3-link planar manipulator: a statics conceptual question
In summary, the end effector force (Fx and Fy) do not depend on the orientation of the third link (q3), but the end effector moment (Mz) does.
Sunny Sun
Not homework, but I hope this is the right forum to post in:
1. Homework Statement
So we have a 3-link planar manipulator, with lengths L1,L2,L3 and angles q1,q2,q3.
About each of the joints, we may apply a torque, t1,t2,t3.
At the end effector, there will be a force and moment that will fulfill static equilibrium with the input joint torques.
So we can go through the rigmarole and compute the geometric jacobian, which is a map from your angular velocies to your linear endpoint velocities. dx = J dq.
From my image, you can see that the linear velocities care about the orientation of the 3rd limb.
Now, using the principles of virtual work, we can compute the end effector moment and forces that we need in order to balance the input torques.
W = J^-T t, where W is the end effector wrench and t is a joint torques vector and J^-T is the inverse transpose of J.
You can see from the analytical solution, that the Fx and Fy do not depend on the orientation q3 of the 3rd limb!
if that image is too blurry:
https://i.redd.it/nmpd2ekfv3f11.jpg
A puzzling observation. Can someone explain why conceptually that the orientation of the 3rd link has no effect on the Fx and Fy, but does change the end effector moment Mz?
The answer lies in the fact that the end effector force Fx and Fy are only affected by the orientations of the first two links (q1,q2). This is because the Jacobian matrix describes how a change in joint angles affects the linear velocity of the end effector. Since the end effector force is related to the linear velocity, this means that the orientation of the third link has no influence on the linear velocity of the end effector and thus no influence on the corresponding forces. However, the orientation of the third link does affect the angular velocity of the end effector and thus the corresponding moment (Mz) as described in the Jacobian matrix.
FAQ: 3-link planar manipulator: a statics conceptual question
1. What is a 3-link planar manipulator?
A 3-link planar manipulator is a mechanical system consisting of three rigid links connected by joints that allow for movement in a two-dimensional plane. It is commonly used in robotics and automation for tasks such as pick-and-place operations.
2. How does a 3-link planar manipulator work?
The manipulator is controlled by a series of motors and actuators that drive the joints, allowing the end-effector (the tool or object at the end of the manipulator) to move in a desired path and orientation. The movement of each link is constrained by the geometry and kinematics of the system.
3. What is the difference between kinematics and statics in a 3-link planar manipulator?
Kinematics refers to the study of motion and how the different links in the manipulator move relative to each other. Statics, on the other hand, deals with the forces and torques acting on the links and how they affect the stability and equilibrium of the system.
4. How do you calculate the static equilibrium of a 3-link planar manipulator?
The static equilibrium of the manipulator can be calculated using the principles of statics, such as the sum of forces and moments equaling zero. This involves determining the external forces acting on the links and the internal forces at the joints, and then solving for the unknown forces and torques.
5. What are the applications of a 3-link planar manipulator?
A 3-link planar manipulator has a wide range of applications in industries such as manufacturing, assembly, and packaging. It is also used in medical robotics for surgeries and rehabilitation, as well as in space exploration for tasks such as satellite servicing and repair.
