2nd Order Non-Linear ODE in MATLAB Issues
In summary, the conversation is about using a solver to modify a problem involving a wire with a current flowing through it to find the temperature distribution with respect to position. The DE is given and the code being used is also provided. The conversation includes discussions about the target boundary condition, the use of ode45 for nonlinear ODEs, setting the dT/dx (x=0) = 0 boundary value, and potential errors in the code.
TurboRegal
Hey everyone,
Having some trouble here using the solver we were supplied and modifying it to fit our problem...
I have a wire with a current flowing through it. I'm trying to find the temperature distribution wrt. position in the wire.
BV's are:
T(x=L/2) = 300K
dT/dx (x=0) = 0
(Apparently this is suppose to result in a symmetrical distribution around 0 from -L/2 -> L/2)The DE is as follows:
http://img165.imageshack.us/img165/3875/2ndorderodetm7.jpg
Which I've rearranged to:
d2y2/dx2 = phi1 * y1 + phi2 * (y1)4 - constants
Where y1 = T, y2 = dT/dx, and phi1, phi2, constants are just the collected constant terms...
Here is the code I'm using, in it c->T, r->x, sorry the terms were different and I haven't had time to change them yet...
%ThieleBVP.m - Example 4
clear
clc
global phi
global phi2
global constant
%Maximum number of secant iterations
maxsec = 20;
%Absolute error tolerance
tol = 1e-15;
%Arrays to store the guessed boundary condition, c(0), and the residual, R
c0 = zeros(maxsec, 1);
R = zeros(maxsec, 1);
%Set the phi is for T, phi2 is for T^4, constant is the rest of the
%collected terms
%Setting Constants...
kcon = 72
h = 2000
eps = 0.1
sig = 5.67 * 10^-8
Icur = 2
rowe = 32*10^-8
Tinf = 300
D = 80*10^-6
L = 4*10^-3
%Calculating Stuff...
RHS = -(Icur^2*rowe)/(kcon*(pi/4*D^2)^2)
LHS1 = -4*h/(kcon*D)
LHS2 = -4*eps*sig/(kcon*D)
%Finding the final constants...
phi = -LHS1
phi2 = -LHS2
constant = RHS + LHS1*Tinf + LHS2*Tinf
%Target boundary condition to shoot for, c(1)
c1_true = 300;
%First guess of the unknown boundary condition, c0 = c(0)
c0(1) = 280;
%Shooting loop
%rspan = [0 1]; % integration interval
rspan = [-L/2 L/2];
% first shot
i = 1;
yini = [c0(i) 0]; % initial conditions
[r,y] = ode45('ODEs',rspan,yini);
R(i) = y(length(r),1) - c1_true;
%second shot
i = 2;
c0(i) = 1.05*c0(i-1);
while abs(R(i))>tol
i = i+1;
c0(i) = c0(i-1)-R(i-1)*(c0(i-1)-c0(i-2))/(R(i-1)-R(i-2));
if i == maxsec
display('Maximum no. of iterations reached!');
break;
end
end
plot(r,y(:,1),'ro');
function dydr = ODEs(r,y)
global phi
global phi2
global constant
dydr = zeros(2,1);
dydr(1) = y(2);
dydr(2) = phi*y(1)+phi2*(y(1))^4-constant;
This just results in MATLAB spitting out jibberish.
At the moment, I need to figure out the following:
1) Does ode45 work for nonlinear ODE's?
2) How do I set the dT/dx (x=0) = 0 boundary value? I know this isn't working because if I set the phi2 power above to ^2 instead of ^4, I get:
http://img379.imageshack.us/img379/6339/80553833xt7.jpg
3) Why isn't MATLAB solving this properly?
4) Is the "solver" part of the 1st code even going to work for this type of problem. It was used at first for a 2nd order linear ODE, I'm assuming this is what is causing jibberish?
Thanks for the help...
Fixing a few small errors in my stupid code...
phi = -LHS1
phi2 = -LHS2
constant = RHS + LHS1*Tinf + LHS2*Tinf^4
I think that's all I changed...
Nets me:
http://img292.imageshack.us/img292/453/18650296io7.jpg
http://g.imageshack.us/g.php?h=292&i=18650296io7.jpg
And gives me the error:
Warning: Failure at t=-1.512856e-003. Unable to meet integration tolerances without reducing the step size below the smallest value allowed (3.469447e-018) at time t.
> In ode45 at 355
In ThieleBVP at 70
When I try just going from 0->L/2 and then making is symmetric myself it nets me the following:
This nets me (NO ERRORS):
http://img390.imageshack.us/img390/2945/99880853fh6.jpg
http://g.imageshack.us/g.php?h=390&i=99880853fh6.jpg
But it should be going up in the middle no?
1. Yes
2. If you set TSPAN (the second argument of ode45) to [-L/2 L/2] then Matlab applies the initial conditions at -L/2 and integrates from x = -L/2 to x = L/2. Since you want to apply the initial conditions at x = 0, you have to set TSPAN to [0 L/2] (as you do below). Then you can compute the other half of the solution by symmetry, or by doing another integration but with TSPAN set to [0 -L/2].
What do you mean with it should be going up in the middle? The solution looks fine to me, except that you get a temperature of -600K at x=0 which is physically impossible. Perhaps make sure that your constants are correct?
Related to 2nd Order Non-Linear ODE in MATLAB Issues
1) What is a 2nd order non-linear ODE?
A 2nd order non-linear ODE (ordinary differential equation) is an equation that involves a function, its first derivative, and its second derivative. Non-linear means that the equation is not proportional to its derivatives, making it more complex than a linear ODE.
2) How do I write a 2nd order non-linear ODE in MATLAB?
To write a 2nd order non-linear ODE in MATLAB, you can use the "ode45" function, which is specifically designed for solving non-linear ODEs. You will need to define the function, initial conditions, and the range of values for the independent variable in your code.
3) What is the difference between solving a linear and a non-linear ODE in MATLAB?
The main difference is in the approach used to solve the equation. Linear ODEs can be solved analytically using methods like separation of variables or integrating factors. However, non-linear ODEs require numerical methods, such as Euler's method or Runge-Kutta methods, to approximate the solution.
4) How do I plot the solution to a 2nd order non-linear ODE in MATLAB?
You can use the "plot" function in MATLAB to plot the solution to a 2nd order non-linear ODE. First, you will need to solve the equation using "ode45" and store the output values in a variable. Then, you can use the "plot" function to plot the dependent variable against the independent variable.
5) What are some common issues when solving 2nd order non-linear ODEs in MATLAB?
Some common issues include encountering errors due to incorrect syntax or not defining all the necessary variables in the code. It is also important to check for any singularities or discontinuities in the solution, as these can cause problems for numerical methods. Additionally, the choice of initial conditions and the range of values for the independent variable can also affect the accuracy of the solution.
