3 Questions about Rotational Motion; Test Tomorrow
In summary: Problem 1 has been solved. In summary, the disk experiences a torque of 2.4 Nm and an angular acceleration of 66.66 rad/s2.
snuffy
3 Questions about Rotational Motion; Test Tomorrow! Please Help!
Problem 1
A uniform disk of radius .12m and mass 5kg is pivoted so that it rotates freely about its axis. A string wrapped around the disk is pulled with a force of 20N.
a. What is the torque exerted on the disk?
b. What is the angular acceleration of the disk?
c. If the disk starts from rest, what is the angular velocity after 3s?
τ = rFsinθ
I=1/2MR^2 for a uniform disk about its center
T=I(alpha)
a. τ = rFsinθ
= (.12)(20)(sin 90)
= 2.4 NM
b. T=I(alpha)
T=.5MR^2(alpha)
2.4=.5(5)(.12^2)(alpha)
alpha=66.66 rad/s^2
c. wf-wi=(alpha)(t)
wf=(66.66)(3)
=199.98
Is that right??
Problem 2
A pulley of radius R1 and rotational inertia I1 is mounted on an axle with negligible friction. A light cord passing over the pulley has two blocks of mass m attached to either end, as shown above. Assume that the cord does not slip on the pulley. Determine the answers to parts (a) and (b) in terms of m, R1, I1, and fundamental constants.
a. Determine the tension T in the cord.
b. One block is now removed from the right and hung on the left. When the system is released from rest, the three blocks on the left accelerate downward with an acceleration g/3 . Determine the following.
i. The tension T3 in the section of cord supporting the three blocks on the left
ii. The tension Tl in the section of cord supporting the single block on the right
iii. The rotational inertia I1 of the pulley
Here's the picture:
http://courses.ncssm.edu/aphys/problems/AP%20Problems/ap160809.doc 1st problem.
I am very confused. I do not know how to answer this problem. I assume I must relate the tension to the torque so:
τ = rFsinθ
=(Tension)(radius)
But how would I know that the tension is the force I should use? What about the force of gravity on the two masses? How do you do this?
Problem 3
A light string that is attached to a large block of mass 4m passes over a pulley with negligible rotational inertia and is wrapped around a vertical pole of radius r. The system is released from rest, and as the block descends the string unwinds and the vertical pole with its attached apparatus rotates. The apparatus consists of a horizontal rod of length 2L, with a small block of mass m attached at each end. The rotational inertia of the pole and the rod are negligible. A) Determine the rotational inertia of the rod-and-block apparatus attached to the top of the pole. B) Determine the downward acceleration of the large block. C) When the large block has descended a distance D, how does the instantaneous total kinetic energy of the three blocks compare with the value 4mgD? (greater, equal, less)
Here's the picture:
http://www.physics4students.com/pages/apc/apcaday/apcaday_040.doc
1st problem
W-T=4ma
Once again, I just don't know how to approach this problem. I'm sorry.
Could someone just walk me through the initial steps? I need to get the answer myself.
snuffy said:
Problem 1
τ = rFsinθ
T=I(alpha)
a. τ = rFsinθ
= (.12)(20)(sin 90)
= 2.4 NM
b. T=I(alpha)
T=.5MR^2(alpha)
alpha=66.66 rad/s^2
c. wf-wi=(alpha)(t)
wf=(66.66)(3)
=199.98
Is that right??
I didn't check your arithmetic, but your method is good.
Problem 2
Here's the picture:
τ = rFsinθ
=(Tension)(radius)
Hint for a: Is it moving? What's the acceleration?
Hints for b: You are told the acceleration. Apply Newton's 2nd law to the group of three blocks on the left. Then apply it to the single block on the right. (Draw free body diagrams of the three "systems": masses on the left; mass on the right; pulley.)
Problem 3
Here's the picture:
1st problem
W-T=4ma
Hint for a: What's the rotational inertia of a point mass a given distance from an axis?
Hints for b: Draw free body diagrams for the pole/masses thing and for the block. Apply Newton's 2nd law.
Okay thanks for the confirmation on problem 1.
Problem 2:
a. Would the Tension=2mg? That seems to make sense to me. I applied Newton's Second, it's at rest so T-2mg=0.
b. Still working on it...another hint appreciated...
Problem 3:
a. Would I=(m)(L/2)2+ (m)(L/2)2+ (m)(L/2)2? One for each point mass and the horizontal pole?
b. T=I(alpha) since the torque is equal to Tr and angular acceleration=a/r
(Tension)(radius)=I(a/r)
TR=(3/4mL2)(a/r)
a=4TR2/3ML2
and since Tension-4mg=4ma then T=4ma+4mg. Therefore I could sub it back into the equation for acceleration.
C. Don't know how to do.
snuffy said:
Problem 2:
Good.
Problem 3:
Not exactly:
- You're told that the horizontal pole can be ignored.
- What's the distance of each point mass from the axis?
TR=(3/4mL2)(a/r)
a=4TR2/3ML2
Redo with the correct I.
Careful with signs. The acceleration is downward.
Consider how the gravitational PE is transformed into KE.
Okay so...
Problem 2b:
i. T3-3mg=-3m(g/3)
T3-3mg=-mg
T3=-mg+3mg
T3=2mg
ii. T1-mg=(mg)/3
T1=(4mg)/3
iii. T=I(alpha)
I=Torque/alpha
alpha=(g)/(3R)
Torque=T3-T1
I=(2mg-(4mg/3))/(g/3R)
I=2mR
Problem 3:
a. So 1/2ml2=I? And if the horizontal rod was not to be ignored it would be 3/4ml2?
b. Another question about this: how is the downward acceleration of the block related to the spinning motion of the apparatus? Is it just the acceleration of the block is equal to the angular acceleration times the radius of the spinning apparatus?
snuffy said:
Okay so...
Problem 2b:
i. T3-3mg=-3m(g/3)
T3-3mg=-mg
T3=-mg+3mg
T3=2mg
ii. T1-mg=(mg)/3
T1=(4mg)/3
OK.
iii. T=I(alpha)
I=Torque/alpha
alpha=(g)/(3R)
Torque=T3-T1
I=2mR
You made a mistake in calculating the torque. (What happened to the radius?)
Problem 3:
a. So 1/2ml2=I?
No.
The rod would contribute 1/12M(2L)^2 to the total I, where M is the rod's mass.
That's right, since they are connected by the string.
Related to 3 Questions about Rotational Motion; Test Tomorrow
1. What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. It occurs when an object rotates or spins around a fixed point.
2. What are the different types of rotational motion?
There are two types of rotational motion: uniform and non-uniform. Uniform rotational motion occurs when an object rotates at a constant speed, while non-uniform rotational motion occurs when an object rotates at varying speeds.
3. How is rotational motion measured?
Rotational motion is measured using angular velocity, which is the rate of change of angular displacement over time. It is typically measured in radians per second (rad/s) or revolutions per minute (rpm).
4. What factors affect rotational motion?
The factors that affect rotational motion include the mass of the rotating object, the distance of the mass from the axis of rotation, and the applied force or torque.
5. How is rotational motion related to linear motion?
Rotational motion and linear motion are related through the concept of force and torque. When a force is applied to a rotating object, it causes a change in its angular velocity, which in turn affects its linear motion. This relationship is described by Newton's second law of motion.
