MHB 3-42 Where on ground (relative to position of the helicopter
The discussion focuses on calculating the landing position of a stunt woman dropping from a helicopter 30 meters above the ground, moving upward at 10 m/s and horizontally at 15 m/s. The equations of motion are applied to determine the time of fall, which is approximately 3.7 seconds, and the horizontal distance traveled during this time. The horizontal displacement is calculated to be about 55.5 meters due south from the drop position. The calculations ignore air resistance, simplifying the physics involved. The final conclusion indicates that the foam mats should be placed 55.5 meters south of the helicopter's position at the time of the drop.
karush
MHB
ok this is out of an old textbook and possibly already posted here so..
A movie stunt woman drops from a helicopter that is 30.0 m above the ground and moving with a constant velocity whose components are 10.0 m/s upward and 15.0 m/s horizontal and toward the south. Ignore air resistance.
[a.] Where on the ground (relative to the position of the helicopter when she drops) should the stunt woman have placed the foam mats that break her fall?
well so far... but not sure
$y=y_0+V_0 yt+.5A yt^2$
$0=30+10t[-.5(9.8)t^2]$
so $0=-4.9t^2+10t+30$
later [b.] Draw x-t, y-t, v ft, and v y-t graphs of the motion
Mathematics news on Phys.org
$\Delta x = v_{x_0} \cdot t$
$\Delta y = v_{y_0} \cdot t - \dfrac{1}{2}gt^2$
solve the quadratic for $t$, then calculate $\Delta x$
ok not sure why this doesn't render but it my understanding of the problem
\begin{tikzpicture}[xscale=.4,yscale=.2]
\draw [very thick] (-1,0) -- (20,0);
\draw [thin] (0,0) -- (0,30);
\draw [dashed][->] (0,30) -- (15,30);
\draw [dashed][->] (0,30) -- (0,40);
\draw [dashed][->] (0,30) -- (15,40);
\node
at (0,30) {30 m};
\node
at (15,30) {15 m/s};
\node [above] at (0,40) {10 m/s};
\end{tikzpicture}
\end{tikzpicture}​
$\dfrac{1}{2}gt^2 - v_{y_0} \cdot t + \Delta y = 0 \implies t = \dfrac{v_{y_0} + \sqrt{(v_{y_0})^2 - 2g\Delta y}}{g}$
for the given values, $t \approx 3.7 \, sec$
$\Delta x = v_{x_0} \cdot t \approx 55.5 \, m$ due South of the drop position.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
