3 dimensional gauge theory
In summary, the dual form of the field strength in a 1+2-dimensional space is a 1-form, not a 2-form. The gauge field, which is also a 1-form, is not the same as the dual of the field strength as it contains derivatives of the gauge potential.
shereen1
51
Dear all
I have a question is the dual of the field strength ( of abelian gauge theory) in 3 dimensional space the same as the gauge field?
I have a formula for the dual field strength and am trying to bring that of gauge field!
Thank you
Do you mean in 1+3-dimensional or 1+2-dimensional space time?
In the first case, the dual is also a 2-form, but generally not the same 2-form. In the second case, the dual is a 1-form, not a 2-form. (In an N dimensional space the dual form of the field strength is N-2-dimensional.)
Likes shereen1
Hi again
no i mean in 1+2 space yes i know that the dual of a k vector is N-k. But am applying it to N= 2+1 space, i am wondering if the dual of the field strength which is a 1 form is the same as the gauge field since both are 1 form in this special 1+2 space.
Thank you again
The field strength is given by ##F = dA## and since ##A## is a one-form, ##F## is a 2-form. Are you thinking of the gauge potential ##A## when you say gauge field? The answer is still no, the dual of ##F## contains derivatives of ##A## and ##A## does not, you would be saying ##*dA = A##.
Likes shereen1
Related to 3 dimensional gauge theory
1. What is 3 dimensional gauge theory?
3 dimensional gauge theory is a mathematical framework used to describe the behavior of particles and fields in three-dimensional space. It is a type of quantum field theory that incorporates the concept of gauge symmetry, which helps to explain the interactions between particles.
2. How is 3 dimensional gauge theory different from other gauge theories?
3 dimensional gauge theory differs from other gauge theories, such as 4 dimensional gauge theory, in that it describes particles and fields in three dimensions rather than four. This makes it a useful tool for studying systems that are more simplified or lower-dimensional than those described by other gauge theories.
3. What is the importance of 3 dimensional gauge theory in physics?
3 dimensional gauge theory has been used to study a wide range of physical phenomena, including particle interactions, quantum chromodynamics, and topological phases of matter. It has also been applied to condensed matter physics, cosmology, and other areas of theoretical physics.
4. Are there any real-world applications of 3 dimensional gauge theory?
While 3 dimensional gauge theory is primarily a theoretical framework, it has been used to make predictions and calculations in various fields of physics. For example, it has been applied to the study of superconductors, topological insulators, and quantum spin liquids.
5. How does 3 dimensional gauge theory relate to other branches of physics?
3 dimensional gauge theory is closely related to other branches of theoretical physics, such as quantum field theory and string theory. It also has connections to classical mechanics, general relativity, and other areas of mathematics, making it a valuable tool for interdisciplinary research.
  • Beyond the Standard Models
