3-particle or more entanglement…
In summary, entanglement is a phenomenon where particles become connected in a non-classical way, allowing for superposition of states between the particles. This can be seen in the example of two-particle entanglement, where measuring one particle can reveal the state of the other. However, understanding entanglement in larger systems, such as billion-particle entanglement, is more complex and requires a deeper understanding. The principle of superposition can be applied to create equations for entanglement in larger systems, but the number of possible states increases significantly. This leads to questions about how measurements affect entanglement and the concept of many worlds or branches in entangled systems. Further understanding of the math behind entanglement, as shown in
bluecap
396
Two particle entanglement such as bell state measurement for quantum teleportation is the example commonly used and in fact you can find everywhere. I understand it like how maximal entanglement can mean measuring one you can know the property of the other.. but it is not very useful for understanding billion-particle entanglement like what happens in macroscopic object like an apple entangling with the environment. So l want to be well versed in more than 2 particle entanglement as billion-particle entanglement is the more realistic everyday scenerio. Let me start with 2 particle entanglement and the math of it:
Entanglement is said to an extension of superposition to different systems. Here is the definition for two systems (this is the example Bhobba kept repeating over the years but he didn't mention the equations for more than 3 particle so I'll try to create the 3 particle equations after the following).
Suppose two systems can be in state |a> and |b>.
If system 1 is in state |a> and system 2 is in state |b> that is written as |a>|b>.
If system 1 is in state |b> and system 2 is in state |a> that is written as |b>|a>.
But we now apply the principle of superposition so that c1*|a>|b> + c2*|b>|a> is a possible state,
The systems are entangled – it is said neither system 1 or system 2 are in a definite state - its in a peculiar non-classical state the combined systems are in.
Let me now generalize it to many systems:
Suppose three systems can be in state |a> and |b> and |c>.
*If system 1 is in state |a> and system 2 is in state |b> and system 3 is in state |c>,that is written as |a>|b>|c>.
*If system 1 is in state |a> and system 2 is in state |c> and system 3 is in state |b>,that is written as |a>|c>|b>
*If system 1 is in state |b> and system 2 is in state |a> and system 3 is in state |c>,that is written as |b>|a>|c>
*If system 1 is in state |b> and system 2 is in state |c> and system 3 is in state |a>,that is written as |b>|c>|a>
*If system 1 is in state |c> and system 2 is in state |a> and system 3 is in state |b>, that is written as |c>|a>|b>
*If system 1 is in state |c> and system 2 is in state |b> and system 3 is in state |a>, that is written as |c>|b>|a>
c1*|a>|b>|c> + c2*|a>|c>|b>+ c3*|b>|a>|c> + c4*|b>|c>|a> + c5*|c>|a>|b> + c6*|c>|b>|a>
is a possible state.
The above convention or equation is correct right? (is the equation or the terms complete). I just read about the 2 particle convention and tried generalizing it to many particle convention above. So please confirm if it is indeed correct.
I’d like to know the following:
1. When you measure only system 2. Do you form new entanglement with system 2 (like you become system 4).. or do you break the entanglement of system 2 from system 1 and 3?
How can you tell if a measurement can break the existing entanglement or form new one?
2. If your measurement produce say c3*|b>|a>|c>, what happens to the other terms? Does the equation means only one term can happen and rest discarded?
3. Measuring c3*|b>|a>|c> means system 1 has state |b>, system 2 has state |a>, system 3 has state |c> right? So if you measure system 2, that means it is in |a>.
4. Let’s assume the state means up or down.. if you measure the system 2 and come up with c3*|b>|a>|c> and |a> is up. How do you know if |b> is up or down.. how do you know if |c> is up or down?
5. Now Many worlds or Branches.. for one particle superposition (of say spin up and down.. I understand the entanglement to observers or other systems is many worlds as taught by Peterdonis). But in the case of c1*|a>|b>|c> + c2*|a>|c>|b>+ c3*|b>|a>|c> + c4*|b>|c>|a> + c5*|c>|a>|b> + c6*|c>|b>|a>, is the many worlds each term?
6. Please answer using the above example and math.. I still don’t understand the GHZ entanglement even after reading many website about it but understanding the math above would enable me to start attempting to understand it. Thanks.
7. Thanks very much for the help
Likes ISamson
There are 27 possible states for the last "equation".
Once those are written, the answers to your questions will become evident.
I am not going to try to explain it in your terms, because there is a lot more to specify. Generally, an entangled state of N particles will have some number of permutations, where there is some known or conserved observable.
For example, you might have total spin be +1. If you have 3 particles combining to be +1, and measure one to be +1, you know the other two are a permutation where one is +1 and the other is -1. This is also a spin entangled entangled state. If you instead measured one to be -1, you know the other two are +1 and the other is +1. This is not a spin entangled entangled state because there is no superposition.
At any rate, there are experiments involving entanglement of large N, where N>>1000. Please keep in mind that there is also monogamy of entanglement. A particle A that is maximally entangled with B, cannot also be entangled with C on the same basis.
Likes bluecap
For the 2 particle case, Let’s give the observable “spin up or down” to the |a> or |b> state.
if system 1 is in state |up> and system 2 is in state |down> that is written as c1*|up>|down>
if system 1 is in state |down> and system 2 is in state |up> that is written as c2 |down>|up>
we now apply the principle of superposition so that c1*|up>|down> + c2*|down>\up> is a possible state,
the 2 doesn’t become 4. It is not like 2^2 = 4.. so why are you using 3^3?
Note
c1 * system 1 system 2 + c2 * system 1 system 2 = 80% * |up>|down> + 20% * |down>\up> (for example)..
there are only 2 terms out of the two state |a> and |b>
so how can 3 state becomes 27 terms?
Thinking it over. For the 2 particle case.. so 2 state for each system produce 4 overall terms. The following is correct?
If system 1 is in state |up> and system 2 is in state |down> that is written as |up>|down>.
If system 1 is in state |down> and system 2 is in state |up> that is written as |down>|up>.
If system 1 is in state |up> and system 2 is in state |up> that is written as |up>|up>.
If system 1 is in state |down> and system 2 is in state |down> that is written as |down>|down>.
But we now apply the principle of superposition so that c1*|up>|down> + c2*|down>|up> + c3|up>|up> + c4|down>|down> is a possible state.
there are 4 terms?
Now generalizing this to 3 particles.. since there are only 2 possibilities “spin up”, “spin down”, there it should be 2^3 or 8 only
|up>|up>|up>
|up>|up>|down>
|up>|down>|up>
|up>|down>|down>
|down>|up>|up>
|down>|up>|down>
|down>|down>|up>
|down>|down>|down>
So for 2 spin, the terms should be c1*|up>|up>|up>+c2*|up>|up>|down>+c3*|up>|down>|up>+c4*|up>|down>|down>+c5*|down>|up>|up>+c6*|down>|up>|down>+c7*|down>|down>|up>+c8*|down>|down>|down>
There are only 8 terms.. not 27.. right (others)?
I am referring to the case where you have three quantum systems in play, with each able to take on state |a>, |b> or |c>.
Likes bluecap
Let's say I have 3 systems of particles that can be spin up and spin down.. so it's only 2 state or |a> and |b>?
But to write the 3 systems in superposition.. is it not you use the following equation?
or c1*|up>|up>|up>+c2*|up>|up>|down>+c3*|up>|down>|up>+c4*|up>|down>|down>+c5*|down>|up>|up>+c6*|down>|up>|down>+c7*|down>|down>|up>+c8*|down>|down>|down> ??
if not.. any clue what is the right equation?
Bill Hobba, (@Hobba)
You can entangle as many particles as you want, and obviously so from its definition.
Entanglement is an extension of superposition to different systems. Here is the definition for two systems. Suppose two systems can be in state |a> and |b>. If system 1 is in state |a> and system 2 is in state |b> that is written as |a>|b>. If system 1 is in state |b> and system 2 is in state |a> that is written as |b>|a>. But we now apply the principle of superposition so that c1*|a>|b> + c2*|b>|a> is a possible state, The systems are entangled - neither system 1 or system 2 are in a definite state - its in a peculiar non-classical state the combined systems are in.
Generalising it to many systems is obvious and immediate.
Thanks
Bill
For my slow mind, it's not obvious and immediately and StevenTNZ is confusing me. So for 3 systems that has spin up and spin down.. do you use only |a> and |b> or also |c> and |d> to signify the 4 possibilities of 1. up,up 2. up, down 3. up,up 4. down, down? Is the following correct?
c1*|a>|b>|c> + c2*|a>|c>|b>+ c3*|b>|a>|c> + c4*|b>|c>|a> + c5*|c>|a>|b> + c6*|c>|b>|a>?
But it's only 3 systems with state up and down.. it seems wrong.. what then is the correct equation for 3 systems that has the particle that can be spin up and spin down? I've been thinking of this for 2 days. Thanks!
I have zero idea where you got my quote from, but its context looks like a general comment about entanglement and superposition.
However what you wrote is for 3 different states |a>, |b>, |c> - up and down is just 2.
I suggest you think a bit more.
Thanks
Bill
Thanks
Bill
So how do you write 3 system entanglement with two states up and down.. please just share the first 3 terms.. lol... thanks..
Mate I will leave it to you - you have three objects with two states - its just a matter of writing the permutations - tedious but trivial.
Thanks
Bill
Thanks
Bill
I've been figuring it out for a couple of days.. if the equation c1*|a>|b> + c2*|b>|a> is for 2 state and 2 system.. I thought 3 system would make it |a>, |b>, |c>.. if it remains as |a> and |b>, how do you turn the c1*|a>|b> + c2*|b>|a> into a 3 system.. it doesn't make sense to make it c1*|a>|b> + c2*|b>|a> + c3*|a>|b>, any clue?
You want to look at the tensor product of Hilbert spaces - that's the starting point for this stuff.
Oh. Actually I was also studying your convention yesterday in msg #6 in https://www.physicsforums.com/threads/entangled-particles.868970/#post-5455273 where you wrote:
"In this framework it's a lot easier to see how three-particle entanglement might work. If we have three observables commuting A, B, and C each taking on either of two possible values, then an eigenstate will be written as something like ##|+--\rangle## where the three signs represent the values of A, B, C in that order. A state like ## \frac{\sqrt{2}}{2}(|+--\rangle+|-++\rangle## or ##
\frac{\sqrt{2}}{2}(|+--\rangle+|-+-\rangle##
is entangled; a measurement of A will cause the wave function to collapse to either ##
|+--\rangle## or ## |-++\rangle##, states in which we know more about what will happen when and if we subsequently measure B or C. (Be warned that this is a highly contrived example; in any realistic situation the wave function would be such that even after collapse B and C would remain entanged)."
Nugatory, For 2 state, your used ##
\frac{\sqrt{2}}{2}(|+--\rangle+|-++\rangle## so I thought it's equal to |a>, |b>, |c> in Bhobba convention...
anyway, can you please share the first 2 terms to know how entanglement of 3 system with 2 state (spin up and down) look like.. I don't know the meaning of permutations nor tensor so no idea how to start.. thank you.
Yes, that is the state I would write. That's only if it is allowable by QM (e.g. in this case, the spin states).
So I was right all along.. and writing it in up, down is not the same as |a>, |b>,|c.. I have some questions:
1. What do you mean if it's allowable by QM.. of course the spin states up and down are allowable...
2. So in measurement, only one of the terms occurs and the rest collapse?
3. So the 8 terms make up 8 many worlds or branches?
Is this permutations thing related to GHZ? Or also there in billion-particle entanglement.. are you saying the permutations can make the terms a little less.. but how would this decrease the terms in 3 systems and 2 states (up and down)...c1*|up>|up>|up>+c2*|up>|up>|down>+c3*|up>|down>|up>+c4*|up>|down>|down>+c5*|down>|up>|up>+c6*|down>|up>|down>+c7*|down>|down>|up>+c8*|down>|down>|down> ?
I read in Amir Aczel book Entanglement in page 222 "The most amazing thing about three-particle entanglement, and the main reason for the interest taken in the GHZ proposal, is that it can be used to prove Bell's theorem without the cumbersome use of inequalities", what can you say about this?
and in page 231, "Furthermore, actual experiments have shown that the quantum theory is correct, and therefore Einstein's local realism is not. The GHZ theorem proves the contradiction in a much more direct, easier to understand, and non-statistical way, as compared with Bell's original theorem."
Do you agree?
bluecap said:
So I was right all along...
Thanks for making my day with this one. :smile:
Do you agree?
GHZ is an amazing theorem. It is NOTORIOUSLY difficult to understand, nothing like the simplicity of Bell. Honestly GHZ would be a subject for another thread. But yes, there is no need for inequalities going down this path. In principle, the outcome of every trial is itself a strike against local realism. Local realism predicts +1, where QM predicts -1 in every case. So no statistcs, averages, etc. are involved. QM says one thing, LR says the diametric opposite.
Likes vanhees71
bluecap said:
... billion-particle entanglement is the more realistic everyday scenerio.
There is no reasonable way to describe the entanglement of everyday objects as being entangled as part of large N groups. Decoherence implies that entanglement of open systems dissipates fairly rapidly over time. Interactions - such as heat transfer - normally sever any entanglement between objects. And they must first be entangled before they can decohere.
Yes, spin states of up and down are allowable, but I am not sure when it comes to three quantum systems.
If you measure system A and it is spin down, systems B and C may be found as |down>|down>, |up>|up>, |down>|up> or |up>|down>. Whether systems B and C collapse into one of those states at the time of measurement of system A I don't think anyone can really answer.
Yes.
Likes bluecap
I don't think this is correct as a statement about QM itself. It's a correct statement of some interpretations--the ones that have wave function collapse--but it is not a correct statement of other interpretations. In the MWI, for example, interactions entangle the interacting systems.
In the particular case where we have two systems, A and B, that are maximally entangled, then if, say, A interacts with another system C, then at least a portion of its entanglement with B will be severed. But that's because at least a portion of the entanglement gets transferred to C.
Likes Simon Phoenix
If all three quantum systems are spin-1/2 fermions, then each one of them can be up or down (more precisely, each one has a Hilbert space with those states as a basis). It doesn't matter how many there are.
You might be confusing this with the case of a quantum system that has more than two allowable spin states to begin with, such as a massive spin-1 boson (which has three). But that's true even if there's only one of them
Likes StevieTNZ
Is it a rule that all kinds of interactions and measurement can only form entanglement between the existing system and the new system.. is there absolute no exception.. how do you completely break off entanglement then instead of forming new one (even if a tiny portion of C in your example above is entangled to A and B.. it is still called A, B, C entanglement)? All I can think of is a gamma photon knocking off a particle in the atom that would cut the entanglement of the particle in the atom.. is this the only way to completely cut any existing entanglement, by mechanically separating them?
By transferring it to something else. For example, if A is maximally entangled with B, you can make A and C interact in such a way that C is now maximally entangled with B and A is not entangled with anything. (But this only works if C was not entangled with anything to start with.)
But cases like this, practically speaking, only occur in carefully controlled laboratory experiments (for example, the kinds of things that are done in quantum computing). In all other cases, it's basically impossible to remove all entanglement from some particular quantum system.
(Note that the above does not make use of any particular interpretation of QM. In collapse interpretations, wave function collapse does remove entanglement, because it takes away all but one of the branches of the wave function. But there is no way to test this experimentally, because collapse interpretations and no collapse interpretations make the same predictions for all experiments.)
Likes Simon Phoenix and bluecap
In the case of A and B, and C entangling with A and B.. how do you make the concept of branches enter into it.. I mean, in collapse interpretation, how does wave function collapse stop the entangling of C to A and B in contrast to no collapse interpretation.. there are no branches in the A, B, and C interaction.. is there?
But separately from the interpretations.. if you shut down the power in the lab of say the aspect experiment.. then you will cut the entanglement.. is it not? And for the apple entangling with itself and the environment.. if you burn the apple.. it will also cut the entanglement in the atoms inside and to the environment.. is it not.. or do you mean the ashes are also in entanglement?
Rather than my answering this question for you, I'm going to make a suggestion: write down the math. This is an "I" level thread, so you should have enough background to do that. First write down a state in which A and B are entangled, and C is not. Then write down a state in which B and C are entangled but A is not. Then see if you can imagine a unitary interaction that will transform one into the other.
With regard to branches, consider a simpler case: we have a system A and a measuring device M. By using M to make a measurement of A, we entangle A and M. What does the resulting state look like? This will be the state after measurement according to a no collapse interpretation like the MWI. Then suppose the wave function collapses. What does that do to the state? Is the resulting state entangled?
Cut the entanglement of what? If the power is shut down, the lab equipment is not producing any photons to begin with, so it's meaningless to ask whether they are entangled or not.
No.
What do you think?
Experiments have been done where three photons were entangled with each other. I believe the max to date has been 10 photons entangled with each other (but it may actually be more than 10).
the above is no problem.. I can write it but don't know how to put into latex.. I was not questioning how C can cut off the entanglement of A and B.. I understood the concept.. what I was questioning was about the involvement of the branches (see below)
For this equation of 3 systems and 2 state (up and down). I use 3 system because I already have the equation typed:
A measurement in MWI would mean the new system or 4th system would be entangled with each of the 8 terms making up 8 branches (according to StevenTNZ this is true, right?)
But in collapse interpretation, the measuring device or 4th system is classical, so it would collapse the wave function of the 8 terms creating only one branch.. and there is no entanglement between the one branch and the measuring device.. therefore the reason there is no entanglement in collapse interpretation is because the device is classical and doesn't entangle with the system.. and not because one branch is chosen.. because even if one branch is chosen.. there is still entanglement if the M device is not classical (remember Copenhagen has the quantum-classical divide.. so Copenhagen in the first place doesn't allow decoherence to exist at all). is this what you mean?
No.
What do you think?
You may be right the ashes as substance is still entangled with itself and the environment, the only way to avoid is to get vaporized at the heart of a nuclear explosion. (?)
In the simplest case, yes. The simplest case would be that each of the 8 terms is an eigenstate of the measurement being made, so each of the 8 terms would get another factor describing the state of the measuring device when it indicates the corresponding result. (In more complicated cases, the 8 terms you wrote down would not individually be eigenstates; but that just means we'd need to rewrite the state in a different basis. It doesn't change the principle of what's going on.)
Yes. More precisely, one of the 8 terms (with the measuring device factor multiplied in) would be randomly selected to be the one that the wave function collapsed into. The probabilities of the random selection would be the squares of the coefficients of the 8 terms (assuming the coefficients were properly normalized).
Yes, because you have a state with only one term, consisting of a single factor for each subsystem (each of the three particles and the measuring device), which is trivially separable.
No, it's because the collapse destroys all but one term, so it turns the wave function into one that is trivially separable. You can have classical objects in a no collapse interpretation like the MWI, and they can entangle with quantum systems; so "classicality" in itself doesn't prevent entanglement.
Wrong. If all but one branch is destroyed by wave function collapse, the resulting wave function is trivially separable, regardless of whether M is "classical" or not. See above.
This is not correct. A collapse interpretation like Copenhagen is perfectly consistent with decoherence. It just adds wave function collapse as an extra ingredient (which is not experimentally testable).
No, then whatever was the end product of the explosion (gases, plasma, whatever) would be entangled with itself and the environment. Why would it be any different from the case of ashes?
Likes bluecap
  • #31
What is mean by "trivially separable"? Why is it that if it's trivially separable, there would be no entanglement.. I think this is the key to why there is no entanglement in Copenhagen. Thanks
  • #32
To the Bohmians, I have a question...
First, I think turning a wave function into one that "trivially separable" means there is no longer any wave to make all the entanglement so everything simply collapses (like there is no more waves and water in the ocean which makes the boats drop to the ocean floor)... right Peterdonis? :)
So if there is no entanglement in Copenhagen upon measurement, and there is in MWI..
how about in Bohmian Mechanics.. is there entanglement in BM upon measurements?? why and why not?
  • #33
Bohmian mechanics is somewhere in between. There is entanglement in the wave function, but it does not influence the particles. Or in more precise language, there is entanglement in the universal wave function but not in the effective wave function.
  • #34
As review. In BM, the wave function controls the quantum potential that pushes the particle into either the left or right slit of the experiment.
Now's let's use the example of 3 systems in 2 state of spin up and spin down. Peterdonis (i think) said it was true that in simplest case, entanglement in MWI means that when you measure this state state c1*|up>|up>|up>+c2*|up>|up>|down>+c3*|up>|down>|up>+c4*|up>|down>|down>+c5*|down>|up>|up>+c6*|down>|up>|down>+c7*|down>|down>|up>+c8*|down>|down>|down>
each of the 8 terms would be entangled with the measuring device (or system 4) wave function. How about in BM, does the wave function in BM also entangled with all the 8 terms at the same time? If so, then MWI and BM is the same with the difference that in BM, only one world exists as the quantum potential pushes it to select one of the 8 terms only?
Is all variant of BM the same where it's wave function can entangled with all 8 terms at the same time? or for some, does it only choose one term? Thanks.
  • #35
Yes.
Yes.
Yes.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
