3 pieces of Polaroid sheet (light intensity)
Unpolarized light of intensity I0 passes through two crossed Polaroid sheets, resulting in zero transmitted light intensity. Inserting a third Polaroid sheet between the first two allows for the calculation of transmitted intensity as a function of the angle Θ between the first and middle sheets. The intensity after the first sheet is I = (1/2)I0, and the intensity through the third sheet is expressed as I' = E^2cos^2(Θ)sin^2(Θ). To find the angle that maximizes intensity, differentiate the intensity function with respect to Θ and set the derivative to zero. This analysis leads to the determination of the optimal angle for maximum light transmission in this three-sheet configuration.
togahockey15
Unpolarized light of intensity I0 passes through two pieces of Polaroid sheet. The second piece is rotated so that the intensity of the transmitted light goes to zero. A
third piece of Polaroid is inserted between the two pieces. Calculate the intensity as
a function of the angle Θ that the axis of the middle piece makes with the axis of the
first piece. By calculating the derivative of the intensity as a function of angle, find
the angle that maximizes the intensity for this three-sheet arrangement.
I0 = E2
(1/2)I0 = I1 (after 1st sheet
then, I = E2cos2Θ
dsinΘ = mλ
After passing the first sheet, I = (1/2) I0
Then, (1/2)I0 = E2cos2Θ
after that i don't know what to do...
Two Polaroid are in crossed position. When the third Polaroid is rotated through an angle theta Intensity through it is I = E^2cos^2(theta).Axis of the second Polaroid makes an angle (90 - theta) with the axis of the middle sheet. Hence intensity of the light from the second sheet I' = E^2cos^2(theta)*cos^2(90 - theta)
or I' = E^2cos^2(theta)*sin^2( theta)
Further simplify it. Differentiate with respect to theta and equate it to zero to get the angle for maximum and minimum intensity.
thanks
  • · Replies 25 ·
10K
