homogeneous boundary conditions has a unique solution. It involves manipulating the equation algebraically and using mathematical properties to arrive at a solution.
2. How do you know if an equation is 2nd order linear homogeneous?
An equation is considered 2nd order linear homogeneous if it can be written in the form: a(d^2y/dx^2) + b(dy/dx) + cy = 0, where a, b, and c are constants and y is the dependent variable. This form is also known as the standard form of a second order differential equation.
3. What is the difference between a linear and nonlinear equation?
A linear equation is an equation where the highest power of the variable is 1. This means that the equation can be represented by a straight line on a graph. A nonlinear equation, on the other hand, has a variable raised to a power greater than 1. This results in a curved line on a graph.
4. What are homogeneous boundary conditions?
Homogeneous boundary conditions are conditions that are applied to both ends or boundaries of a system or function. In the context of a 2nd order linear homogeneous proof, these conditions are set at the beginning and end points of the equation and are used to determine a unique solution.
5. Why is a 2nd order linear homogeneous proof important in science?
2nd order linear homogeneous proofs are important in science because they provide a systematic way to solve and understand a wide range of physical phenomena. Many natural processes can be modeled using second order differential equations, making this proof essential in fields such as physics, chemistry, and engineering.
