MHB 3.1.5 AP Calculus Exam average temperature
The discussion focuses on estimating the derivative W'(12) using the provided temperature data from a tub over 20 minutes. The suggested approach for part (a) is to calculate the average rate of change between the values at t=9 and t=15. For part (b), participants question whether the citation of the problem is complete and if it affects the calculations. In part (c), the average temperature over the interval is discussed, with participants considering whether the approximation is optimistic or underestimates the true average. The conversation emphasizes the importance of correctly interpreting the problem and using the data effectively.
karush
MHB
309 average temperature
$$\begin{array}{|c|c|c|c|c|c|c|}
\hline
t\,(minutes)&0&4&9&15&20\\
\hline
W(t)\,(degrees Farrenheit)&55.0&57.1&61.8&67.9&71.0\\
\hline
\end{array}$$
The temperature of water in a tub at time t is modeled by a strictly increasing, twice-differentiable function W. where W(t) is measured in degrees Fahrenheit and t is measured in minutes.
At time $t=0$. the temperature of the water is $55^o F$.
The water is heated for 30 minutes, beginning at time $t=0$,
Values of $W(t)$ at selected times t for the first 20 minutes are given in the table above.
a. Use the data in the table to estimate W'(12).
b. Show the computations that lead to your answer. using correct units,
c. For $0\le t \le 20$ the average temperature of the water in the tub is
$\dfrac{1}{20}\int_0^{20} W(t)\, dt$
Does this approximation overoptimistic or underestimate the average temperature of the water over these 20 minutes? Explain.
ok not sure just what kind of equation we need for this since the points are close to a straight line
Re: 309 AP Dalculus Exam average temperature
(a) $W'(12) \approx \dfrac{W(15)-W(9)}{15-9} \, \dfrac{^oF}{min}$
(b) ... is this part a complete citation of the given question? Does part (c) depend on a complete citation of the question in part (b) ?
that was exactly the way it was given
so I presume first they just want average between the first and last point
then they want a addition of the sums of the intervals which would be close.
don't actually know their answer...
  • · Replies 19 ·
