MHB (3+√a)^(1/3)+(3-√a)^(1/3) is an integer, find a
  • Thread starter Thread starter lfdahl
    Integer
The discussion focuses on finding positive values of \( a \) such that the expression \( \sqrt[3]{3+\sqrt{a}}+\sqrt[3]{3-\sqrt{a}} \) results in an integer. Various solutions and methods are proposed, including algebraic manipulations and alternative approaches to simplify the expression. Participants share their findings and verify each other's solutions, emphasizing the importance of integer results. The conversation highlights the mathematical principles involved in solving the problem. Ultimately, the goal is to identify all possible positive values of \( a \) that satisfy the condition.
lfdahl
MHB
Determine the positive numbers, $a$, such that the sum:
$$\sqrt[3]{3+\sqrt{a}}+\sqrt[3]{3-\sqrt{a}}$$
is an integer.
Mathematics news on Phys.org
is an integer.
my solution:
let $\sqrt[3]{3+\sqrt{a}}=x$
$\sqrt[3]{3-\sqrt{a}}=y$
consider $x>0,y>0$
$x^3+y^3=(x+y)(x^2-xy+y^2)=6=2\times 3=3\times 2=6\times 1=1\times 6$
now $x+y=2---(1)$
and $x^2-xy+y^2=3$ $\rightarrow xy=\dfrac {1}{3}---(2)$
satisfy the condition $a>0$
$x,y$ are roots of $3t^2-6t+1=0$
$x=\dfrac{3+\sqrt 6}{3}$
$y=\dfrac{3-\sqrt 6}{3}$
and we get :$a\approx 8.963$
if $x+y<0$
$x^3+y^3=(x+y)(x^2-xy+y^2)=6=-2\times -3=-3\times -2=-6\times -1=-1\times -6$
with the same method we may get another "a" or no solution
Albert said:
my solution:
consider $x>0,y>0$
only $x+y=2---(1)$
if $x+y<0$
Would you please show the other $a$ solution?
another solution:
sorry another solution will happen at :
$x+y=1$ and
$x^2-xy+y^2=6,or \,\, 3xy=-5$
which gives $x=1.8844,or\, -0.8844$
both yield $a=13.63$
here ($\sqrt[3]{3+\sqrt a}=x$)
($\sqrt[3]{3-\sqrt a}=y$)
Albert said:
another solution:
$x+y=1$ and
Well done, thankyou Albert!An alternative approach can be found here:
Let \[n = \sqrt[3]{3+\sqrt{x}}+\sqrt[3]{3-\sqrt{x}}, \: \: x >0.\]
Then
\[n^3 = 6+3n\left [ (3+\sqrt{x})(3-\sqrt{x})\right ]^{1/3}\]
Hence, \[\left ( \frac{n^3-6}{3n} \right )^3 = 9-x \Rightarrow x = 9 - \left ( \frac{n^3-6}{3n} \right )^3 > 0.\]
The term $\left ( \frac{n^3-6}{3n} \right )^3$ is monotone increasing and larger than $9$ for $n \ge 3$, so
it suffices to let $n$ be $1$ or $2$:$n = 1$: $x = \frac{368}{27} = 13,\overline{629}$.$n = 2$: $x = \frac{242}{27} = 8,\overline{962}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
