3 problems involving linear momentum
In summary, the force exerted on a rocket can be calculated by multiplying the rate of propelling gases (1500 kg/s) by their speed (4.0 x 10^4 m/s) which gives a total force of 6.0 x 10^7 N. In a similar problem, a 12,600 kg railroad car travelling at 18 m/s has a 5350 kg load dropped on it, resulting in a new speed of 12.6 m/s. In a different scenario, an atomic nucleus moving at 420 m/s emits an alpha particle with a mass of 4.0 u, slowing the remaining nucleus to 350 m/s. To find the speed of the alpha particle,
jrd007
159
1) Calculate the force exerted on a rocket, given that the propelling gases are expelled at a rate of 1500 kg/s with a speed of 4.0 x 10^4 m/s (@ the moment of take off) Answer: 6.0 x 10^7 N
Okay I can not figure how to get an equation to use... Though I did noticed that the rate x the speed in this problem does in fact give you 6.0 x 10^7. Does that play a role? :confused:
2) A 12,600 kg railroad car travels alone on a level frictionless track with a constant speed of 18 m/s. A 5350 kg load, intially at rest, is dropped on to the car. What will be the car's new speed? Answer: 12.6 m/s
So... here was my approach...
(Before) KE1 + KE2 ( = 0) = (after) KE1 + KE2
(1/2)(12600 kg)((18 m/s)^2) + 0 = (12600 +5350)(v^2)
sq root of 114 = 10.6 m/s... I am off by 2 numbers... did I do something wrong?
3) An atomic nucleus intially moving @ 420 m/s emits an alpha particle in the direction of it's velocity, and the remaining nucleus slows to 350 m/s. If the alpha particle has a mass of 4.0 u and the original nucleus has a mass of 222 u what speed does the alpha particle have when it is emitted. Answer: 4.2 x 10^3 m/s
I did the same approach as above with Kinetic energies... Cannot figure out what I am doing wrong. Please help me.
For the first one, it helps to remember that a Newton is a kgm/s^2 (think m*a). In other words, you just multiply them together.
For part two, momentum before = momentum after
mv + mv = (m+m)v
You should be able to figure out number 3 now.
But vertigo, is 1500 kg/s considered a mass? I was confused because masses aren't usually per anything.
2) mv + mv = (m+m)v
(12600 kg)(18m/s) + (5350 kg)(0 m/s) = (17950 kg)(v)
v= 12.6
So for number 3 do I apply the same logic, with momentums?
1500 kg/s is a rate of change of mass, like power is W = J/s, a rate of change of energy. (kg/s)(m/s) = kgms^-2 = N
Do you understand that formula for number 2? Numbers 2 and 3 are very similar, read them again.
Yes, I know the formula in # 2 with momentum.
So for number three I get this...
mv + mv = mv +mv
(222 u)(420 m/s) + (4.0 u)v = (222 u)(350 m/s)
But that doesn't work...
I also tried the problem like this:
(222 u)(420 m/s) + (4.0 u)v = (222 -4 u)(350 m/s)
And I get -4.2 x 10^3 m/s... it is the correct answer just negative... Must I consider the v to be negative, that way I get a positive answer?
What is the total momentum before? What is the total momentum after?
Isn't that what I just stated? I alpha particle has none after.
Before........After
The alpha particle does have a mometum afterwards.
You have a mass, 222, which splits into two separate masses, 218 and 4, with separate velocites.
The single mass is the before case. The two masses is the after case.
(222 u)(420 m/s) = (218 u)(350 m/s) + (4.0 u)(v)
I understand it now. Thank you!
v = 4.2 x 10^3 m/s!
FAQ: 3 problems involving linear momentum
What is linear momentum?
Linear momentum is a physical quantity that describes the motion of an object. It is defined as the product of an object's mass and velocity. In other words, it is the measure of how much an object is moving in a straight line.
How is linear momentum calculated?
The equation for linear momentum is p = m * v, where p is the momentum, m is the mass, and v is the velocity. The units for linear momentum are kg*m/s.
What is the law of conservation of linear momentum?
The law of conservation of linear momentum states that in a closed system, the total linear momentum remains constant. This means that the total momentum before a collision or interaction is equal to the total momentum after the collision or interaction.
How is linear momentum related to force?
According to Newton's second law of motion, force is equal to the rate of change of an object's linear momentum. This means that the more force that is applied to an object, the greater its change in momentum will be.
What are some real-life examples of linear momentum?
Some examples of linear momentum in everyday life include a moving car, a person running, a ball being thrown, and a falling object. In each of these cases, the object has a mass and a velocity, which contributes to its linear momentum.
