3 Algebra problems that I with.
  • MHB
  • Thread starter namerequired
  • Tags
    Algebra
In summary: And what about negative values of $t$? In summary, Francesco is struggling with three problems and is seeking help. However, the community does not provide direct solutions, but rather guides him through the thought process and asks him to explain his attempts so far. The first problem involves understanding what it means for a matrix to be invertible. The second problem involves using determinant properties and the third problem involves finding the rank of a matrix and writing a line passing through two points. Despite some misunderstandings, Francesco is making progress and the community continues to offer guidance and assistance.
namerequired
Hello everybody, I am Francesco and I would be very grateful if someone could show me the solution for those 3 problems. I have many of them and these are just an example for type, so if I understand I can do the rest of my own. I don't find on google an exact answer to my problems, but all the time something similar but never the same :S. Thank you in advance if you can help the fellow here. (Angry)
1)
This one I don't understand if it is too easy or I am doing it wrong. Because the logical answer is: Coordinate of the point A am I wrong?
2)
3)
Hello Francesco! Welcome to MHB. :) We'll be happy to guide you to a greater understanding of these concepts, but we don't do that by giving you the solution: we'll walk the path with you, instead. Therefore, what did you attempt on questions 2 and 3? Namely, to arrive at their solutions you must answer positively to these questions:
1) Do you know what it means for a matrix to be invertible?
2) Are you familar with determinant properties?
3) Do you know how to find the rank of a matrix?
4) How do you write a line passing through two points?
Hope to hear your answers and further help you. :)
Best wishes,
Fantini.
Hello and welcome to MHB, Francesco! (Wave)
In addition to showing what you have tried as Fantini has stated, we also ask that no more than two questions be posted per thread. This just helps keep a thread from becoming convoluted and hard to follow, particularly if more than one helper is assisting you with different problems at the same time.
It should be a square matrix and it is the opposite of the original one and has to be determined, so it can't have Det = 0.
det A = Det A^T
The position matter
det(AB) = det(A) and det(B)
for invertible matrices det(A) cannot be 0
Row operations to find the diagonal, or check if the det of a sub matrix 2x2, 3x3 is not 0
I look for the coordinate of the 2 points.I hope it is more or less right )) :confused:- Sorry to post more than 2, actually the first question was more a bonus, because I don't really understand if the problem is so easy or so tricky )
Exactly. The information that it is an square matrix is important. Using "opposite" as terminology is not adequate here in my opinion, as I usually associate that word for addition. So consider this: if $B \in \mathbb{R}^{m \times n}$ and $B$ is invertible, then what can you say about $m$ and $n$? This answers more than just $B$: the dimensions of all other matrices are automatically determined.
namerequired said:
det A = Det A^T
The position matter
You are correct. In order to apply that information you need to isolate $X$ in the equation $B^{T} X^{-1} A = C$. Looking at it, we can see some possible orders to do this. I would do as the following:
1) Eliminate $A$ (how?), transpose what the rest (to eliminate $B$), invert and transpose back.
Any other order is essentially an rearrangement of the above.
These are correct, but rather tedious. In particular there are many determinants to be computed, so it's not really a good option. What else can we do? This information is important: the rank of the matrix is always less than or equal to the minimum between the number of rows and columns. Let's apply in this case: we have 4 rows and 3 columns, therefore whatever the rank of the matrix is it has to be less than or equal to 3.
How can we check that? Consider the three columns as vectors and make a linear combination of them, equating to zero. From here you should find the condition on $\beta$ that answers the problem.
This isn't correct. You already have two points and you want a line between them. The most common way (but definitely not unique) to define such line is to write it as
$$r = \{ P_1 + t(P_2 - P_1), \, t \in \mathbb{R} \}.$$
The parameter $t$ controls where you are in the line. At $t=0$ you start at point $P_1$, while at $t=1$ you are at $P_2$. It is usual to think of it as "time" (hence the letter $t$) and this parametrization of the line as the unit time taken to walk the line leaving one point and arriving at another.
Try using it this time: first write the equations of lines $AB$ and then $AC$. What will be the condition for them to intersect? :)
FAQ: 3 Algebra problems that I with.
What is Algebra?
Algebra is a branch of mathematics that deals with symbols and the rules for manipulating these symbols to solve equations and represent relationships between quantities.
Why is Algebra important?
Algebra is important because it helps us understand and solve real-world problems, such as calculating distances and speeds, predicting patterns, and analyzing data. It is also the foundation for higher-level math courses.
What are the basic operations in Algebra?
The basic operations in Algebra are addition, subtraction, multiplication, and division. These operations are used to manipulate variables and solve equations.
How do I solve an Algebra problem?
To solve an Algebra problem, start by identifying the unknown variable and writing it as a letter. Then use the given information and basic operations to create an equation or set of equations. Finally, solve the equation by isolating the variable on one side of the equals sign.
Can you give an example of an Algebra problem and its solution?
Yes, for example, if we have the equation 3x + 4 = 10, we can solve for x by first subtracting 4 from both sides to get 3x = 6. Then, we divide both sides by 3 to get x = 2. The solution to this Algebra problem is x = 2.
